Hello. Your tv has one audio output jack on the back. 1 x audio line-out ( RCA phono x 2 ). Go to any Radio Shack, tell them what you have [RCA phono x2] so they sell you the correct headphones.
Unfortunately, you can't connect Bluetooth speakers to this TV. You can connect a wired sound bar, home theater sound system (receiver and speakers) or wireless headphones with a wired based station (RCA or digital audio input from the TV's audio out). These wireless systems use RF or Bluetooth signals to the headphones. See this page, http://stereodevelopment.com/#what-are-wireless-tv-headphones , for a few models of wireless headphones that will be compatible with the D43-D1.
I wish that I had better news for you. You may be able to find an audio receiver that supports Bluetooth. However, these usually are Bluetooth devices, the same as the Bluetooth headphones. They can't pair and send a signal to your headphones.
Yup. If the headphones are driven by the TV, then turning down the TV turns down the headphones. Check to see if the TV has an audio output setting where you can select either the TV speakers or the headphone jack. What brand and model TV is it?
Normally the wireless headphones have a transmitter that send audio via wireless to the wireless headphones. The transmitter needs to be plugged into the headphone outlet on the TV. This will switch off the speakers on the TV and sends the audio to the wireless headphones.
From the initial details of your problem it is unclear what equipment you have connected and what you are trying to listen to with your headphones.
Please describe exactly what piece of equipment your headphones are plugged in to. If it is a TV or a stereo system, please provide the model number for it.
If you are using wireless headphones plugged directly into your TV, please provide the model number of the headphone and for the TV and whether you are plugged into the EARPHONE jack, or the LEFT and RIGHT AUDIO OUT jacks.
If you are trying to listen to your TV audio through a home stereo amplifier, then please describe what type of cables you are using to connect the TV or set top box to the stereo (HDMI, RCA stereo, etc).
When you say that you 'CLICK TV TO STOP SOUND', do you mean that you are pushing the MUTE button on your TV's remote control?
Normally, pushing the TV's MUTE button will turn off the sound for both the TV's speakers and for the headphone output.
It is usually possible to shut off just the TV's speakers and leave the headphone volume active but in most cases this must be done through the TV's AUDIO OPTIONS MENU. For most TV's there is usually an option there to TURN TV SPEAKERS OFF.
Please comment back here to this page and provide as many additional details about your current setup and how you normally use your heaphones and I will respond as soon as I see it with any additional assistance necessary.
Most TVs these days do not come with headphone out jacks. If your TV has RCA audio out, you can get a RCA to Headphone jack.
If your TV has no audio outputs at all, you're out of luck.
If your TV is equipped with audio out, there will be an option in the speaker or sound menu of your tv to turn off internal speakers and transmit directly to external speakers. If there is no audio out on your tv, this will not be an option.
Changing the Audio Output
To switch audio output from the internal TV speakers to a connected external sound system or headphones:
Press 1. MORE.
Press 2. 9 (AUDIO).
Press 3. until the Speakers option is displayed. The Speakers option will display only if an A/V receiver connection has been detected.
Press 4. to switch between TV and either AV Receiver or Headphones.
Check if the MUTE key is on.
• The TV's "Listen to:" setting may be set to SAP (analog program from the ANT input) but no SAP is being broadcast.
• Check that the Speakers option is set to TV to hear sound from the TV speakers. Possibly sound is being sent to one of the audio outputs for an A/V receiver or headphones.
• If using an A/V receiver, check that the Speakers option is set to AV Receiver to hear sound from the A/V receiver speakers.
• Press and hold the POWER button on the control panel for 10 seconds to perform System Reset.
This model doesn't have a headphone jack. The only JVC TV in the series that does is the model AV-20D202. For the JVC AV-2732, use the RCA audio out jacks with an RCA to 3.5 mm adapter to connect to the headphones. The front audio jacks are audio in (for the audio from a video camera for example).
When you use any external speakers or headphones through the audio out jacks, make sure to turn off the TV speakers. Press Menu and navigate down to TV Speakers (up/down arrows). Then use the right/left arrows to select Off and then Exit the menu. Make sure you scroll the TV volume before doing this. Note: if your headphones do not have a volume control they are a bad choice for this type of audio output.
With this TV, you can turn the TV speakers off with the remote. This will not turn off the headphone output port.
Press menu, go to AUDIO, then go to TV speakers. You have the option to turn the speaker OFF there.
The speakers should have turn OFF automatically when you plug the headset into the headphone port. But, going over the manual for this TV; the option is to turn the speakers off manually with the remote.
