no the factory is a am fm cd player and aftermarket is a sony explod... i know i would have to get a install kit and a wiring harness for the stereo. im just not sure how to take the dash apart to remove the factory radio so that i can install the sony. i have installed aftermarket stereos before just not in something so new.no the factory is a am fm cd player and aftermarket is a sony explod... i know i would have to get a install kit and a wiring harness for the stereo. im just not sure how to take the dash apart to remove the factory radio so that i can install the sony. i have installed aftermarket stereos before just not in something so new.
Since you have done this numerous times, so you know the installation process. It seems there's something wrong with the aftermarket CD player, try replacing it with another one.
This generation of Vibe may have the upgraded audio system installed from the factory. In order to get the audio from an aftermarket radio to play through the factory amp, the factory remote turn-on lead must be located. If you are using an adapter harness, it may have the wire installed, just attach the blue/white stripe wire from the Alpine to the blue or blue/white stripe wire on the aftermarket harness adapter.
Had the same problem with my 2004. Replaced the stock radio with a aftermarket pioneer unit. If you replace it make sure you by the aftermarket harness so it will plug right in and all your chimes will work.
you will need to unscrew your dash and pull off the front plate of your dash, then you will need to unscrew the stock radio, then you will need to go ahead and pull out the adapter from the back of your radio. Next you will need to attach your adapter harness to your car harness and splice the color coded wires to the harness on your new cd player.After that, you will need to plug your antenna back into your new cd player, Note that some cd players will require an adapter, these can be found at circuit city or at your local car dealerships.-Shocker
Is the aftermarket radio the same size as the original?
