Question about HP OfficeJet 7410 All-In-One InkJet Printer
Keeps asking to load original in document feeder
I placed a document in the glass surface to make a simply copy,I press the copy button and the printer ask to load original in document feeder.I don't want to use the feeder that's why I placed the document in the glass surface. Is there a way to bypass the document feeder to use the glass surface?
  • 1 more comment
  • Mike1993 May 21, 2008
    your solution worked - tools, restore factory defaults. Many thanks
  • nardelyz27 Dec 23, 2008
    quiero printiar algo de la computadora y no puedo
  • Anonymous Mar 22, 2014
    printer will only print documents that are placed on glass bottom NOT FROM MY MONITOR
This has a happy ending. But first, the obligatory narrative:
The HP site has advice on how to deal with a document feeder that doesn't detect your document. It doesn't talk about the opposite problem, which is what molecular is describing. I had the identical problem yesterday. I'd place the original on the glass and it kept demanding that I put the original in the feeder. So I got into a chat session with the HP technician. Her advice, (based on the possibility that a power surge had created the problem) unplug from everything, restart, and retry. The problem persisted. I told her so. She broke the connection. Nice.
So here is how I fixed it. Using the Setup button>Tools>3. Restore factory defaults, I returned the device to its factory settings. I put the original on the glass and it made the copy without a problem.
Here is a pure speculation. There are at least two ways to enter settings related to two-sided copying. I had used one to enter the settings (two-sided original to two-sided copy, as it happens) and later tried to use another button to change those settings. I noticed the 2-sided settings did not change. I believe the feeder is the default for two-sided copying. So when the system failed to clear the settings, it failed to clear the default. Once I returned all settings to the factory originals, the problem disappeared.
Posted on Mar 14, 2008
    Sniper:
  • 95 Answers
SOURCE:
Have a dell 3115cn when copying from tray a line appears in the center how to remove line
lift document feeder cover, you will see the large glass surface, to the left of it there is a strip of glass about 2 cm wide. This is where the scanning from document feeder occurs. Clean glass with alcohol or glass cleaner
Apr 16, 2013 | Dell 3115CN
Status stopprintatus
I did not understand sir, what you want to ask.If you want to rename the file then its not possible on machine.You can just give print commands.you cannot edit it or rename the documents to be printed through machine.Every time you will check job list there will be an option to stop printing or CANCEL.If you want to make a copy then simply place the original in document feeder or onto the glass then simply press the START button.Its best to select the tray first.If red light glows then check the trays are properly closed.Check if tray is empty then load paper.Every time any error comes on machine it will appear on screen.When red light glows, kindly check if there is some indication appeared on screen or instructions, then please follow it or explain the problem in detail which you are facing.ALL THE BEST!
Dec 09, 2011 | Konica Minolta Bizhub c203 Copier
How to fax
Load an original in the automatic document feeder (ADF)
You can copy, scan, or fax a single or multiple-page A4, letter, or legal-size document by
placing it in the document feeder tray.
The document feeder tray holds a maximum of 20 sheets of letter or A4-size paper or 15
sheets of legal-size paper.
To send a basic fax from the control panel
1.
Load your originals. For additional information, see Load originals.
2. Enter the fax number by using the keypad, press Speed Dial or a one-touch speed
dial button to select a speed dial, or press Redial/Pause to redial the last number
dialed.
TIP: To add a pause in the fax number you are entering, press Redial/Pause,
or press the Symbols (*) button repeatedly, until a dash (-) appears on the display.
3. Press START FAX Black.
If the device detects an original loaded in the automatic document feeder, it
sends the document to the number you entered.
TIP: If the recipient reports issues with the quality of the fax you sent, you can
try changing the resolution or contrast of your fax.
for further refernce check out the online manual
http://h10032.www1.hp.com/ctg/Manual/c01181836.pdf
Mar 29, 2010 | HP Officejet J3680 Multifunction Printer...
Instructions for scanning on epson cx4300/cx5500/dx4400
Scanning the Document
Place the original on the glass.
1) Open the document cover and place your original face-down on the glass, in the upper left corner. Move your original about 1/10 inch away from the top and left edges so all of it will be copied. 2) Close the cover gently so you don't move the original . Caution : Never open the document beyond where it stops and do not place heavy objects on top of the CX4600. If you need to copy or scan a thick or large document, you can remove the document cover. Just open it and pull it straight up. If you need to press the document flat while you copy or scan it, do not press too hard and be careful not to move it. Caution : Do not use excessive force on the document cover, and do not twist it diagonally. You may damage the document cover. When you are done, replace the document cover by inserting the tabs back into the slots. Copying a document. 1) Load paper. 2) Press copy button until you see the desired number of copiesin the Copy window You can select up to 9 copies at a time. 3) Press the paper type button to select PLain Paper. The light indicates which type is selected. 4) Press the paper size button to select Letter. 5) If you want your copies automatically reduced or enlarged to fit the loaded paper size, press the Fit to Page button. 6) To make color copy, press the Start Color button To make black and white copy, press Start B&W button. The ON light flashes and after a moment the CX4600 starts printing. If you need to stop copying at any time, just press the Stop button. Do no pull out paper that is printing, it will eject automatically to the output tray. Hope this helps. Please rate my response. Thanks Have a good day.
Nov 25, 2009 | Epson Stylus CX4600 All-In-One InkJet...
Vertical line appears in scans using the ADF, but not with copies
happened to me after i fed a page with not-too-hard whiteout on it. the feeder makes the page run through a different piece of glass and i just had to clean it.
Aug 18, 2009 | Brother MFC 7840W Printer
When faxing does paper face uup or down
You load the originals print side uo on the document feeder tray or print side down on the glass.
To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
The position of the paper is the same either you copy, fax or scan.
All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
Faxing
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
Apr 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
ADF has something on it causing a stripe on all copies
Lift the document feeder and clean the narrow glass, (next to the glass where you place your originals). Documents are scanned across this glass when automatic feeder is used, thus a small piece of dirt becomes a line down the page.
Feb 24, 2009 | Canon ImageClass D880 Copier
HP 7410 streaks when using auto document feeder to make copies
the document feeder of that unit have its own scanner glass. try opening the document feeder and clean the scanner glass with a lint free cloth that is moist with water and also clean the rollers of the document feeder
Aug 13, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Lines on copys when i feed through top feeder
There is a small strip of glass under the feeder.Not the main glass, but look where the lamp is sittting in the start position.
You have something on that section of glass.
It may be very tiny, but that is what causes that. Best way I have found to get that clean is with some alcohol and just a plain piece of copy paper crumpled and used as your cleaning towel.
The reason it is there only when you copy through the feeder is this. When you copy off the glass, the lamp moves and scans the original end to end. So a spot is simply a spot.
When you run through the feeder, the lamp parks and the document passes over the lamp scanning that way. So any mark between the lamp and document will repeat and be line down the page.
Mar 28, 2008 | Sharp AL-1642CS Copier
HP OfficeJet 7410 All-In-One InkJet Printer Logo
1,190 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
