Question about Microsoft Xbox 360 Console
Xbox 360 help
The system makes a sqealing noise while you play
  • 121 Answers
If its a really loud squeal you should probably call xbox customer support 1-800-4myxbox
if it is just a minor noise that seem irregular its probably nothing its happend to me to and goes away
Posted on Jan 13, 2008
1998 fxsc slowing down in any gear makes ascreaching sqealing sound . stops when you pull in the clutch
Hi Anonymous, I'm sorry but I just loaned my listening ears to the lead technician at your local Harley Dealer so he could take your bike for a test ride and evaluate the noise. Good luck and have a nice day.
Mar 12, 2013 | Cars & Trucks
Enviracaire filter system makes squealing noise when blower fan for funace kicks on
Sounds like you are on the right track, the machine is starving for air. Remove filter and test in auto. If no noise then either you still have a "bad seal" somewhere or the filter is simply to think or restrictive. I can't ask you to test the static pressure but that would be a sure test on what is going on. Good Luck!!
Apr 04, 2017 | Honeywell Heating & Cooling
Steering making noise when turning steering wheel on ford focus
what kind of noise a loud squel noise or a poping noise
is sqeal check your fluid if fluid ok then the **** needs replaced
Aug 10, 2011 | Ford Focus Cars & Trucks
1998 mercury villager van , power steering belt was sqealing, so I replaced all three and it still sqeals and its still the power steering belt thats sqealing. I tried tightening it and that made the belt...
CHECK ALL THE PULLEYS WITH BELT OFF TO SEE IF ANY HAVE PLAY IN BEARINGS
OR ARE CONTAMINATED FROM PREVIOUS BELTS SLIPPING MAKE SURE THEY ALL ROTATE FREELY WITH NO SOUND
May 17, 2011 | 1998 Mercury Villager
Fluid leak and a sqealing noise when turning steering wheel,topped up with fluid and sqealing noise goes away?? but has returned and fluid level seems to be holding.
look to see if the pulley is coming off the pump and belt is going astray not lining up. also may have air in system jack front end up engine off and turn lock to lock with pump cap off look for air in pump may need assistint to look .
Aug 10, 2010 | 2005 Ford Focus
How to adjust belt sqealing problems?
If this vehicle has one serpentine belt chances are the belt must be replaced, look to see if there are visible cracks on the contact surface of the belt if so replace the belt if not then there may be a component in the pulley system that is starting to seize, the squeal is the pulley wheel offering more resistance at certain times therebye causing the noise, with the belt off try turning each pulley to see if binding is occuring, also check each pully wheel for loosness or play the bearing may be worn if play is detected.
Dec 07, 2009 | 1996 Mazda MPV
WIL NOT TURN ON AND IS MAKING A SQEALING NOISE WHEN I PLUG IT IN
need the model number, as squealing for rear projection is different that sqealing in a DLP televison
Oct 30, 2009 | Televison & Video
High pitch sqealing noise
This is caused be a bad record switch. As a temporary solution, incert a blank tape, push the record switch, then stop. Repeat about 10 times. This may clean the contacts of the record/Play switch but it will probably need to be replaced.
May 20, 2008 | Panasonic RR-830 Desktop Cassette...
RCA D52W19 - High Picth sqealing noise
Thats usually a sign of the flyback or HV Splitter nearing the end of their operational lifespan. However its not an exspensive fix unless done ay a repair shop then it can be a few hundred.
Apr 21, 2008 | RCA D52W19 52" Rear Projection Television
Microsoft Xbox 360 Console Logo
52 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
