Question about BUSlink Disk-On-the-Go-Lite (677891121369) 80 GB Hard Drive
Problame i format my hard disk
0 characters
1 Points
Pc hard disk problam
Try some of the free data recovery software to see if they can read it.
Recuva, PhotoRec and other decent free programs as a start.
Jul 24, 2014 | Western Digital Hard Drives
My SanDisk Cruzer USB flash drive had problams with the U3 systam, So i uninstalled it by using the "renuve u3 luntch pad.exe." then I selected the "format adn keep my data" option, but the systam find a...
You have ruined the file integrity of the flash drive, There is a very slim chance that you will recover any data off of the drive. Most flash drives only have a read/write of about 8,000 to 9,000 times so depending on how much you actually used the drive, it is possible it finally went bad. To format the drive try going to my computer and right clicking on your cruzer drive letter and click format. "ALL DATA WILL BE ERASED WITH THIS OPTION"
Jun 21, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
try to format the HD using disk management. right click computer select manage then disk manager. look for your external HD and click format.
Mar 26, 2010 | Hard Drives
Checking hard disk for errors
no, checking the Hard Disk using windows tools does not format the hard disk. You data would still be there.
Jul 20, 2009 | Hard Drives
Bad disk
low-lable format can solve ur problem.
at first create windows98 startup disk from any win98 pc or use windows98 bootable cd. and download disk manage 9.54 for samsung hard disk. and copy it in a cd. then boot ur pc with windows98 bootable disc or startup disk. then inseart disk manager cd go to cd rom drive give "dm" commnad. run low lable format form advance --->utility ----->maintanance------> low lable format. after complete low lable format (it can take saveral time) then creat partition and format each partion.
Jun 25, 2008 | Samsung (SP0411N) 40 GB Hard Drive
Hard disk is read only
format your hard disk with disk manager software. (low level for formating). this software can remove bad sector of your hard disk
Oct 10, 2007 | Hard Drives
Hard disk problem
First u should format disk from disk management mmc snap or from command prompt.without formatting a disk's properties says 0 bytes used and 0 bytes free space.
Sep 03, 2007 | Seagate Barracuda 7200.7 (ST360014A-20PK)...
BUSlink Disk-On-the-Go-Lite (677891121369) 80 GB Hard Drive Logo
Top BUSlink Hard Drives Experts
Brian Sullivan
Brian Sullivan
Are you a BUSlink Hard Drive Expert? Answer questions, earn points and help others
