Question about Toshiba Satellite P35-S611 Notebook
Please contact me at spz4321 at gmail dot com
Posted on Jan 18, 2008
Ad3177, I would like to talk to you about your problem email me at spz4321 at gmail dot com
  • 689 Answers
There is connectivity problem, best way is to ask a qualified hands on technician's help to clean the connector as it probably stained due to environmental changes like humidity. By my experience issue doesn't require any replacement of parts but skill of the technician is essential. You may check your local repair center or you can take to the Toshiba Authorized center.
here is the link for Toshiba Authorized Service center selector
Good Luck
Posted on Jan 15, 2008
Okay one day my compaq Presario F700 kept showing a message saying it needed to be restarted because something wasnt starting up when the computer turned on. So I restarted it and when it came back on the...
you disabled keyboard in fn mode press fn blue key and hold down and locate the little blue key on keyboard and press it release at same time if that dont work restore to earlier point using on screen keyboard and problem should be fixed
Mar 01, 2013 | Computers & Internet
Purple laptop display
Sounds like you either cracked the screen (does it get more colorful with a little pressure?) or that the video cabling has come loose at either the motherboard or the lcd. Find a tear-down video for your laptop model and check these connections. Reseating them should be fairly straightforward.
Nov 10, 2012 | Toshiba Computers & Internet
Replace satellite keyboard
These days, laptop computers, like the Toshiba A305, are designed so that many of the components can be removed and replaced.
This includes the keyboard, which can be removed even if it becomes broken or damaged. This is good because it means you don't need to toss out the whole computer, but you may be worried about how to do it if you don't know much about computers.
The good news is that the process is fairly straightforward.
Turn off your Toshiba laptop and remove the power cable if it is attached.
Close the screen and turn your computer upside down.
Slide the rectangular battery out of its compartment on the underside of the computer.
Turn the keyboard right-side up and open the screen so you have full access to the keyboard. Locate the rectangular plastic frame just above the keyboard.
Insert the top of your screwdriver in the seam at the end of the frame where it meets the side of the computer, and gently pry the frame up.
Remove it from the computer.
Remove the two screws above the keyboard and set them aside.
Lift the keyboard up and unplug the thick ribbon cable where it connects at the back of the keyboard. Set the old keyboard aside.
Plug the cable into the port in the back of the new keyboard and fit the keyboard over the computer.
Replace the screws and bezel, and you're finished.
Hope this helps
Nov 04, 2012 | Toshiba Satellite A305D-S6848 Notebook
The t and the y don't work
cleaned them with what?
key don't work on a laptop due to something being spilled on them(liquid) or something underneath them(hair, crumbs etc)
hold the laptop upside down(off of course) and GENTLY tap the edge near the keyboard bottom on table you might find something dropping out
otherwise new keyboard time
May 25, 2012 | MSI CR630228US 156Inch Laptop Black
I would likke a manual for a toshiba L775D computer that explains the keyboard and etc.
Until now, I've never found a software that can be used to fix keyboard.
Based on experience, in keyboard have configuration button, which can be used to turn off, the hardware functions. When we press a button, the keyboard will ignore damage to the hardware.
Configuration button is press one button or several buttons at once. There is no manual that I have ever read. I'm using experience, instinct and trial and error method, to fix keyboard without replace keyboard.
Dec 05, 2011 | Toshiba Computers & Internet
Hi, i have a toshiba x205-s9800. my two year old seems to have accidently pressed some keys and disabled the keyboard...please help...
You could have deleted the keyboard in the device manager. If so, rebooting your computer and it will find it.
Are all the keys not working or just some? Take a look at this hint and see if it fits.
I do this for fun & feedback not $$$
Oct 02, 2011 | Toshiba Satellite X205-S9349 Notebook
When I turn on my Toshiba laptop the keyboard will not light up and the screen will not come on? What could be the problem?
have you pressed any of the top keys by mistake as one of them will i believe turn off the monitor/screen
maybe have a look at your top keys and find one that looks like a blank screen and try pressing it or pressing it with the fn key as well
also you could try to start up in safe mode which is probably in the f8 option at start up
and try to do a system restore
or go to device manager
scroll down to find the display and un install it
then restart and hopefully all will be good
or press f8 on start up and try to choose last good know configuration and see if that does anything for you
if you still have a problem please come back to us telling us what operating system your are running
many thanks
Mar 06, 2011 | Toshiba Satellite L500 Series Notebook
I'm trying open my Toshiba Satellite L500D; I am having a problem I have removed all the aparent screws but I can't seem to lift the keyboard from the laptop. Ids there something else attaching it that I...
Check the "top" edge of the keyboard -- that part closest to the hinges & the LCD screen.
There may be a few "tabs" going "under" something.
Gently push the keyboard towards you, so that those tabs can be adjusted to move "over" that something.
Then, gently lift the keyboard -- there probably is a small and delicate ribbon-cable connecting the keyboard to the motherboard.
AVOID breaking/damaging that ribbon-cable.
Jul 18, 2010 | Toshiba Satellite L500 Series Notebook
Toshiba Satellite 5105-S501 LCD screen resolotion
This is usually caused by the cable that connects the LCD to the system board coming loose.
On this model, you can pop off the shiny black cover with three silver buttons on it above the keyboard. You will see a plug under there with about 25 multi-colored wires coming out of the connector. Carefully pull the connector off and then plug it back in.
If this doesn't fix it, try gently wiggling the plug with the laptop on and see if the picture changes quality at all. If it does, then the port on the system board may have gone bad.
Dec 07, 2007 | Toshiba Satellite 5105-S501 Notebook
Toshiba Satellite P35-S611 Notebook Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
