Clicks on and off when turns on
When i turn on my tv it just makes a clicking noise like its being shut off and on. the power light flashes with the clicking. I was told this may be the flyback transformer, but before i go buy this somewhat expensive part i wanted to find out for sure? any one know where i could get the schematics of this tv cheap
  • Ericws Jan 14, 2008
    I am also having the same problem with a Mitsubishi VS-50705 RPTV. It started out by shutting down after about 1/2 hr of operating and now clicks off as soon as you release the button. I get fault code 22 from the front LED and I've researched issues on coolant leaks onto the power board. The TV had a coolant leak around Sept 2007, was repaired, and has been operating great ever since. No coolant is visible on the PCB at this time. Since I was not the owner of the TV at the time of the first leak, I'm just looking for a place to start and some schematics
  • phan Jan 15, 2008
    Phillips model 32PT563S37G I have a meeter to test it but i cannot find schematic for it. any tips on what to test and what the reading should be would be a a big plus
  • 8,617 Answers
What is the model of your set. I should be able to locate a service manual for you as well as help you diagnose whats exqactly wrong with it.
Posted on Jan 13, 2008
  • Sonny Berry
    Sonny Berry Jan 15, 2008
    Unable to locat a service manual. But check the horizonta output transistor. Its located near the flyback on a large heatsink, also check the low voltage regulators also located on a heatsink but those heat sinks are smaller. Hope this helps I will keep searching for a manual.
6ya staff
SOURCE:
Won't turn. on red standby light changes to on but then goes right back red
TV won't turn on - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I have the Samsung FP-T5084 50" Plasma tv. I went to turn it on the other day, and it wouldn't turn on. No clicking. No red power indicator light. Nothing. Samsung TV LN52A650A1FXZA won't turn on, keeps clicking
Jun 11, 2015
Samsung TV won't turn on
Jun 11, 2015
Samsung LCD TV LN32A330 power won't turn on
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
More results from www.cnet.com
The power light keeps flashing and the tv wont turn on - TV ...
www.tomsguide.com/answers/id.../power-light-flashing-wont-turn.html
If you unplug for a minute and hit the power button it sound like it is coming on then it shuts off and the red power light flashes slowly. The TV is a Panisonic 1080i HDTV, about 6-7 years old. ... I have an old type sony tv with the big back and the red power light keeps flashing and ...
How do you fix a television that won't turn on? - Ask.com
www.ask.com > Technology > Television & Video
Jan 03, 2016 | Televison & Video
THIS TV WILL JUST SHUT DOWN WHILE WATCHING, FIRST IT WAS JUST EVERY SO OFTEN AND I THOUGHT IT WAS CABLE. IT WOULD GO OFF THEN COME RIGHT BACK ON, BUT NOW ITS HARD TO GET IT TO COME BACK ALL I GET IS THE...
Now tv turn on have the power LED light indication flashes and tv making clicking noises?The tv power supply board is mostly the causes,that the board,where the power a/c cord plug into it.Try website like Ebay.com to buy a refurbish power supply board for the replacement.
Mar 24, 2011 | Panasonic TH37PX60 37 in. Plasma...
Hi. I have a Zenith 42" plasma TV - Z42PQ20 that's
I had this exact problem on my TV, everything said it was the power board. It wasnt, luckily i was able to return that board. It was the YSUS board.
I should have done this this first but this is how i verified the old power board was good. Unplug TV, take the cover off and disconnect the wire harness going to the YSUS, plug TV in and turn on. If led stay blue its the YSUS.
Mar 19, 2011 | Zenith Televison & Video
The TV was working, and then randomly just shut off and won't come back on. It still makes the click noise when i turn it on, but only once instead of two. The standby light keeps flashing four times....
Hello melanie Hi, in my experience as a TV technician, that would usually be a shorted part, the horizontal output transistor, that part powers the HIGH Voltage section. Very Lethal, the power supply detects this bad part which in turn makes the unit go in standby so as not to damage the TV much further. mMy advice is go seek a tv tech to repair the part.
Jan 20, 2011 | Sony KV-27S42 27" TV
SONY KDS60A2000 will not turn on,flashes green light for a few seconds and then clicks off and red falsing light returns
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator.But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is XL5200 you can find it here:http://www.discount-merchant.com/Sony-Grand-Bare-Lamp-XL-5200-p/sony_xl-5200u_replacement_lamp.htm?Click=48173.Have a blessed one!
Apr 30, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
It wont turn on anymore. it fires then instantly shuts off, doesnt even flash screen. standby lights still flash and its trying to turn on, just cant get on. you can hear the on sound and then the tv...
Depending on the age of your tv, if you hear a rapid clicking, it seems like your ballast is starting to turn on your tv but it's not able to. (1) Check your lamp, (2) reset the lamp timer, (3) make sure the cover panel is all the way. the positioning sensor might not be detecting the cover all the way in.
Personally I think you're experiencing a ballast problem.
Apr 20, 2010 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Samsung LNT4061FX makes clicking noise before coming on.
Replace capacitors in power supply you will see that they are bulged on top
Sep 13, 2009 | Televison & Video
TV won't turn on, red flashing light
Hold The Off Button for 20 sec should make clicking noise switch off at power and on again should be working
Nov 03, 2008 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Tv wont turn on only clicks and then flashes red timer light
tv wont turn on when i hit power it makes the clicking noise like it is going to turn on, but never does and the red timer light next to the power button just flashes.
help!
trinitron kv29f1u
only clicks and blinks
Jul 26, 2008 | Sony KV-35S42 35" TV
I heated up board with hair dryer through back of TV without taking back cover off. The heat was on high for approx. 5min. and was placed on right side of TV about 1/3 up from bottom.
Nov 20, 2007 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Televison & Video Logo
131 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
