Question about ASUS S-Presso S1-P111 Deluxe (SPRESSOS1P111DELUXE) Barebone
Front Panel display do not disply.
The front panel display show only a small vertical line. Is there anything can be done in tems of BIOS or all it is hardware issue.
  • Elik Jan 13, 2008
    THE COMPUTER CAME ALL INTEGRATED WITH THE FRONT PANEL AND WORK PERFECTLY FOR 2 YEARS AND IT JST HAPPEN. NO MOVEMENT OR SPILL.
    THANK YOU FOR YOUR RESPONSE.
  • knightsky
    knightsky May 11, 2010
    Did the board in the case come with it or was it a board you yourself put in the case? Did you at any time drop or spill anything on the computer?
    President:
  • 2,351 Answers
From your description is sounds like the display has died. I can suggest it may be possible to have it replaced or you replace it through Asus. Have you tried to chat with Asus through their on line chat service? http://livesupport.asus.com/
This can work out to be a fix. Luck....
Posted on Feb 07, 2008
  • Mike Peluso
    Mike Peluso Feb 08, 2008
    I'm loosing it! Asus warrents boards & barebones for three years. So here's their number. IL EST. Tech support 812-282-2787, you will not find this in your manual. They moved to IL in 2007. You talk with tech & they'll ask you to try this or that, than they'll want the serial number to check the warranty. The tech should give you a case number, don't hang up with them before you get one. They'll give you the number for the RMA dept. You can just ask to be transfered. Wait times vary. The RMA dept is in CA. So if your ET they are 3 hours behind you.
My cpu is front light on but not go to disply powr fan is ok runing but not show the disply plz help me any on
check the display monitor cord to CPU if attached perfectly/check on off switch of display screen
Feb 23, 2015 | Computers & Internet
Westinghouse 47" has a black vertical line in the middle of screen
Anything from a bad connection on one of the boards (solder or plug) to a bad board (rare) to a problem inside the front display panel which is usually fatal if the issue from a cost point of view---getting any parts for a Westinghouse may also be hard as last I heard they were again out of business.
Dec 17, 2012 | Westinghouse W4207 42 in. HD-Ready LCD TV
Sylvania hdtv model lc320sl1 will turn on but does not get picture.... sound works.... various colored lines and or scrambled picture appears at best
Let me start at the beginning---Likely a bad main board in your case but nothing is sure in this type of set.
Main board controls all information to the front screen and communicates to various boards---There really is almost never a simple "that part is bad solution" as any board, the power supply, the main, etc can cause issues.
It can even be a issue with the front screen unit--called a display panel.
You might consider doing some research on the set by Google of the model number with "parts" to get an idea what is available and what potential parts cost might be.
If a main board is bad it will average from one to two hundred just for the part----if issue is the panel you are done--part if even available is more than set cost when new.
Let me know if you have questions.
Jun 03, 2012 | Televison & Video
Red vertical lines on right side of LED TV set
It is likely the main board that processes all signal to and from the display panel (entire front screen unit).
It is also possible it is the display panel itself which is fatal.
May 16, 2012 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
ASUS p5kc front panel connector
all motherboard front side audio connector is equal so if you compair with onther motherboard
connector
Feb 02, 2009 | ASUS P5K Deluxe/WiFi-AP, iP35, S 775,...
Vertical stripes on screen.
well, change ur screen their is failure in your screen line & row moudle
Sep 29, 2008 | Televison & Video
Red vertical line.
I will give you a small step through which you would be able to know whether its a hardware or its a software issue.
You need to log in to the BIOS. Do not change anything in the BOIS just check whether you have that red line in the BIOS.
If you see the line while you are in the BIOS, that means its a hardware problem and you need to contact the manufacturer (In this case HP ). You should get a replacement if its under warranty.
If you do not see the red line in the BIOS than it is a software issue and you need to start with reinstalling the Display drivers.
Note : - Steps to go to BIOS. ( Dont change anything in BIOS )
Turn off the computer
As soon as you turn it on start tapping the key "F2". ( "Del" in some brands).
Hope that will give you a good insight.
Sammy
Nov 29, 2007 | Computers & Internet
THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
Jun 14, 2007 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
ASUS S-Presso S1-P111 Deluxe (SPRESSOS1P111DELUXE) Barebone Logo
281 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
