Question about Philips 32PT6441/37 32" TV
No picture or sound
The power button comes on then pauses then flashed 5 more times. what does the code mean
    Scholar:
  • 173 Answers
Means run ... or you lost power supply inside the set.
Posted on Jan 19, 2008
1987 plymouth reliant power loss light
You need to do the on board diagnostics to determine what trouble code(s) it is giving. Here's how: cycle key to On (not start) position, then off, then on again, then off, then on, and leave it in the on position. (leave on after 3rd time on ) Now the check engine light will flash a series of 2 digit numbers, with a pause in between each digit. For example: 2 flashes, pause, then 2 more flashes, would be code 22. 3 flashes, pause, 5 more flashes would be 35. There will also be a little longer pause between the 2 digit codes. You may have more than 1 trouble code, so pay attention and write them down as you go. When you get code 55 ( 5 flashes, pause, 5 more ) that means end of message, or codes. Get back to me with those codes and I will tell you what area the codes are pointing at as a problem. Does the car seem to be experiencing any running problems currently?
Apr 22, 2012 | Plymouth Reliant Cars & Trucks
Sony kds-60a2000 power light flashes 5 times, no picture
5 flashes - Lamp Driver - (lamp driver faulty)
This is the error code that usually means the ballast (it is the power supply for the lamp) is bad.
SD TECH
Apr 20, 2012 | Sony KDS-60A2000 60" HDTV
I have a 1994 plymouth voyage se and it will not strat. It tell me to check gauge light comes on. what should i do or what does that mean?
Turn key to on ( not start) then off, then on, then off, then on and leave on, and have a pen and paper ready to record flashes of "check engine light". It will flash then pause between second number of 2 digit code. Then a short pause and flash again, pause, then flash. For example: if it flashes 2 times, then pause, then flashes 2 more times, that would be code 22. If it flashes 3 times, pause, then flashes 5 more times, that would be code 35. As I said, there will be a short pause between 2 digits, as well as after number. Write them down as they come up and get back to us with those codes for advice. When you get code 55 ( 5 flashes, pause 5 more ) that means end of message. Those codes should point everyone in right direction of trouble spot.
Jul 31, 2011 | 1991 Plymouth Grand Voyager
"on" light flashes twice and then "blacks out"
IF power light comes on and a few seconds later goes off, do the self check this model has.
On front of set when this happens, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Watch the power light closely, it should blink a two digit error code like; 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65909 65" Rear Projection...
Error codes. no picture or sound after turning
When the SUB5V or MAIN9V/SUB9V, short or over-voltage 15V short condition occurs, the TV shuts down and the power LED blinks 10 times.
May 15, 2010 | Panasonic Televison & Video
The tv sound works all the time when turned on but occasionally the video either does not come on or goes of while watching it.
It is usually a vertical deflection circuit problem. Here's the basic troubleshooting:
  1. Make sure that no front panel buttons are inadvertently stuck in an "engaged" position.
  2. Press MENU button. If a small horizontal line appears at the center of the screen, you have lost vertical sweep on your TV. The protection circuit shuts down the picture to protect the tubes from burning a line across them. The intermittent problem may indicate a loose solder. Try resoldering the vertical output IC. The IC along with the B+ feed resistor back in the sweep power supply is most probably bad or has a loose solder.
  3. Press the DEVICE and MENU buttons on the front panel simultaneously and hold it for 5 seconds to activate the Error Code Operational Check. The status LED indicator will then flash denoting a two digit code.
  4. Count the number of flashes then pauses for about a half second then flashes again. The first number of flashes indicates the first digit of the error code and the second number of flashes indicates the second digit of the code. For example, if the error code is "24", the LED will flash 2 times, pauses, then flashes 4 times. The error code is repeated a total of 5 times. Error 24 indicates a vertical deflection circuit failure.
Please let me know the code you'll and I'll tell you where the problem lies and how to fix it.
Dec 02, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi projection tv picture and sound turn off but the power button remains on with no picture or sound turn tv off real quick and then back on and works for 2 mins then turns off again what could be...
  2. Disconnect ALL devices from the TV.
  3. Press the SYSTEM RESET button and hold for 10 seconds. Proceed if the problem still exist.
  4. Press and hold POWER and MENU buttons simultaneously for 20 seconds. Proceed if the problem still exist.
  5. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours.
  6. If it still shuts down, press the DEVICE and MENU buttons on the front panel simultaneously and hold it for 5 seconds to activate the Error Code Operational Check. The status LED indicator will then flash denoting a two digit code.
  7. Count the number of flashes then pauses for about a half second then flashes again. The first number of flashes indicates the first digit of the error code and the second number of flashes indicates the second digit of the code. For example, if the error code is "35", the LED will flash 3 times, pauses, then flashes 5 times. The error code is repeated a total of 5 times.
Please let me know the code you got and I'll tell where the problem lies and how to fix it.
Dec 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Plymouth grand voyager 1991 3.3l v6 se
Sounds like you need to check for a vacuum leak.(hissing noise) Also try this,: Cycle key, on, off, on, off, on, and leave on (not start) & count "check engine" light flashes. Always a number, a pause, then another number. For example: 2 flashes,pause, then 2 more is code 22. 3 flashes, pause 5 more, is code 35 etc. When you get 5 flashes, pause, then 5 more, that's code 55 which means end of message. Try that and lets see if any codes come up & go from there. Get back to us with what you find.
Jun 13, 2009 | 1991 Plymouth Grand Voyager
No picture/ power button flashes twice constantly. 2 flash code?
Sorry, but there is no simple answer to your problem.
Bottom line, it needs to be repaired by a qualified technician.
The blinking is a code for what circuit area of the set called for the shutdown.
No matter what it is, there is nothing more you can do.
www.mcveyelectronics.com
May 03, 2009 | Philips 50P8341 50" Rear Projection...
Sony KDP-65WS550 flashes when you try to turn it on
No the DLP units can flash more than 8 times. 9 blinks mean Zero Crossing detector which means diode number D6166 or D6114 is open they are on the A board.Let me know if you need any further info.
Feb 23, 2008 | Televison & Video
Philips 32PT6441/37 32" TV Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
