Switching of a str 6707 in onida tv
Sir i have a onida tv set having a let start problem . i have worked on this . replaced some elco.s str 6707 is used in power supply for 110v . tr.A966  is not working well. after triggering by brobe  get starts. pl. help me.
PAVAR SAPYA VAL NAKADT
Posted on Sep 03, 2012
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: Model Sony KV-G21q2S Problem-STR 6707 has
This is the SMPS Power suply drive and the IC fails ONLY if there is fault in the circuit. You need to check on the SMPS section
check this link below for tips:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
Next you need to check if the LINE output transformer has failed. If so this will have a higher current drain and so switch off the SMPS unit. check for the EHT drivers, capacitors in the HT circuit.
Posted on Jun 25, 2011
Hii everyone I'm new on fixya. Kindly pls help me.. my problem is i got a onida tv wich has a power supply fault...first it blows the fuse...then i replace a short cap. Now the another probolem arise. When...
What is the model and make?...its vary rare for any set to show 300 Volt on the main filter on the hot side of the power supply...generally with the set off and power correction factor inoperative it should be about 162 and go up to about 340 with the set on and power factor correction active.
Oct 18, 2017 | Televison & Video
STR 6707 give output voltage more than 110 voltage of TV Onida model BLACK
Check it with load. If it shows more than 112VDC, the IC is faulty. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Check all the related components at the SMPS section circuit, before replacing a new IC.
Jul 15, 2015 | Televison & Video
Sir i 'm TV mechanic i got (Model no
onida com
All the specifications are right there, hope it helps
Dec 14, 2014 | Televison & Video
Model Sony KV-G21q2S Problem-STR 6707 has been changed. After an hour the went down. The fuse and STR 6707 are working. But no picture no sound. When plug in it gives "boo" sound for few...
Jun 25, 2011 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Dear Sir, I'm Bangladeshi Tv Techanician, Sony tv
Hello
Before replacing the STR, have you checked all the components related to it? When STR burns out some of the nearby components, such as zener diodes and other resistors will also get damaged. You just replace the components, especially, zener diodes, in case it does not show any fault, replace it. Connect a 100W filament type bulb in seris with the power supply, and switch on the set. This will reduce the power concumton at the begining, and we can check its heat effect also, after all are ok we can connect directly. Check the smoothing capacitor at the secondary 130VDC. Replace it also. If you need furthermore assistance, feel free to contact me through Fixya. I'm an Indian, residing at Trivandrum, the capital city of Kerala State.
Dec 11, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Latest onida tv service code for remote
sir ineed the service menu code for onida tv remote model is rc 115/d
Nov 14, 2010 | One For All URC-3445 Remote Control
Tv set was in standby mode.the green light was blinking.what probably the cause sir/ma?
you can check the elco 100/160 Volt and replace it, or the problem may be caused by IC EEPROM.C2404,(2406 0r C2408 )
Oct 19, 2010 | Televison & Video
Onida black tv enter password
i want enter password for Onida TV for all models
Apr 24, 2009 | Televison & Video
Onida stand by problem
sir my onida tv 21'' ineed un lock
Nov 07, 2008 | NEC PlasmaSync 42MP3 42 in. Television
Televison & Video Logo
633 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
