Question about Transceivers
Lost clicker 4 my uniden car alarm
I lost my car keys and my car has a uniden car alarms system with a immobiliser in it have no spare clicker and im currently getin a new key for the doors and ignition but dnt no wat 2 do with the alarm system to start driving again any hints
0 characters
1 Points
Record greeting message for unida Dect 6.0
Do you mean Uniden DECT 6.0? If so, select the model of your phone/answering machine from the list beginning at to download a copy of the manual.
Sep 11, 2013 | Alcatel-Lucent OS6602-24 Managed Ethernet...
You nee reset windows login password, there are two methods to help you reset windows password.
Method 1: Bypassing windows password with password reset disk
Step 1: Insert the password reset disk into your locked computer.
Step 2: When you input the incorrect password in Windows logon screen, the "Reset Password" option will pops up, click it.
Step 3: When you click the "Reset Password" link, a "Password Reset Wizard" will come up for you to reset the forgotten password.
Method 2: Bypassing windows password with Windows Password Recovery
Step 1: Download Bypass Windows Password software and install it.
Step 2: Burn a bootable Windows Password Recovery CD/DVD or Windows Password Recovery USB flash drive with the program.
Step 3: Reset Windows Administrator Password to blank with the burned CD/DVD or USB, then bypassing windows password and regain access to your locked computer.
Apr 23, 2012 | HEWLETT-PACKARD Hewlett Packard HP Mini...
How to reset the Password n 3510-24T Nortel switch
Hi Try the following - it should go back to factory default settings
There can be times when you need to factory reset a switch. This process can be accomplished through the CLI but if you've lost the switch password you'll need to follow a special process. This process should work for any of the Ethernet Switches (450, 460, 470) and the Ethernet Routing Switches 2500 Series, 4500 Series, 5500 (5510, 5520, 5530) Series. There is a different process to recover lost passwords on the Ethernet Routing Switch 1600 and 8600. Please note that by factory resetting the switch you will loose all configuration settings. It will be as if it just arrived from the "factory".
Follow these steps:
1. Connect to the console port of the switch (9600,8,N,1)
2. Reboot the switch.
3. When the first line of the diagnostics tests is displayed, press CTRL-C. The system then displays a menu.
4. Select option "i" to factory default the switch.
5. Select option "a" to run the agent code.
Upon boot up, the switch will be in a factory default configuration
Jan 06, 2010 | Nortel Ethernet Routing Switch 3510-24T...
C905 lcd went black, does showing at all
if you think that youll just spend a lot of money in repairing your phone, then its time for you to buy a new one.. we have the same problem as well, but i dont have a choice but not to use it at all rather buy a new one for myself.. sometimes.. they will tell you that its difficult to fix bcos they dont have any spare parts to trade. but you know theyr just money making. one time i borrowed a digicam fr. a friend and use it to take pics of my nephews grad. after using it and my brother dropped it on d flor not quite high. but it just shake. and d screen goes in black. d lense had a problem.den i went to d products ofc. (kodak phils.) dey told me that its difficult to fix yet i need to buy a new one.they offered me. if i buy a new one itll cost 10grand.but if im interested theyll giv me a discount w/c ill sell to them d cam & buy a new one to dem w/ discounted price?? huh ?? dem my bro decided not to buy. insted went over RAON., (quiapo mnla. phis.) atlast. he saw a technician and fix it for us for only 1.5 grand. look. how much d diffrence? a lot of good technicians hir in d philippines. but not a good company. bcos its a street w/ a lot of celphone dealers. if you will go hir in d philippines. dont forget to stop by on RAON, QUIAPO MANLA. but be reminded not to wear jewelries & to dress up casually, do not talk to strangers. ask only d security & d merchants.. sorry for d bad english & long story :)
Jul 24, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
Low free storage alert on my tmobile dash
you have to do a master reboot on the phone.. that will clear up the things that you cant erase... Hard reset:
1. Power off
2. Push both white dash keys and power up.
3. At T mobile screen it will change to black with writing and instructions.
4. Let go of soft keys and push send (follow directions on screen).
5. Formatted!
Jun 06, 2009 | Jabra T-Mobile Wing / Dash / SDA /...
Laserwriter 4/600 to G5 via asante talk
The wonderful Asante tech support people in San Jose, CA, talked me through this fix last week:
This is for system 10.5.x.
1. Delete that printer from your list of printers in System Preferences.
2. Make sure your computer, printer, and Asante box are all hooked up together and turned on.
3. Click + under the list of printers in System Preferences.
4. Click AppleTalk icon in top row of dialogue box that appears.
5. After a moment, click Bluetooth icon instead.
6. After a moment, unplug the power cord from your Asante box (but not from the electrical outlet).
7. After a moment, re-plug the power cord into your Asante box and, as soon as possible after the "TX" light comes on, click the AppleTalk icon again.
8. Within a few moments, your printer's name should appear. Highlight its name, then make sure all the information about it that appears is correct, then click "Add."
9. Everything should communicate beautifully. I had no further problems.
Sep 06, 2008 | AsanteTalk - Ethernet to LocalTalk Adapter...
2001 plymouth neon
My car radio wont work but the radio lights stay on
Apr 12, 2008 | NEC Refurbished RC-28C ALARM CARD HECI...
Transceivers Logo
212 people viewed this question
Top Transceivers Experts
Mohan Sriraman
Mohan Sriraman
Are you a Transceiver Expert? Answer questions, earn points and help others
