TV image goes off when VCR power turned on
When I turn on the power for my VCR the TV image disappears, meaning
I can't tape off the TV. It worked fine for about eight years, then became an intermittent problem, now a seemingly permanent one. What can I do to fix this?
  • fritz73 Jan 25, 2008
    My sony SLV-998HF has same problem; tuner operation is intermittent-sometimes tuner works for a little while, then starts getting scratchy video and audio, then goes out completely(blank screen). Stereo and SAP indicators will go out too. Bad solder joint somewhere is the strong idea I'm getting. I've owned unit since new (1998).
  • 579 Answers
The vcr is connected in between the antenna (or cable) and the tv, and when it turns on its tuner takes control of the signal. Either:
1) press the VCR/TV button on the VCR to let the signal go stright thru
2) Tune the VCR to the channel you want to watch and set the TV to the VCR's input.
3) If you use a coax cable connection to the TV, try switching the VCR to the other channel (3 or 4, switch in the back)
4) Change the TV connection to RCA cables on the A/V inputs.
Hope Ya Fix It!
Posted on Jan 13, 2008
The TV turns off when i put a VHS tape in the VCR. The tape will play for a few seconds, then the Power goes off. When i turn the Tv back on the tape immediately ejects.
Possibly have a tape drive motor issue it powers down to save itself .Thats the dickens with those combo sets they are hard to look at ,you have to take it half apart just to see whats going on
Feb 16, 2011 | Sylvania 6719DC 19 in. TV/VCR/DVD Combo
Vcr cuts my tv off after i put the tape in
The VCR is not turning the TV power off. The tape is not playing. I'd guess maybe it needs a cleaning or a replacment.
Dec 24, 2009 | Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
After vhs auto rewinds both it and TV power down
some televisions have a feature where the video signal disappears,they power off.when the vcr shuts off,the signal goes and the tv shuts down
Jul 07, 2009 | Emerson EWV403 VHS VCR
Emerson EWC 1302 Tv/VCR combo shuts down
I've seen problems like this with 2 tv/vcr combo sets before. in my case each time the sensors in the machine think there's a tape jammed, and it shuts down to prevent damage. if tihs is what's going on it should actually say onscreen that it's trying to eject a tape, whether there's one in or not.
WARNING: this fix may get the tv working again, but the vcr will not be usable.
if this is what you're seeing then step one would be to remove the tape (assuming there's one there at all), now turn it back on and see that: THIS DIDN'T FIX ANYTHING! that's where step 2 comes in, you need to probe around a bit, in my case this was very much a trial and error thing, and find which mechanical parts are in the wrong positions. you want everything in the position it should be with a tape ejected. with this done you should be able to turn the tv on without getting the eject message and having the tv turn off.
Sep 15, 2008 | Emerson EWC1303 13 in. TV/VCR Combo
What do I do when my Emerson TV keeps turning off by itself?
I had the same problem with mine turning off after 3-5 seconds. After much research I found a suggestion that on some combo units the vcr part could have a power supply cutout if it is not working correctly. I tried to insert a tape and found that the tape mechanism would not accept a tape. I used a little bit of force and managed to insert a tape. I then played the tape forwards and backwards and the power stayed on! I ejected the tape and found the TV then worked just fine. The power has now been on for over one hour. I hope this give you another avenue to try and fix your problem.
Nov 30, 2007 | Televison & Video
Emerson TV won't stay on
I am currently have the same problem . I just got off the phone with the support tech and he suggested unplugging TV for about 5 minutes and if that doesnt work to unplug TV for about 2 hours. He said that may reset the TV . I am waiting now. If it works , I will leave feedback.
Nov 15, 2007 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Vcr freeze frames tv programs when turned on
No nO NO the cable out from the cable box goes to the input of the VCR and the VCR output goes to the TV connection. Good Luck
Jun 05, 2007 | Panasonic PV-V4525 VHS VCR
My Tv is turning off by itself
if all you want to do is disable the vcr portion turn the set on , install a blank vhs tape it has to be blank or the vcr will try to read it .and the tv and dvd should work fine. this is a timing problem in the vcr deck its not hard to fix but it is a pain.
Nov 05, 2006 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
TV shuts off when VCR tries to eject cassette
This is a hard call man. Some combos have to be laid down when taking the back off or it will collapse when you do take off the back, falling over backwards as they are top heavy. These units are so tight inside by means of no room to work so alot of maufacturers have extension cables to attach to componets ie vcr deck and main chassis. After they take them apart. If you really feel confident then lay the set down on its face and take off the back and after the back is off look to see in the deck part if the tape has come out of the cassette or if it all looks normal. If you see the tape out of the cassette ,cut off the tape on both sides and see if the tape will eject. It it does then go back in after and remove the remainder of the old tape. Now it could have been a bad tape but most likly something is wrong with the mechanism. If you cant see anything out of norm, dont try to force the tape out as you WILL cause more damage and most likely unrepairable. Really there are no user serviceable parts inside these buggers so the best advise I can give ya is to disconnect the thing and take it into your repair shop for an estimate!! Good Luck
May 23, 2006 | Samsung CXJ1964 19 in. TV/VCR Combo
Televison & Video Logo
104 people viewed this question
Top Televison & Video Experts
