Question about Dell Dimension™ B110 PC Desktop
DELL MASTER RESET?????
I need help, my Dell dimension b110 with Windows XP home edition, keeps getting the blue screen that says UNMOUNTABLE_BOOT_VOLUME and everytime i try alternate boots, it goes right to the blue screen. i don't have any Windows xp discs either, windows came with the pc when i got it in 2005
please help!!!! if i need to master reset it somehow, tell me too thks
  • samandrosh Apr 28, 2009
    I keep getting this blue screen that says "A problem has been detected and windows has been shut down to prevent damage to your computer. UNMOUNTABLE_BOOT_VOLUME. If this is the first time you've seen this screen, restart your computer. If this screen appears again follow these steps: Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you might need. If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable components, restart your computer, press F* to select Advance Startup options, and then select safe mode. Technical information: *** STOP: 0x000000ED (ox81351738, 0xc000009c, 0x00000000,0x00000000)
    Please help my computer keeps going to this screen and will not go to Windows XP I do not know what to do at this point. I am currently using my laptop till I can get this issue resolved. Thanks so much Sammy
    Brigadier General:
  • 6,966 Answers
Based on your post/description, you have three (3) concerns:
1. "master reset" - if you are ferring to the BIOS/CMOS, normally this would require that you open your PC and on the motherboard, temporarily move the jumper from 1-2 of Jumper PSWD to 2-3 and then back again after a minute or so. Alternately, a reset can also be done by removing the internal motherboard Lithium battery for a couple of minutes.
2. "UNMOUNTABLE_BOOT_VOLUME" - refers to a hard disk problem which can either be: a. defective/missing partition; b. corrupt format/files/OS; and/or c. defective hardware/HD.
3. "blue screen" - normally displays when Windows is booting and is indicative of either: a. defective memory and/or its contacts are dirty; b. corrupt/inappropriate video drivers, defective video card and/or its contacts are dirty; c. corrupt drivers/software/applications; and/or d. corrupted/defective hard disk.
Corrective procedures would require any or a combination of:
A. Determine if your HD is still functional by temporarily installing it in a 2nd PC. This will also allow you to backup your important files if the HD is still accessible;
B. Repartition, reformat, reinstall your OS. You need to borrow an OEM XP Home installer CD and use the MS Windows key in the sticker at the side or back of your Dell Dimension B110;
C. Clean contacts or replace if determined defective the memory and/or video card.
If you were successful in repartition, reformat, reinstall your OS, you also need to re-install the drivers which may be downloaded from here. Additionally, manuals and other related information are available here.
Hope this be of help/idea. Pls post back should you need additional information.
Good luck and kind regards.
Posted on Jan 13, 2008
  • Louie  Role
    Louie Role Jan 13, 2008
    for tom19511,
    Sorry tom, did not know you posted already while I was composing my reply.
    Cheers.
    Genius:
  • 1,601 Answers
When booting up to Win XP you may get a error that reads "Unmountable Boot Volume". This is probably because your boot.ini file is messed up.
You should be able to restore your windows installation.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&l=en&s=gen&docid=35F157CB59994ED7E040A68F5B2813E3&journalid=4391620012FE791FE040A68F73281D77&Query=dW5tb3VudGFibGU=&SystemID=DIM_CEL_1100&ServiceTag=&contenttype=-1&os=-1&component=-1&lang=-1&doclang=en&toggle=false
Unmountable boot volume + how to fix. Have reboot CD's Errors messages 0x000000ED, 0x8137DE8, 0xC0000006, 0x00000000, 0x00000000 can't get past this screen. keep circling around F8 and the Dell start-up...
Turn off your pc and take the side panel off and remove the cmos battery leave for three minutes
and then replace this will reconfigure your
motherboard and hopefully solve your problem.
Feb 15, 2010 | Dell Dimension 2400 PC Desktop
Black Screen on Dell Dimension 3100 on boot up. Running Windows XP Home Edition. This happen before you get to the Windows login screen.
If you have a black screen it means the system cannot boot into your master boot record, you should reinstall the system using a bootable Windows XP CD, and perform a repair,( not the Repair Console).
When youre in the Windows XP Wizard screen, press enter , accept the license agreement, and then it will check for existing windows xp partitions, press R to repair the existing Windows XP installation, and wait til it gets your system restored.
Jan 10, 2010 | Computers & Internet
Windows XP Blue Screen
change your ide cable or sata.
Reset your bios settings pull cmos cell from motherbord for minute so all settings are defaults.
Also boot your computer with winxp disk then if you able to enter in setup then go to recovery console mode and run "chkdsk /r' command .
Also check your harddisk is master set jumper in master position .
Aug 18, 2009 | Computers & Internet
I would like to run a PC reset on my 4700 that runs on XP Windows Home Edition. The "Dell" blue scroll does not appear on the top of the screen to allow me to hit to go to the PC reset screen. How can I...
Okay...Normally the recovery partition contains a Ghost "or Ghost-like" image of the hard disk in the state it was shipped. You can get an option to boot to the recovery partition if you pres F12 during post. Follow the onscreen instructions and you are going to be okay.
Aug 13, 2009 | Dell Dimension 4700 PC Desktop
UN MOUNTABLE BOOT VOLUME ERROR - BLUE SCREEN
Place a Windows XP disk in to a drive and just after pressing power button keep pressing F10 or F12 to get to the boot menu then choose cd/dvd drive and follow procedures from the screen to repair or install system. ANother way is by pressing F1 or F2 or Del just after pressing power button to get to BIOS the go to Boot options and set firs cd/dvd drive then press F10 and enter.
Jul 20, 2009 | Dell Latitude D600 Notebook
Dell tech in who-knows-where told me to reinstall operating sys, XP Home. About half way thru, error message, "Windows detected fatal error, shutting down." Tried 2 times more same message. Help! Dimension...
The fatel error is cause by memory/ and or CPU giveing out if the unit is under warrenty then I would suggest having them diagnose it , if its not then purchase some memory with the same spec's and try reloading again.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Dell Dimension B110 PC Desktop
Error message: unmountable boot volumn
Yes you can save your computer. But if you are running Windows XP, you need the Windows XP CD. Boot with that CD and at the first prompt, press "r" to get to the repair option.
Press 1 to choose your windows instalaltion and then at the prompt, type the following
chkdsk /r
this might take some time but at the end, type the work exit and you should be back in business.
Mar 13, 2009 | Dell Dimension 4600 PC Desktop
HOW CAN I FIX MY COMPUTER? ITS READING UNMOUNTABLE BOOT VOLUME?
You need your Windows XP cd for this fix.
Boot from the Windows XP CD and at the first prompt, press "r" for repair. Press 1 when asked to choose windows installation and then enter the admnistrator password. If you don;t have one, just press "enter" and it should show you "c:\windows>"
At this prompt, type the following
chkdsk /r
THis should take quite sometime but will fix the problem at the end. when you get the c:\windows prompt again, type the word "exit" and your system will reboot and load windows XP normally
Mar 07, 2009 | Dell Latitude D600 Notebook
Restore for dell dimension b110 without disk
Boot the computer, as soon as the blue Dell bar comes on the screen press CTRL+F11 this will take you to the Dell Restore. If that does not work you can request a backup CD from Dell here(one CD only):
https://support.dell.com/support/topics/global.aspx/support/dellcare/en/backupcd_form
Mar 06, 2009 | Dell Dimension™ B110 PC Desktop
Operating system
What part do you usually get the blue screen, you also need to know what kind of blue screen are you getting, for example beginning dump of physical memory or unmountable boot volume, then send me a message so that i can help you.
Nov 03, 2008 | Dell Microsoft Windows XP Home Edition
Dell Dimension™ B110 PC Desktop Logo
1,887 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
