Question about Lexmark X5150 All-In-One InkJet Printer
Blank printout my printer is not printing; the paper goes threw the process moving threw the machines; but the paper comes out blank the machine was reading ink cartrige problem earler but the reading disappeared. but im getting no printout on paper
  • 1 more comment
  • kokopelli55 Feb 28, 2008
    I am having the exact same problem. Has anyone found a resolution? I've re-installed the software from a download (no disc) several times, restarted computer, checked cables and power, etc. Everything seems to be working fine...just no ink on paper.
  • nobrepereira Mar 15, 2008
    So far I had no problems using the black ink cartridge for printing (Lexmark 17) . A few days the paper came out blank.I saw from the Utility Set Up that the cartridge was empty.So I refilled it from my kit ,installed it but I always get the message " Right cartridge not installed".I had already refilled some months ago without any problems.Last time I used the printer was on 28th Feb. and I had a perfect print job.
    Thanks for the help you can provide to solve my problem!
  • Mirza Aminul islam Oct 26, 2012
    My printer Epson Stylus R230 blank printout. My printer is not printing; the paper goes threw the process moving threw the machines; but the paper comes out blank the machine was reading ink cartrige properway. but im getting no printout on paper. Aminul Bangladesh
  • 64 Answers
If you are able to drag out your users manual, most lazer printers have a self cleaning process for the head, which takes around 3-5 minutes to complete, after that try to run a test page to ensure the colors are working fine.
Failing that, unless the printer is brand new, and or unless it has been sitting ( unused - regardless of age ) the print heads can dry out leaving a blockage ... hence, no ink, hence blank page.
The only other suggestion after running a Print head clean, would be to replace or refill the ink cartridges.
Posted on Jan 13, 2008
My printer gives me the message: "Out-bin Full" all the color ink cartridges are empty, blk one is full I am using Staples all purpose printing paper What needs to be done?
"Out-bin full"normally means that the printer thinks the paper tray where the printouts go is full of prints. If you have printouts on the machine, remove them. If there are no printouts, then check where the paper comes out, to see if there is any small piece of paper jammed, or if the sensor is stuck. The sensor is normally a small piece of plastic on a hinge, which will be just where the paper exits the printer.
Jul 23, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
Black stopped printing out. Dell 922 all-in-one ink jet.
Did you already run the head cleaning cycle from the utility?
Apr 23, 2008 | Dell 922 All-In-One InkJet Printer
I have the exact same problem with the E on the left hand side of my display panel, and the machine will do NOTHING! HELP!!
You got little fingers?... I reckon you may find that the little head that runs up and down to print isn't moving free. ie machine turns on and goes to test printer mechanism and .....E ..... check gently ie move it with power off...that it can move up and down ok and isn't full of dust in that area, also check paper path is clear by threading paper all the way threw,
Is there any print,? noise at power up? will it power up without an E if turned on when set to just calc and not print?
Nov 07, 2009 | Canon CP1200-D Calculator
Is there a fix for error 6A80 for a Canon mx700 printer?
You can try a few things:
RESET the printer:
  1. On the operator panel, press and hold the <ON/OFF> button for one second. (The display will go blank.)
    Note: It may be necessary to unplug the power cord if pressing the ON/OFF button does not shut off the printer.
  2. Wait approximately ten seconds and then press the <ON/OFF> button again.
  3. Wait until the device has completed its cycling process before submitting another job request.
Check for paper jammed in the paper output slot, the Rear Tray, or the Front Tray.
Remove the paper following the procedure below.
(1) Slowly pull the paper out, either from the paper source or from the paper output slot, whichever is easier.
(A) When printing from the Rear Tray
(B) When printing from the Front Tray
bullet_s.gif If the paper tears and a piece remains inside the machine, open the Scanning Unit (Printer Cover) and remove it.
After removing all paper, close the Scanning Unit (Printer Cover), turn the machine off, and turn it back on.
* Be careful not to touch the components inside the machine.
bullet_s.gif If you cannot pull the paper out, turn the machine off and turn it back on. The paper will be ejected automatically.
(2) Reload the paper in the machine, and press the OK button on the machine.
If you turned off the machine in step 1, all print jobs in queue are canceled. Reprint if necessary.
i_note.gif Note
bullet_s.gif When reloading the paper in the machine, confirm that you are using the correct paper and are loading it into the machine correctly.
bullet_s.gif A5-sized paper are suited to print documents consisting mainly of text. We do not recommend using such paper to print documents with photos or graphics, since the printout may curl and cause paper exit jams.
If you cannot remove the paper or the paper tears inside the machine, or if the paper jam error continues after removing the paper, you should take the printer to a service shop since the printer will have to be disassembled to remove the torn paper.
Oct 16, 2009 | Canon MX700 Office All-In-One InkJet...
Recieving fax no printout, all other printing processes ok
When you say all other printing processes are ok, I am assuming you can make copies and print from the computer. If so...then are the blank faxes coming from several different fax machines or are they coming from one particular fax machine. If one particular fax machine, then the problem is probably on their end. I need to go backwards a second....when you receive a fax does the machine spit out a blank page or no paper is fed at just receives the fax? Is the machine programmed to just receive faxes to memory to be printed out later? It doesn't make sense for it to print or copy but not to print a fax. If problem persist try a different fax modem.
May 08, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Blank paper
That is the most likely cause.
Also under the cartridges, there are some ports and pads that may have dried out. In that case unplug the machine, and remove the cartridges, trickle some alcohol slowly to dissolve the sticky ink in that area. Place some paper towels under the print head area as you trickle in the alcoholl and allow it to drip into those towels. Then allow some time to dry.
The cartridges and those port areas can dry out or become very tacky.
Feb 26, 2008 | Lexmark Z715 InkJet Printer
Misaligned Printing
if you do an internal test page ( there should be a button on the machine you push for this function, I'll give you the link for the manual in case you don't have it) does it come out crooked?
the alignment of cartridge is to make sure the colors are o.k. not for paper alignment.
if the internal test comes out ok then the problem is with the paper path, are the guides snug against the paper ?
if the internal test comes out crooked then the problem is with the scanner or board.
Dec 06, 2007 | HP OfficeJet 6210 All-In-One InkJet...
Printouts with shadow
Two things - Fuser or cartridge - stop print halfway in machine, if fault occurs before paper has gone threw the fuser then it is a faulty cartridge, if print is ok before fuser (the hot bit at rear) but gets doubled up after fuser then the hear roller in fuser are faulty change fuser....but 95 % of the time it is due to dodgy refill cartridge or worn cartridge (the rubber blade inside cartridge fails to apply enough pressure against drum to clean away old image  hence duplicating itself onto your nice clean paper! Try a known good cartridge if in doubt..
Oct 16, 2007 | HP LaserJet 1300 Printer
Lexmark X5150 All-In-One InkJet Printer Logo
298 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
