Question about Canon PowerShot S30 Digital Camera
Canon PowerShot S30
I have downloaded all the software that came with camera in question, and am still unable to download any pictures from it. My OS is Windows Vista, and i cant seem to find any help with any updates for this camera. Do you know where i can get them or is it even possible for this camera?
  • 7 more comments
  • nanahas3 Apr 27, 2008
    I cannot download pictures from my camera to my computer
  • Bellum May 10, 2008
    Vista seems to detect that the PowerShot S30 is attached thru the USB. It asks that I select a default program....but offers none to select from.
    If I open ZoomBrowser and ask it to find the camera...it cannot do so.
    Suggestions?...thx
  • Anonymous Jun 16, 2008
    I get a new laptop with vista on it and I tried several times to conect my camera on laptop. no succes. what shall I do?
  • coodi Jul 04, 2008
    I am having the same problem. None of my photo editing apps can find a picture on the camera either! I can not find a solution anywhere.
    This camera works fine in XP but not in Vista. The camera is listed in my scanners & cameras.
  • Anonymous Sep 06, 2008
    I have the same prob with Canon S30
  • Sheilie Dec 02, 2008
    I have the same problem. I have a PC with Vista 32 bit. I loaded the Canon Zoombrowser software and installed an update from Canon that is supposed to work with Vista.
    My PC found the driver and successfully installed it, but when I turn on the camera I get a pop up panel that says "PowerShot S30 connected. Select the program to launch for this action", but there is nothing to choose from.
    I also get a Windows information panel that says "pscND112 stopped working and was closed. A problem caused the application to stop working correctly. Windows will notify you if a solution is available."
    The camera is listed in the Control Panel as an "Imaging Device".
    Has anyone had any success solving this problem? Thanks in advance.
  • gperezdiez Dec 09, 2008
    I have exactly the same problem. I downloaded the last drivers version in Canon web site but it does not work: there is no program able to recognize the camera, neither as a unit or hard drive; only when I connect it and then, nothing to do.
  • novoempira Feb 11, 2009
    same problem. same error message. same operating system i can download it onto a machine running XP though
  • Anonymous Mar 16, 2009
    I get the same error message with my canon s30 and vista. In the control panel under cameras and scanners, windows shows the camera as conected and even how many pictures are on the card. But I can not download them or view.
NO SUCCESS
Posted on Jul 05, 2008
What if the e; drive thing doesn pop up??
Posted on Jan 22, 2008
  • 86 Answers
Usually if you just plug the camera in it will mount as a removable disk (drive e: or similar) and you can move your files off to the hard drive.
Posted on Jan 13, 2008
6ya staff
SOURCE:
My PowerShot S30 has suddenly started to produce blue pictures
The white balance is set to something other than "auto WB".
Jul 22, 2010 | Canon PowerShot S30 Digital Camera
Cannot download pictures on laptop with windows 7
1. You might be facing compatibility problems with Windows 7 OS as the new patches or updates for it are still awaited!
2. Try to download the Canon Powershot Software from these sites :
http://software.canon-europe.com/products/0010333.asp
http://driverscollection.com/?H=PowerShot%20A530&By=Canon
please rate this advice if it helps....tc! :)
Jan 03, 2010 | Canon PowerShot A530 Digital Camera
I cannot retrieve pictures from my camera. When I plug it in to my USB port, my computer is not recognizing it. I have a Canon Powershot S30, my operating system is Windows XP.
Most Compact cameras come with a software disk that has the photo software pre-loaded. My experience is that once you have loaded the software and uploaded your pictures, you can then convert the file to XP, or better still, to Photoshop.
Hope this helps
G
Jan 10, 2009 | Canon PowerShot S30 Digital Camera
Service manual needed for canon PoweShot S30
This isn't exactly a service manual, but something I had prepared for a friend who had a similar problem as you. Would recommend instead of fitting a new switch to replace the entier assembly. You can get broken S30's from ebay relatively cheap. Anyways, here's the file:
http://yxfmmw.bay.livefilestore.com/y1pMbDXGB8LmXIEowrdwrYjJv-FvzOc_lMMv7NkbxKsjKUd2mYlZzpgVBK_XIRTWMecOcaVMSdNwi6LZKKADezv0Q/S30%20Disassembly.pdf?download
Jan 09, 2009 | Canon PowerShot S30 Digital Camera
Cannot locate CD that came with Canon PowerShot S30
You don't need any special software.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Dec 26, 2008 | Canon PowerShot A75 Digital Camera
Need software
Here ya go straight from the Canon website. Select the "Drivers and Downloads" tab to find and download the software that you're looking for:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=224&modelid=14919#DownloadDetailAct
Mar 08, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Driver download
well i dont know if u running vidows xp? but so far i know it not neccesary with drivers in xp but download for other OP. os here
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=11774
thx ake
Feb 07, 2008 | Canon PowerShot SD30 Digital Camera
Unable to download pics to pc
Your Lexmark printer software may have changed the Canon software so that Lexmark is default. You need to reinstall an updated driver again for the camera. There are other great software utilities here too.
http://www.canon.ca/english/index-customersupport.asp?pid=123
It should be a simple software problem. Only other solution is the USB cable or USB port fault.
Nov 07, 2007 | Canon PowerShot S30 Digital Camera
Canon powershot sd 750 problems
Check on the CD software you received with your camera whether it support the Win Xp OS. In case it doesn't support your OS, go to the Canon web site and download to your PC the relevant drivers for your camera and OS. Good luck !
Aug 15, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Canon PowerShot S30 Digital Camera Logo
541 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Ekse
Are you a Canon Camera Expert? Answer questions, earn points and help others
