Question about Acer Aspire 5050-3242 Notebook
Acer 5050 screen blink...AC problem???
I know this laptop is a bit dated (over 1 year) but I seem to be having problems not with the computer itself but with the AC charger.
My laptop works fine from a system point of view but when I plug it in to charge or use, it seems to be picking up the charge only some of the time.
what I mean is when I plug it in and it says that it is charging it keeps switching from AC power to batt. power causing a blink effect...is this a software problem or does it sound more like a loose charger that only picks up the adapter some of the time I am still under warranty but want to know if it is a simple program fix if not do you think it is a internal hardware problem with the charger itself.
when it does charge it does hold the charge it just keeps blinking between charge and batt power WHILE charging.
  • Anonymous Dec 03, 2008
    My 5050 will flash to life but then shut down.
    Gerald
  • 86 Answers
Very likely a problem with the connection between the power pack and the laptop itself. This is usually the weakest point, and often you need to wiggle the connection a little to get a good connection.
It is usually just a solder joint that breaks, but it is a lot of work to get fixed on most laptops so get it replaced under warranty.
Posted on Jan 13, 2008
6ya staff
SOURCE:
Is a system restore safe to do on the computer?
Yes, it is safe to do a system restore on your computer, it is just back dating your computer to a previous date
Jan 18, 2012 | Acer Aspire 5050 5430 Laptop
When i turn my acer aspsire on all i get is a light grey screen will not do anything else.
Welcome to FixYa!
It's either the hardware or just somthing in the motherboard. This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
May 17, 2011 | Acer Aspire 5050-3242 Notebook
How do you do a system restore on a acer 5050-3242?
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
Hope this helps
Jan 13, 2011 | Acer Aspire 5050-3242 Notebook
The cooling fan in my Acer Aspire laptop (bought 1 year ago) stopped working. Can it be replaced or is it part of the motherboard?
As stated it can be replaced. Might be the pits in finding the replacement fan, though.
Let's take a look at an Acer Aspire 5520 series laptop, as an example,
http://www.insidemylaptop.com/take-apart-acer-aspire-5520-laptop/
Scroll down until you come to the third photo.
Getting to the Cooling Fan in the Acer Aspire 5050 series Notebook PC's, requires a lot more disassembly, however.
The Acer Aspire 5050-3242 Notebook PC, in the category heading, is part of the Acer Aspire 5050 series of Notebook PC's.
This is the Service Manual for the Acer Aspire 5050 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the second Aspire heading.
The one that begins with Aspire 1200.
Now go down to the 5th line, and scroll across to > 5050.
Left-click on 5050.
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
[ Although I would recommend upgrading to Adobe Reader 9, if it isn't on your computer ]
After you click on the file > 5050, you won't see anything happening for up to 30 seconds.
Most of the time the first page pops up within 10 seconds, and it requires additional time to fully download the file.
Suggest you let the file download all the way, before looking through it.
Watch the Download Progress bar.
You can save this file to your computer.
This way you can burn a copy to CD for safekeeping, and easy access anytime you wish.
You can also delete from your computer then, to save Harddrive space.
If you do not know how, and wish to, simply post in a Comment.
For further questions on this please post in a Comment.
Regards,
joecoolvette
Nov 10, 2010 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5535-5050 only starts in "safe mode"
when you get to safe mode try to do a system restore to a date that the computer worked............on xp it will give you a screen to enter safemode with yes or no options ........choose no to go diorectly to system restore...............if not xp look for system restore in the system tools folder on start menu or in control panel............the screen saver error is most likely because you are in safe mode.
Jul 19, 2010 | Acer Aspire 5535-5050 Notebook
Need to restore to factory default but my lappy gives me a blank black screen with a blinking underscore on the top left of the screen.
There might be one step you could try to restore the system to factory specifications. When you turn the laptop on, and you see the Acer splash screen, press the Alt-F10 keys together at the same time, and this should hopefully bring the Acer eRecovery system up, provided that your computer has the built-in recovery partition. If it asks for a password, try using the default of "000000". If that doesn't work, then a password has been entered into the system, and there is no way to reset it, however there is a way to find out what the password is, however it does require the use of the Ubuntu Operating System (which is free to download, here)
May 10, 2009 | Acer Aspire 5050-3242 Notebook
Acer blinking screen problem
Hold down the "Fn" Key on the keyboard and press "F4", it puts your computer in hibernate mode, wait a minute...Hit the "Enter Key" and fixed!
Dec 21, 2008 | Acer Aspire 5050-3242 Notebook
Acer 5050
Do you have or did you make the recovery installation optical media [dvd or cds]. If you have the option to make the recovery media - you should do it now - as you may need to reformat the hard drive.
Mar 16, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer 5050
by default acer 5050 have 3 partitions
1. OS partition (C)
2. Data (D)
3. Recovery partition (hidden).
If you deleted recovery parition, you can't recover your C parition using Alt+F10. Your only option is recovery from cd/DVD recovery that you created. if you didn't create the cd/dvd, you can call acer support to buy the recovery dvd.
Mar 16, 2008 | Acer Aspire 5050 Notebook
Problem with Acer Laptop
removing the battery is useless if the AC adapter is still plugged in, unplug the power adapter then try fircing a shutdown by removing the battery. leave it a few minutes and try starting it again
Dec 05, 2007 | Acer Aspire 5050-3242 Notebook
Acer Aspire 5050-3242 Notebook Logo
558 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
