Question about HP Pavilion dv6000z Notebook
CD/DVD drive When I put a CD/DVD in the computer says, 'doesn't recognized CD-Drive.' Is this a problem I can fix?
  • 89 Answers
Possibly. Try this: http://static.tigerdirect.com/pdf/HP_Pavillion_dv6000_MnS.pdf
Go to section 1.2 and follow the procedures.
Posted on Jan 14, 2008
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
My emachines el1360 doesn't recognize cd/dvd
Try going to safe mode. Restart your computer and tap f8. Use the arrow key to highlight safe mode, and once you are inside safe mode. Try running the dvd or insert the sd card. If it runs well, then install RadarSync or any automatic PC updater then update the drivers. You can also manually update them by going to the website of your computer's manufacturer. Look for support and download.
Feb 24, 2013 | E-Machines Computers & Internet
CD/DVD drive not recognizing game
Clean the cd/dvd with a laser lens cleaning kit. If that doesn't fix it then the cd/dvd drive will need to be replaced.
Aug 18, 2012 | Cosmi Star Wars Empire at War Gold Pack...
L305D-S5930 dvd wont burn documents to a dvd disc
You need a program, like nero.
if that doesn't work then put a DVD in the drive & see if the computer picks it up in the my computer.
the first thing that goes in a CD/DVD-RW drive is the DVD heads, thats if your drive is a CD/DVD-RW.
Have a look on the front of the drive tray, if it say CD-RW DVD ROM then it doesn't burn DVD's it only plays them.
Jan 30, 2012 | Toshiba Computers & Internet
Computer does not recognize CD/DVD disks in drive. My Windows XP PC has suddenly stopped recognizing disks in my CD/DVD drive. Device Manager shows that both of the listed drives (TST Corp. DVD +RW...
Most likely a problem with the reader on the CD/DVD Drive.
Very easy to swap out a different CD/DVD Drive. Add the new device and see if that resolves the issue.
May 02, 2017 | Computers & Internet
The DVD writer doesn't recognize that there is a
Most DVD drives are also CD drives, and it sounds like the DVD part is broken, you need to replace the DVD drive, this is done simply by buying a new one, I recommend Newegg.com ( if your unsure search exactly what you already have) then opening your case (tower) and just unplugging old one and plugging new one in, it really is very doable for even a novice.
Jun 26, 2011 | HP Computers & Internet
I need a driver for my backpack DVD +- RW model number 224010. Lost my installation CD and now have a new computer that doesn't recognize the drive
If you are using Microsoft, have you tried using the driver search tool? When Windows says it does not recognize a drive via pop up, click it to have the option for windows to search for the drivers online. If that doesn't work, you can manually search for drivers, which can probably be found on Micro Solutions' website. If the PC cannot detect any drive at all, then odds are the installation was incorrectly done.
Jun 01, 2011 | Micro Solutions Backpack DVD±RW...
CD driver do not read any file
Does it recognize any cd you put in the drive or is it only one cd it doesn't recognize?
Please check if the cd drive is recognized by your computer:
Click Start go to My Computer (XP) / Computer (Vista/Win 7)
and check if you can see the drive. (if it's not there you may have to reseat the drive to make sure that the cables connecting it to motherboard are tight)
check the status in the Device Manager:
On your Keyboard press and hold the Windows Key then press the letter R
once the Run box comes up type in devmgmt.msc and the device manager should appear.
On the device manager look for the cd / dvd drive see wether it has an exclamation point a red x mark or a down arrow or it looks normal.
if it has a yellow exclamation point press and hold the windows logo then the letter R again and type regedit:
On regedit go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and the delete the upper and lower filters. Close Regedit and restart the computer.
if it has a red x mark right click on the cd drive in the drive in the device manager and the choose uninstall and restart the computer.
If it has a down arrow right click on the drive and click Enable.
If the above steps doesn't work or if it doesn't recognize all types of media you put in it, that might mean that your cd drive is busted and it needs to be replaced.
Hope you find this helpful!
Apr 30, 2011 | LG CRN 8245B (CRN-8245B) Internal 24x...
Computer not recognizing Dvd drive
Hi, Check the MS word / software file it works DVD drive, if it recognize there is no problem the drive and play CD - format files.
If not recognize, i found that DVD Lens not working what you can do DVD lens cleaner disc you found stores. Rgds, Manju
Jan 26, 2010 | Computers & Internet
Dell Lat. D600 will not read cd and does not recognize cd
this tool will fix it
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
May 30, 2009 | Dell (313-1220) CD-RW/DVD-ROM Combo Drive
HP Pavilion dv6000z Notebook Logo
42 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
