Blinking light on the front bye the power button
I was wondering if my tv has the exact same problem as the one about the capacitors for the wd 52525. because i have the exact same problem as far as the blinking light of death. i have tried to hit the reset button. but nothing works. and i am pretty sure that it is not the lamp.
  • 8,617 Answers
That is a common problem in the wd series mitsubishi, but it doesnt stop at WD series. Mits had some bad capacitor trouble even in the VS series Jamicon capacitors. I have switched out a thousand or better. hope this helps. Its an easy repair. You have 4 capacitors tight together on the DM board replace them with Radio Shack equivalents and you should be good to go. Hope this helps.
Posted on Jan 13, 2008
The timer light is continuosly blinking when i plugging in the tv (mitshubishi wd-5252) and won't reset?
Thats one of the famous capacitor issue most likely. Thats the V26 Chassis DLP and usually that symptom is caused by failed DM and Power Board capacitors. There is a repair kit that will work in alot of cases with that symptom. Its called The V26 Chassis DM / Power repair kit available at the following link with detailed instructions
Apr 03, 2013 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 with blinking green light problem
The #3 post worked for me. I first just did the capacitors and it did not work at first, but I got it reset. It worked for 2 months and lost power the other day in a storm and the blinking light came again and would not reset. I put in the switch and followed his directions and it work perfectly. Sweeet. The switch was easy. The capacitors were not hard, but very detail oriented. I work on copiers for a living, so I am used to taking things apart and back together. You must be able to solder and reassemble pretty well, or I would hire someone to do it.
Sep 16, 2009 | Mitsubishi WD-52525 52" Rear Projection...
The timer light green blinking all the time
You most likely have some bad capacitors on the dm board, unfortunately the board is not available for this set, the complete chassis has to be sent in to Mitsubishi to be rebuilt.
Sep 08, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Ws-55813 mod. green ld light wont stop blink tv wont turn on
The DM modul is bad. Replace all 1000mF/16V capacitors( be careful with the polarity). After replacing capacitors conect to AC power. Waith about 1min. Green flashing will stop. Turn ON tv. The modul is on the raight hand side next to the main board.
Jan 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Continuosly blinking green light and tv won't turn on.
Either bad capacitors -vented - on power supply board or bad E2P eprom board on DM board.Probably the capacitors-4-1000Ufd and 2-3300ufd.You should get expert help from reputable tv shop.Not really do it yourself fix either way.
Dec 15, 2008 | Sony KDS-60A2000 60" HDTV
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Green blinking light
the PWB , FMT and DM boards all have capacitor issuses with that chassis. If the power light is blinking there are 4 1000uf capacitors on the DM that need replacing. If you need more info let me know.
May 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Televison & Video Logo
165 people viewed this question
Top Televison & Video Experts
