Question about Canon PowerShot A75 Digital Camera
Opening the camera
My card will not insert all the way and it has been suggested that I need to open up the camera to fix a probably-spent pin. How do I open, where do I start, etc? Is this a risky proposition?
If you check you have probably some bended pin, I had the same and I put them back with a very small and long nose screw driver for camera but the suggestion of a long needle is also good but don't open the camera because I did and we can not remove that part or work on it because you will have to break a type of sealed electronic card so it is impossible for someone who does not have all the tools and resources for it. It need patience to bring back straight up the bend pin. You also need a magnifying glass to see clearly were to put it back in a good alignment. But I succeed there was more than 3 bended pins.
Good luck.
Moboul
Posted on Jan 15, 2008
  • 36 Answers
That is a very risky proposition as you might say. you know nothing about its architecture. The people who knows this things are found on the Canon Service Station/Center. To avoid future problem that may arise if you'll gonna do it yourself, just visit the nearest service station in your area.
Posted on Jan 14, 2008
My nikon D200 shows CHA whenever I insert a CF card? How can I fix it? It shows that error even I use a different card.
Dear Sir e_jamandre, probably the connector memory card has one or more bent pins or cracked solder.
The worst thing would be that the memory compression circuit is damaged.
Greetings
Feb 11, 2011 | Nikon D200 Body Only Digital Camera
Hi, I have an Oly SP-510 UZ camera and I have a problem with it, don't recognize the XD 1GB card. I tryed many cards (2GB and 1GB) and all are the same, when I insert the card I have the message "card is...
Hello Musat
The problem sounds to be with the card reader of the camera. Most often what happens is that the soldering on the card reader's connection to the circuit board gets loose and if one of these contacts are loose , it gives a card error.
The problem is most likely not firmware or card related and unfortunately opening the camera to check the soldering is not really a user friendly fix. If you send it in , it will cost about $40-$80 to have this fixed.
Have a look under a good light into the card slot and see if you can see anything out of the ordanary that may be blocking the contact pins but if there is none , you probably won't be able to fix this yourself.
If your camera is still relatively new , you should have it fixed under the warrranty service.
Kind Regards
Andrea
Sep 28, 2010 | Olympus SP-510 UZ Digital Camera
I have olympus e300 evolt and the read out says card cover open when it is closed any ideas?
my Cannon has to be well clipped in ... scares me doing it but they can be a little tight and of course must be the right way around ... most are lug prevented from misplacement ... then of course I cannot get it out ! later on, just a guess . Mike could be corroded, grubby electrical connect as it is shut ?
Jun 13, 2009 | Olympus EVOLT E-300 (Double Lens Kit)...
I have a Nikon D70 and am unable to insert memory card all the way, i double checked that it is the correct card and inserted the right direction.
STOP! You have just bent a few pins. Your camera has a male connection. Meaning it has pins sticking out. If you are unable to insert a memory card, that means a pin is bent and is not going into the holes in your memory card. This is a common problem with cameras that accept a compact flash card. This can be an easy fix or it can be a very hard fix.
Ive fixed a couple of cameras like this with a pair of tweezers. flash light (or some big source of light) and a magnifying glass. You need to look into the slot on the camera under light and look at all the pins sticking out. Look for the bent pins and use the tweezers to bend them back. Be careful not to keep bending the pin back and forth, as this will break the pin off. Ive seen cameras work without certain pins, but this is not something you want to do.
To have an SLR fixed is a minimum $160 dollars depending on where you take it too. The D70 is a good camera.
Please do not stick the memory card back in. Check the memory card to make sure all the holes are clear and have nothing blocking the holes or make sure a hole has gotten bigger and merged into one. I would use a different card once the pins are are sticking straight.
Hope this helps you.
Mar 30, 2009 | Nikon D70s Digital Camera
My Canon PowerShot A70 Digital wont take pictures!
There are several possible possible things might cause this error. The first obvious is the card has gone bad. Try a different memory card to verify.
Second thing is to inspect the pins in the card slot. Look for bent or missing pins. If you find a bent pin, don't fret as it's relatively easy to fix:
- Remove batteries and card. Use a small/skinny jeweler's flat screwdriver to bend the pin back as close as possible. Take your time and use as much patience as you can muster (take a breather in between if needed).
- It doesn't have to be perfect, just as close as you can get it. When it's there, take your flash card and "SLOWLY" insert it. The card itself should fine-align the pin. Remove the card, and verify that the pin is still straightened. If so, reinsert the card and try it out.
If it's neither of the above, the next thing to try is replacing the camera's "CR 1220" clock battery. Its compartment is located under the rubber A/V cable mat on the left side of the camera. You can buy this inexpensive battery at most department or drug stores. Just open the door by prying it open with a pin or small screwdriver, take out the old battery, and put in the new.
Jun 10, 2008 | Canon PowerShot A70 Digital Camera
Memory card
When you use an SD card in mulitple cameras, each camera creates it's own folder beneath the DCIM folder. I'm not sure if you have a program that automatically opens when you insert the SD card in your reader, but perhaps you can try double clicking on "My Computer" and locating your reader/SD card and opening that folder manually. Once you're there, open the DCIM folder and see if there are multiple folders inside. Open each one to see if you can locate your pictures.
If you have a program that opens automatically when you insert the SD card you'll need to figure out how to tell it to look in other folders.
Dec 28, 2007 | JVC GR-D270US Mini DV Digital Camcorder
Will No Longer Format SD Card
I'm assuming that you have used tried other SD cards? If so, have you tried to do a factory reset of the camera? If you have tried that and it still hasn't worked, I have one last suggestion that might help you. First, remove the battery from the camera. Once the battery has been removed from the camera get yourself a bottle of Isopropyl Rubbing alcohol and some q-tips. I tell you where I'm going with this: The contacts for the SD card in the camera could be dirty thus not allowing the camera to send the "write" message to the card, hence you get the write protected message. We going to clean the contacts to try and get it working again. One you have all the supplies, lay an old memory card down on a table with the connector pins face up. Use a memory card that you don't have any pictures on in case this process damages the data on the card. Take the q-tips and dip them in the alcohol and get a liberal amount of fluid on the tip. Next, coat each pin so that it is somewhat wet with alcohol. Don't use too much, you don't want to soak it. Next insert the SD card into the camera horizontally so that you can get the alcohol to the pins in the camera. To clean the pins remove the card and insert it several times. Repeat this whole action three to four times. Remove the SD card and let the camera stand in a position that would let the pins if they were wet drip down toward the surface. The pins should not be sopping wet, I'm just try to convey that this is how the camera should be left to dry for the next hour. After an hour or so try using the SD card that you cleaned the pins with. If it works, enjoy! If not, drop me a note. Good luck If you want me to continue to help people with there problems, please rate me!! Thanks
Oct 04, 2007 | Nikon Coolpix 5600 Digital Camera
Casio Exilim won't turn on when memory card is inserted
It sound like a bent pin issue. Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in. From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break. Good luck !
Aug 04, 2007 | Casio Exilim EX-Z57 Digital Camera
Camera wont work when memory card is inserted
I suggest you try to use a different memory card. If it doesn't happen again then it's probably a bad memory card.
Mar 06, 2007 | HP Photosmart M417 Digital Camera
Memory card won't format
Most likely one of the pins on the compact flash connector is bent, not allowing the card to be recongnized correctly - Am now fixing such a problem for a friend
Jan 23, 2007 | Canon PowerShot A95 Digital Camera
Canon PowerShot A75 Digital Camera Logo
20 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
