Question about Eclipse EA3422 Car Audio Amplifier
Eclipse 2.13oe camtec
The amp over heated and red light went on . looked at all fuses a ok . But amp still dosnt work is it cooked ?
  • 631 Answers
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up, the wiring needs to be checked. If it still shuts down, the amp likely has blown output transistors.
Posted on Jan 13, 2008
Rockwood amp 5556 car audio amplifier no sound
Check an make sure your fuse is tight the one coming off the battery for your amp if that dosnt work try grounding your amp to the battery to make sure the ground is good
Nov 08, 2012 | Rockwood AMP-5554 Car Audio Amplifier
I currently own a CFMT148GPB2 Frigidaire Pro Series Microwave/fan. It stopped working instantly i.e. was cooking vegetable, it went to the end of its cooking cycle...then 2 minutes later I re-openned the...
I would think the main fuse may have gotten hot due to a bad fuse holder. If the fuse holder gets old and doesn't grab the fuse tightly it is an opposition to current flow, which is a resistance, and any resistance will produce heat, heat will make a fuse melt in its end and go bad. So, either that or something else just shorted out and blew the fuse inside. Need to call a technician. But the fact it finished its cycle then was dead when you went back makes me think the overheated fuse thing.
Aug 23, 2017 | Microwave Ovens
I have a 98 eclipse. I was putting new tail lights on and then the signals stopped working along with the brake lights. the fuse to the brake lights had burnt so I replaced it. The signals however are...
Jan 24, 2011 | 1998 Mitsubishi Eclipse
Stove top want heat up
the bulb i am sure is ok . but you have had a power failure to the burner . it could be the burner itself . if all the burners do not work the power to the range may be the problem .. ck the main fuse and make sure the 220 power is ok mm
Jul 12, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
I have a Mitsubishi Eclipse 2000 Gt. I recently been having problems with the right headlight. I thought it it went out. So i went to auto zone and bought a new bulb. But it still won't turn on. So i tried...
Did you check the socket that bulb plugs into.I hav seen where they melt for, the hat produced by the bulb.If that isnt the issue,I would suspect the headlight switch.But first stick to basics.Check all the fuses.
Dec 12, 2009 | 2000 Mitsubishi Eclipse GT
Our oven would not heat,everything appeared normal lights worked fan worked timer worked tried again on cook 3 closed door and lights went out and we have nothing,I have 120 volts at plug.
Check the voltage at the primary winding of the highvoltage transformer. If it is 120 volt.then controll board part is. Now check the magnetron and related components. If the fuse and the diode are ok replace the magnetron
Jul 14, 2009 | GE Spacemaker JVM1740 Microwave Oven
2004 Mitsubishi Eclipse-no heat?
check thermostat and water pump.the water pump could be working good enough to ke the engine cool but dosnt have the pressure to push it thru. i ran in to this prob be for no heat and the engine didnt over heat. the antifreeze ate the blades off the water pump. it was crazy.
Dec 23, 2008 | 2002 Mitsubishi Eclipse
Faulty hp en623aa flat screen monitor
my desk top is half display is ok and half display is white light & all program is look a lite
Jul 24, 2008 | Xerox XG-91D 19" LCD Monitor
Eclipse EA3422 Car Audio Amplifier Logo
73 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
