Question about RCA F36650 36" TV
Green is going, going, gone?
The TV first began showing signs of trouble with the vertical hold, the picture would slowly squeeze together. Sometimes this was fixed just by unplugging the TV. I would also like to note that there was also a small sparking when the TV was plugged in, or unplugged from the outlet.
The vertical hold was no longer a problem, but then the green was not appearing on the screen. When adjusting the screen with the controls on the flyback, the green would appear when adjusted fully to one side, appearing with bright trace lines and blurring out the rest of the picture. The picture returns to normal when adjusted so the green retrace lines are gone, but there is no green in the picture.
I thought that with all the problems this TV has with the Flyback Transformer, that I would replace it, along with the Horizontal Output Transistor. After doing this, and adjusting the screen level on the flyback, the picture was back to normal again.
But that didn't last long, when I went to make another fine adjustment on the flyback, the picture once again lost the green and would only appear when fully adjusted to one side.
Could this be a problem with a solding joint elsewhere on the board, or another component that is going out?
As is appears, not many local repair shop will work on a large screen standard TV, and being this set belongs to my retired folks, and they can't afford the expense of the repair shops that are out of town. Any help, or suggestions would be greatly appreciated. Thank you.
  • 2 more comments
  • ithelps2help Jan 15, 2008
    Thanks for the quick response, any help is really appreciated.
    Serial # D435C2036
    Chassis # ATC113CA1
    I don't know if this is going to make things more difficult, but today I checked the Main PCB and did some minor cleaning, no fluids were used, just a soft brush. The TV was in storage for a short period and I thought that the weather may have caused some damage to the Main PCB.
    After checking the soldering joints, and doing the cleaning. I plugged in the TV, and the picture was very dark. I barely touched the Screen Adjustment on the Flyback, and the picture came in cystral clear with all colors present, including the missing green.
    The TV never had any problems until it was put into storage. I don't know if moisture could have caused some damage, and I really don't know where to look for it on the Main PCB. Some of the soldering has a slight "smokey" look to it. It took a couple months before problems started happenling.
    Thanks for any help.
  • ithelps2help Jan 18, 2008
    The TV is a:
    Model: RCA Model F36650 36" TV
    Serial #: D435C2036
    Chassis #: ATC113CA1
    Made: October 2003
    I'll check the Voltage on the Cap as soon as I can, but I thought I'd let you know that the picture on the TV is finally coming in clear.
    I did a minor adjustments on the Flyback, when the picture was appearing very dark when first turned on. The screen is now bright, but the screen takes awhile to appear and it seems the green is appearing first.
    Will let you know how things turn out. Thanks for help.
  • Vista Electronics May 11, 2010
    What is the Model # ?
    What is the full service # off back of set??
  • 2,336 Answers
I would suggest check the the secondary side of the power supply for around 130VDC if that voltage is found to be lower than 120VDC I would suggest to replace CP80 with a 100 mfd@250 vdc. Part # 218374
Check Globalsemi.com for these parts.
Posted on Jan 17, 2008
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
BIG SCREEN TV WILL NOT COME ON
YOU LOST VERTICAL DEFLECTION THIS IS NOT HARD TO SOLVE
Dec 25, 2009 | Televison & Video
Gas keeps going is it worth fixing or is a new one better
I assume you mean that your screen is showing signs of stress 7 the picture quality is suffering. This would mean a replacement screen is needed & as this is very costly then it is more economical to buy a new TV instead.
Dec 01, 2009 | LG 50PG6000 50 in. HD-Ready Plasma TV
Philips TV (old) showing a horizontal line in center of screen
Check for the cracked solder joints on the IC or dried capacitors on the vertical side
Mar 28, 2009 | Televison & Video
Samsung hl-s6186 screen flickers and sometimes goes green
The humming will usally come from the color wheel(one of the only moving parts), which is part of the light engine. If the tv is starting to get a green picture that is a sign that the light engine is on it's way out.
Aug 05, 2008 | Samsung HL-S6187W 61 in. HDTV
Tv does not turn on
You does not mean about picture clarity before this problem occurs. Former the picture clarity is well and good means picture is not problem. There is a problem in horizontal deflection area.May be flyback transformer failure shows these type of problem. This service should be done by technical persons only.
Aug 27, 2007 | Sony KV-32S42 32" TV
Philips TV showing horizontal lines model 27pt6441/37
You likely have an elevtrlytic capacitor bad on the B+ line to the vertical ouput ic. If you continue to use the set like this it is likely the vertical ouput ic will fail.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Jun 26, 2007 | Philips 27PT6441 27" TV
Shrinking picture
All symptoms indicate a problem in the vertical circuit,the first thing to look for will be loose conection on the vertical output IC,sometimes this IC goes bad completly and it needs to be replaced.If you are familiar with soldering electronics you can take care of it but if you are not too familiar you can play it safe and take it to a servicer ,it will be a lot less expensive than if they come to your house.Let Us know how it goes or if you need more information.
Oct 26, 2006 | Quasar SP-2722 27" TV
RCA F36650 36" TV Logo
122 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
