Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Printing out of order
Everytime we print the pages are printed out of order. How can we correct this so the pages are in numerical order?
    Brigadier General:
  • 6,966 Answers
A couple of things you can try:
1. If you are using MS Word, try to check (or uncheck) "Collate" when you click on the File/Print command;
2. In your printer Properties/Setup/Configuration, see if you have Options or Extra settings where you can change the Output Options (Normal, Reverse All Pages, Print Odd Pages, Print Even Pages). Determine which will work to your preference.
Hope this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 13, 2008
6ya staff
SOURCE:
How do i get my printer to print last page first
Any special reason? They will always print in the right order, so you can read in correct order. You organice your printing on Page set-up.
Jul 24, 2014 | Epson Workforce Pro Wp-4530 All-in-one...
Occasionaly labels are not printing in the correct order
This is not a printer related issue. The printer prints exactly what it is told to do, and in the order received. If the data coming to the printer is out of order, the printer cannot correct it because it doesn't know that it is out of order.
If you have a way to pause and/or prioritize the data that you're spooling, you may be able to provide a flow of the data that prevents the printer from printing out of order.
Oct 19, 2012 | Monarch Paxar? 9855 Label Printer
How do i switch of align page when installing a new cartridge as it waste paper printing a test page everytime you switch it on. This is for a HP 1300 series
http://h20000.www2.hp.com/bizsupport/TechSupport/SupportTaskIndex.jsp?lang=en&cc=us&prodTypeId=18972&prodSeriesId=238320&taskId=110
Click on the 'Automatically check to see if your driver needs updating (MS Windows Only).' box in order to check for latest updates to your driver.
Unfortunately, I looked over the unexpected page output and it didn't list this problem as one of them.
Does it really print a test page every time you switch it on? Or does it only print a test page after installing a new cartridge?
Definitely, the alignment page should be printed everytime a new cartridge is installed due to variations in manufacturing of print cartridges will throw off the alignment everytime a new cartridge is installed.
I'm not sure about the test page, though.
Good luck on this modification of standard operating of hp printers.
Jan 17, 2011 | HP LaserJet 1300 Printer
The top quarter of page does not print clearly. The print is faded on just the top 1/4 of the page. The rest of the page prints correct.
If you print out a list print on this copier is it the same? If not then it is somewhere in the optics, try cleaning the mirrors under the scanner glass with rubbing alcohol. If it is the same when printing it could be a drum or numerous other things.
Aug 07, 2010 | Toshiba e-Studio 350 Copier
Prints only blank pages
I have a brother MFC 3240C. My Black ink stopped printing(initially printed horizontal faded lines and gradually got worse), the other colors were printing fine. I tried cleaning numerous time( 50 -100 times over 1-2 weeks ). Still no improvement. The way I print now is:
1. I go to Printer Properties
2. Change Media type from "Plain Paper" to "Inkjet Paper".
3. Change Quality to "Photo".
This takes a long time to print 1-2 minutes per page. However, this works for me since this is my Home printer and use it for printing only few pages here are there.
Good Luck
RK
Jan 06, 2010 | Brother HL-2040 Laser Printer
HP officejet 9130 printer: pages keep printing
Yopu can change the rprinting order from the Print Dialogue box or Printer driver.
Look for the following to change page grouping when printed
and the followintg to change printing from first to last and last to first pages
Nov 13, 2009 | HP OfficeJet 9130 All-In-One Thermal...
With out printing numeres paper keeps coming out of port and stating paper jam
Try the Following Steps
1. Turn On the All-in-one unit
2. Disconnect the USB cable from the unit
3. Press and Hold OK and Cancel button on the unit while plugging in the power cord
4. This will perform a NVM reset
Once you have done this try Printing a self test page from the unit (Steps given below)
1. Press Setup button on the unit
2. Scroll to the option Print Reports
3. Select Print self test report
4. Check if it prints correctly.
May 17, 2009 | HP Officejet 5610 All-In-One InkJet...
Unexpected size in tray 2
whenever i took printout of a multipage file of Powerpoint. Everytime i have to preses the ok button to proceed with the print. because every page an eror comes displaying on screen of printer "UNEXPECTED SIZE IN TRAY 2" when i press the OK button it start printing the page. everytime i have to press the ok button to take print out. For example if i give a print command to a file that is having 15 pages. i have to press 14 times the ok button to complete the printing of 15 pages. pls help me in this
May 14, 2009 | HP LaserJet 2840 Printer
Hp6310 officejet all in one
here is solution..
Solution Step one: Make sure that the product prints correctly
  1. Print a self-test page from the product control panel, from Windows, or from the product software. (See the product user guide, available online, for instructions to print a self-test page.)
  2. Check to make sure that black and all colors (if using a color product) print on the self-test page.
    • If the self-test page does not print correctly, an issue might exist with the product hardware. See the product user guide, available online, for further troubleshooting steps.
    • If the self-test page prints correctly, continue with the next step.
Step two: Determine what portion of the page is set to print Many Web pages use frames. Frames divide the screen into multiple windows. Follow these steps to determine what portion of the page is set to print.
  1. Click the Internet Explorer icon on the desktop. The Internet Explorer window opens.
  2. On the File menu, click Print . The Print dialog box opens.
  3. Click the Options tab to view the print settings.
  4. Change the settings if required, and then click Print .
Step three: Change the Encoding setting in the Web browser
  2. On the Menu bar, click View .
  3. Click Encoding to view a list of encoding options.
  4. Check the Encoding settings.
    • If Auto Select has a check mark next to it, click to clear the check box.
    • If Western European Windows does not have a check mark next to it, select it.
Try printing again. If the issue continues, proceed to the next step. Step four: Check the page setup settings for the Web browser Web pages are designed to be viewed at a certain screen resolution. If the resolution of the screen is lower than the resolution of the Web page, the whole screen might not display or might not be printed.
  1. Make sure that Internet Explorer is open.
  2. On the File menu, click Page Setup . The Page Setup dialog box opens.
  3. Review the Margins information.
  4. Make sure that the margin settings are greater than or equal to the minimum printable region margins for the product. The margins vary slightly among HP All-in-One products. As a general rule, the settings should be at least the values shown in the following table. Side Margin Top Margin Bottom Margin 6.3 mm (0.25 inch) 6.3 mm (0.25 inch) 6.3 mm (0.25 inch)
  5. Make necessary changes to the margin settings.
  6. Click OK to save the changes.
Try printing again. If the issue continues, proceed to the next step. Step five: Print using Smart Web printing software HP Smart Web Printing is fast, free, downloadable software that enhances how Microsoft Internet Explorer and Mozilla Firefox print Web pages. Use HP Smart Web Printing for the following tasks:
  • Select text and graphics from any Web site
  • Save paper by combining portions of numerous Web pages
  • Preview and modify clips before printing
Thank you.......
Jan 29, 2009 | HP Officejet 6310 All-In-One InkJet...
I need to change printing pages from last to first page first
the last printed page is always on top. For a long document, it takes a while to resort and place the first page first! This is how you can get Microsoft Word to reverse the print order and save all the trouble.
I have spent so much time resorting documents after printing. On my printer, the last page printed is always on top. By printing the last page first (reverse order), the document is already correctly sorted.
Here is how to do it:
1. Open Microsoft Word
2. Open the document to be printed
3. Click the Tools menu
4. Select Options
5. Click the Print tab
6. Check the Reverse Print Order option
7. Select OK
Now, all your documents will prevent in reverse order. What a lifesaver!!!
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 30, 2008 | Lexmark Office Equipment & Supplies
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
87 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
