Hard Drives
Problem for Hard Drives
Generic problem for all Hard Drives
Trying to boot from a hd from my old comp
By Burst1n on Jan 13, 2008
My old comp's motherboard died, so i got a new comp that didn't have a hd from my friend. I installed the hd from my old comp in the new one but it won't boot the OS nor does it give me an error msg to let me know what's wrong.
My old comp was an hp 545x and my new one is a Dell Dimension 4600.
Comments:
Jan 13, 2008
- Thanks alot I've reinstalled XP and everything is fine now
Same Problem
Jan 09, 2009
-   I need to reboot the hard drive. Because in hard security pop-up at all time.
Now i got new motherbard. I need to reboot it and try to make it work with the new motherbard.
-   xiongj85
Best Solution
posted on Jan 13, 2008
Helpful)
Benimur
Rank: Guru
Rating: 88%, 3802 votes
MS Windows XP when installed to an HD will "marry" itself to the hardware of the original computer specifically the motherboard. Transplanting the HD to another PC with a different motherboard will result in a cycling blue screen of death or protective message requiring that you reboot. Running in Safe Mode will not also be allowed.
You need to re-install your OS (boot from CD) but choose the 2nd repair option rather than a new/clean install or the first repair option if you want to preserve your other applications as well as your settings/configuration. Doing this will allow the OS to install the new device drivers and delete the old ones.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
God luck and kind regards.
Comments:
Jan 14, 2008
- Hi again,
Am glad that your PC is fine again.
Cheers.
Was this helpful?
Yes
No
Popular Solutions for Hard Drives
Questions and Unsolved Problems for Hard Drives
Answer
my USB is not getting detected and I am getting the following error message ''Windows failed to... (More)
Answer
I have a laptop PC 64-bit and I hooked my passport elite up to my computer and it wont let me back... (More)
Answer
problem with size indicated and actual available. When I saw that windows explorer said I had over... (More)
Answer
The drive worked ok then suddenly my main storage folder shows empty. But the drive still shows the... (More)
Answer
i restarted my toshiba com to if it was new i cant find anything now need my e mail back
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Hard Drives Experts
Top Computer & Laptop Repairmen
in San Mateo, CA
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
