Question about Whirlpool 24 in. GU2548XTP Built-in Dishwasher
Quit working Had nothing but problems with this LEMON of a dishwasher. My new problem is that it quit working while running a cycle. It quit with water in the bottom.
  • 90 Answers
Make sure you are getting power to the board, if so check fuse on control board.
Posted on Jan 13, 2008
6ya staff
SOURCE:
Kitchenaid dishwasher wont stay closed
you might need a new Latch, Drawer (left Hand) part number 8194053 okay
Feb 07, 2013 | KitchenAid 23 in. KUDD01DPPA Stainless...
The start button on my KItchen Aid Built in Dishwasher KUDI01FLSS2 will not start, there is power and the control lock is not on. It just will not start
I had the same problem although my dishwasher quit working in mid cycle. Once it quit, there was no power to the unit. I replaced the thermal coupling fuse and that solved the problem.
Dec 27, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
AS PER DIRECTIONS FROM TECH, I PURCHASED AND INSTALLED A NEW CONTROL UNIT. THIS WAS BECAUSE MY WHIRLPOOL DISHWASHER GOLD GU2300XTLB3 QUIT WORKING IN ALL CYCLES EXCEPT SHORT CYCLE. PUT EVERYTHING BACK...
This is a common problem with Whirlpool washers.If the clean light is the one flashing then your dishwasher could have a heater circuit problem (depending on the age) or this could simply just be water colder than it is used to getting.
Repeatedly press the Heated Dry and Hi-Temp Wash(scrub) which ever yours has until all the LED lights come on, press cancel twice and try the dishwasher again making sure to run the water at the kitchen sink till it is hot before starting the dishwasher, if this trips and locks you have a problem with the heating element, or temp sensor.
Press the heated dry button followed by the normal cycle button, and then repeat once. You should see all of the lights come on for a second or two, and then the dishwasher will work again.
If you haven't already, take a look under the kick plate in front to see if there is a schematic tucked in there somewhere. Whirlpool has put their diagnostics for specific models on these.
I don't have the specific repair manual for you model.
So, if the above combination does not work here are two more that have worked for me.
HiTemp Wash + Air Dry + HiTemp Wash + Air Dry in less than 5 sec
or
Hi Temp Scrub/Scour + Air Dry + Hi Temp Scrub/Scour + Air Dry in less than 5 sec
Let me know, if you need further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 01, 2010 | Dishwashers
I can't select a cycle. The buttons quit working.
it sounds like the touchpad is gone,phone the manufacture and see how much it will cost ,and then take it from there
Mar 30, 2010 | Maytag 24 in. MDB7601AWS Stainless Steel...
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
May 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher quit during cycle.
Need a little more info.. anyway.. open dr will shut off dw...close dr.. push power button until power on... lights on, but nothing happen.. try holding down drain and one of wash cycle.. repeat holding drain w/other buttons until you hear drain pump running.. make sure you hold both buttons for a few seconds.. if your drain pump works.. then, you might have a problem w/your wash motor or something is stuck in the impeller area.
Jan 13, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Won't quit running
Try the timer - I had a Kenmore that did the got stuck in the rinse cycle and it ended up being a bad timer.
Oct 08, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
"Lock on" light keeps flashing - cannot run dishwasher
same issue..
Other boards suggested heating element issue - but nothing very clear or compelte.
Aug 10, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Viking dishwasher quit working
Possible bad door switch, thermostat or timer issue, call for service, make sure the tech. knows how to fix Asko dishwashers as that is what is in on the inside. Be sure that you are getting power to the unit.
Jul 16, 2008 | Viking 24 in. Professional Series VUD040...
Whirlpool 24 in. GU2548XTP Built-in Dishwasher Logo
66 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Bruce Denton
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
