Question about GE Profile Arctica Stainless Steel Top Freezer Refrigerator
Ice trays overfill leaking into the basket
The water fills to the point water runs down into the basket- Now the auger is broken, and we still don't have ice coming out right
    Genius:
  • 1,122 Answers
FIND ADJUSTMENT SCREW UNDER ICEMAKER COVER AND TURN DOWN ICE CUBE SIZE,REPLACE AUGER,THANKS-MIKE
Posted on May 29, 2008
Water leaking from Icemaker fill tube near the back wall
It probably is not the water valve. More likely it is the ice maker itself. Nothing else in the machine controls the flow of water to the ice maker except the ice maker itself. It is recommended that both the ice maker and the water valve needs to be replaced when trouble such as this.
Dec 12, 2012 | Refrigerators
Ice maker not working
my icemaker has a wire overfill sensor which shuts off the icemaker if there is too much ice in the basket. If this wire gets pushed up it will stop making ice until level lowers OR manually lowered.
Feb 08, 2012 | Electrolux EW28BS71IS (278 cu ft) Bottom...
Ice maker no longer making ice. A few weeks ago the water that was supposed to fill just the ice tray, didn't turn off, overflowed the ice tray and proceeded to fill the ice basket underneath. Since then...
Sounds like the water flowed enough to freeze the end of the fill tube shut. Best to prepare to replace the dual water control valve on the rear and near floor of refrigerator. If it was leaking and you should thaw the tube you need to turn the main supply of water off until replaced. Then thaw tube and replace the dual control valve. I will return with a part number providing your model number is correct, Thanks, Sea Breeze
Jan 17, 2010 | Maytag MBB1954G Bottom Freezer...
The ice in the ice tray becomes a solid block and has to be manually broken apart to get the dispenser working again. Tried changing the temperature on the front panel to no effect.
Good day,
Water leaking from the water fill valve when it should be off can overfill the ice maker cavity causing that, or the fill tube from the back of the machine going into the back of the ice maker has become dislodged.
Machine could be going into it's defrost cycle for too long, warming up the area around the tray causing the cubes to partially melt.
Nov 05, 2009 | GE GSH22JFT Side by Side Refrigerator
ICE DISPENSER
Dmuehr,
Are you sure it is a leak. Is the solenoid actually cutting off BEFORE the tray is full of water? If not, it is not a leak. The filling time for the icemaker water tray (where the ice freezes) varies depending on the local water pressure. With higher pressure, the tray may overfill. Your icemaker motor module timer may be set too long for your specific water pressure, so that the tray overfills. There is an adjustment on the module for shorter or longer fill time. You will need to remove the icemaker (3 screws probably) and reset the timer. It may take 2 or 3 tries to get it so the trays are about 80 to 90% full.
Jan 07, 2009 | Whirlpool GS6NBEXR Side by Side...
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Jan 04, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Ice maker overfills with water, drips into ice bin, and auger cannot turn because of ice. Can't find any water regulator.
Don't have this model, but could there be a weight sensor for the ice tray that is stuck and possibly frozen in the up position? The weight sensor would normally sense when there is enough water in the ice tray and then cause the water to shut off. See whether the tray should have up and down vertical movement.
Jul 24, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Ice cubes melt together
check the fill cup on the rear of the icemaker to see if any ice is frozen in the fill cup if so remove the ice
May 06, 2008 | Refrigerators
Ice maker leaking
shut off the water going into the unit if it stops doing it then your valve is bad as it is leaking by and filling the im too much
May 05, 2008 | Frigidaire FRS3R5EMB Side by Side...
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
GE Profile Arctica Stainless Steel Top Freezer Refrigerator Logo
106 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
