Question about Symphonic ST419E TV
TV Picture Reduced to Line across the Middle
At first the picture was as if across the top of the picture had been folded down over itself - about 3 inches.
Now it is just a thin line of light across the center of the screen. Does it need a little tube, a huge tube or what? Is it worth having someone repair it?
Could I repair it myself, or should I take it to the dumpster? Thanks,
  • 3 more comments
  • pdmm Jan 16, 2008
    same problem...screen folded down over self ..now today just a line through the middle
  • Marcie007 Jan 21, 2008
    Thanks, What are the chances you have access to schematics that could direct me on what is and where it is? I am no electrician, but am mechanically inclinded. My dad doesn't want me to go into the TV, he says even when it is unplugged, there is power stored up in the components, that could blow up on me. Your thoughts?
    Wow, thanks for all the info.....tell me, in AZ, what do you think would be a fair price to fix it....ball park?
    I posted my response in the wrong place, it sounds like I need to go to a repair person. I am not too old to be warned. In AZ, how much do you think it would cost, ball park?
  • Marcie007 Jan 23, 2008
    Wow, had no idea I was talking to South Africa.......guess I thought the world was USA, hehe.
    Thanks so much. I will let you know what happens, cause I know you are holding your breath!
    Scholar:
  • 57 Answers
This is called field-collapse. Either
1. The problem lies in the vertical deflection voltage-doubler circuit. The usual fault is a single capacitor of 100uF/35V that has failed. It is normally connected to a rectifier diode right at the vertical IC. Replacing the capacitor usually gets it working perfectly again.
or
2. The vertical drive IC has failed.
If you are finicky around technical work, then a reputable local repair shop in your locality should do it quickly for you and charge only labour.
Posted on Jan 21, 2008
  • Rio de Loca
    Rio de Loca Jan 21, 2008
    Sadly, free schematics are generally hard to come by. One normally pays around $14.99 for each. However, there are a few sites that you might want to try, e.g.
    http://www.filekeeper.org/download/brows...
    or
    http://www.orbit-el.net/tehnicka_podrska...
    One nice little trick is to open up the TV, identify the vertical IC (its the one somewhere around the middle of the board), read off the number and tell it to me. Then I can look in my own archives for any circuit using the particular part. You'll be surprised by how many TV circuits are actually "ORIGINAL". Mostly they are "kindly borrowed". This commonality provides a trick that makes it easy to fix in the absence of proper schematics.
    Your Dad is right, of course. The tube itself is a small but almost perfect capacitor. It charges up with high-tension (+40000Volts) that it retains for years. With some care, it can be discharged instantly to render it harmless. The mains capacitor is another such, though it deliberately has largish resistors called bleeders to drain away the charge when the unit is not in use.
    I would suggest extreme caution if you intend to partake in TV repairs. Talk nicely to the local repair chaps and they just might make an apprentice out of you. That's actually how I did some learning, aged 8! Good luck, friend.
  • Rio de Loca
    Rio de Loca Jan 22, 2008
    I don't know about in AZ, but here in ZA (South Africa, cute!) I normally charge the equivalent of US$40 - that's about ZA Rand 300.00; this price is mostly just labour since no major replacements are done. So it's worth having it fixed.
Horizonal line across middle of screen top half of picture perfect bottom half has small lines in picture hitachi hd S 69 plasma
I'm not sure if this model is the one that has resistors that go bad. You can actually purchase a pack of resistors in a kit. It will come with solder, the resistors and instructions. You can lay the tv out and take the circuit board out to find the blown components, and replace the bad ones. Takes about an hour start to finish and will cost around $65.00. It has been a few years since I did this, so I'm not sure on the price.
Apr 04, 2015 | Hitachi UltraVision 55HDS69 55 in. Plasma...
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
27'' lxi reduced picture
This is a problem with the vertical circuit and can be as simple as poor solder connections within that circuit or defective parts. If you have no experience with soldering or TVs, this should go to a service shop. Expect a parts cost in the $30-$40 range for and IC +/or capacitors. If you'd like to attempt this yourself, please supply the exact make and model so I can post the parts required along with additional instructions. Please note that TVs contain potentially dangerous high voltages even when unplugged.
Thanks,
Dan
Mar 15, 2010 | Televison & Video
Turned on my TV today to find a 5" horizontal stripe across the middle of my screen. I can view the picture through the stripe but the picture brightness on the top 1/3 and bottom 1/3 of the screen is much...
This sounds like an impact injury to the screen itself. It is likely that something may have hit the screen or if the set is old, the part inside may be starting to go.
Hope this helps
Nov 27, 2009 | Sylvania LC320SS8 32 in. LCD Television
The Picture on my Mitsubishi vs-60805 "shrank" then disappeared
it isnt worth it, your verticle diflection is out, that board is about 3-4 hundred, and you would probabily need a service center do it(messing with like 30000 volts)and they will probabily charge around 200
Jan 07, 2009 | Mitsubishi VS-6041 60" Rear Projection...
Picture reduced to 1/4 on a black screen
Picture is reduced to a straight horizontal line across the center of the screen.
Aug 17, 2008 | Televison & Video
PT-51G44
Some of the components in the vertical deflection circuit area, and possibly in some other areas as well, have become thermo sensitive with age and use.
An experienced TV tech can troubleshoot the set to locate the defective parts and change them.
Jerry G.
May 08, 2008 | Panasonic PT-51G44 51" Rear Projection...
Picture size is shrinking within screen
hi there, you have vertical section prob., repalce imeditely the electrolytic capacitor at the vertical section. do some test and check up. ty
Feb 18, 2008 | Philips 27MT3305 27" TV
55IN TV.
1. VERTICAL ROLLING, VERTICAL BLANKING BAR LOCKING IN THE MIDDLE OF THE PICTURE, ALSO MAY HAVE HORIZONTAL PULLING OR TEARING. CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01
Oct 31, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Symphonic ST419E TV Logo
245 people viewed this question
Top Symphonic Televison & Video Experts
SHARCNET-USA
SHARCNET-USA
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
