Question about LG LFD790 System
HD-DVD Can I play HD-DVD's on this system?
  • CMeadows Jan 27, 2008
    Thanks!
  • daniels06200 Aug 19, 2008
    I can play CD's in my LG FLD70 home theater but i can't watch DVD's
    it says that it's an incorrect region code.
    What can i do?
No. It will play regular DVD's and try to upconvert them to a better quality, but it will not play true HD-DVD's.
Posted on Jan 25, 2008
It does not play in color but otherwise plays well
it may be connectet in HD. in HD for viedo three pins are connected so check the coulour in dvd and tv and connect it to the same colour
Apr 25, 2011 | kawasaki 5-DVD Home Theater System - 1152...
Playing movies through usb port?
The options when you play a DVD it will appear when you are connecting ext HD it will not work.
Better you need the play in a DVD Disc to get the good sound.
Jan 06, 2009 | Philips HTS3440/37 System
Wharfedale DS-A243 HDMI Upscaler wont play HD DVD
Hi, sorry to have break it to you but your self diagnosis was correct! It is a 'normal' DVD player that upscales and will NOT play HD discs.
Nov 12, 2008 | Wharfedale DVD-M3 DVD Player
Hd dvd
As a general rule, Blu-ray and HD do not mix, unless you have a dual format player. That said, I will assume that you are using AT Least one of these newer format players. A standard player will not play either of the higher definition format discs...accordianman
Mar 05, 2008 | Audio Players & Recorders
Dvd player, hd dvd movies
If this is just a regular DVD player, then no. You need an HD DVD player to play HD DVD discs. Now the HD DVD players should play regular DVD discs.
Feb 12, 2008 | LG DR787T DVD Recorder
Im unable to play HD DVD on my philips HTS8100 home theatre system
As far as I can see your philips dvd player is not a HD-DVD player.
It just upscales standard dvd or digital content to HD ready televisions.
Jan 14, 2008 | Televison & Video
Hi-def dvd
This is not a High Definition DVD player, it does upscale a regular DVD to HD resolution, but that's just an electronic trick.
Also, Toshiba has abandoned the HD-DVD standard (did you find the discs on sale?), you'd need to find a BluRay player (like the Playstation 3) to play high definition DVD's.
Dec 05, 2007 | Samsung HT-Q100 System
Hdmi
Its not designed to play HD DVDs, the model has HDMI connection in order to connect to latest output devices, viz flats panels and LCD tvs there by having a common audio and video cable. your model has a feature to upscale the normal DVD singal to match the quality output of hull HD TVs, hence the HDMI out put, do not confuse this with HD compatiability.
Go to the link below to check the full specs of your system.
http://www.consumer.philips.com/consumer/en/in/consumer/cc/_productid_HTS9800W_55_IN_CONSUMER/DVD-SACD-Home-Theater-System+HTS9800W-55
though yours is a high end set, but its not HD disc compatiable.
Regards
Benam
Nov 14, 2007 | Philips Cineos HTS9800W System
Hp hd dvd player for desktop wont play hd dvds
I had this problem. Turned out that I was using a DVI cable to connect my monitor to the video card, but my monitor was not HDCP compliant. Most HD-DVD's require the monitor to be HDCP compliant for digital output (i.e. over DVI or HDMI connections). Alternately, you can connect to your monitor via its analog (VGA) input instead, but you won't get HD output. I was able to do this using a VGA cable along with the VGA-DVI adapter for the video card output.
Cyberlink has a tool you can run to see if your system is capable of HD-DVD output. http://www.cyberlink.com/multi/support/bdhd_support/diagnosis.jsp
When I ran it, it gave me a red flag telling me my monitor was not HDCP compliant
Aug 05, 2007 | Pioneer VSX-D511 Receiver
LG LFD790 System Logo
43 people viewed this question
Top LG Audio Players & Recorders Experts
Marvin
Marvin
jairo sanchez
Are you a LG Audio Player and Recorder Expert? Answer questions, earn points and help others
