Phone number 01924 835274 need a code for netgear box so i can go wireless
Following steps will help you out in retrieving the password for the wireless connectivity:-
a)Use an ethernet cable to connect a computer to any one of the four LAN ports of the NETGEAR router.
b)In a web browser, enter the router's IP address - either http://192.168.0.1 or http://192.168.1.1 by default.
c)When prompted for a Username and Password, enter the default username and password (admin; password) unless you have already changed it.
d)Select Wireless Settings from the Setup menu in the left-hand navigation bar.
e)ssid:-any name , channel:-11 , mode:-g and b
f)Under Security Options, select WEP (Wired Equivalent Privacy) or WPA-PSK (Wi-Fi Protected Access Pre-Shared Key).
For WEP:-
authentication type should be automatic and encryption strength should be 64-bit.
passphrase:-leave that blank and only select key1 from the list of four keys and in the key1 box type your telephone no. without the numeral 0 in the beginning or hen enter 10 hexadecimal digits of your choice and apply the setting's.
The number in the key1 box will act as the password to connect to the wireless.
For wpa-psk:-
In the passphrase box enter any password of your own choice between 8 to 63 characters which will be
password to connect to the wireless and apply the setting's.
g)You can also follow this link for the help:-
http://kb.netgear.com/app/answers/detail/a_id/112/related/1
