Question about Lexmark JetPrinter Z22 Color InkJet
Not printing My control panel says I have plenty of ink but when I try to print something all I get is a piece of blank paper through the printer. I have tried aligning and cleaning the print cartridges and get nothing.
Yep
Posted on Mar 16, 2008
Print sounds but blank paper
Try a few print head deep cleanings if that does not help then you could try soaking the print head in a shallow plate of hot distilled water. Soak the tip of the print head only in no more than 1/8th to 1/4 inch of water.OR
Still Having Canon Printer Problems Then follow Us On: Canon Printer Support
Jan 29, 2014 | Canon PRINTER CANON IPF8000S PRINTER...
Hi.. I have a Lexmark X6180 printer and it stopped printing. The paper goes through, and it sounds like it's printing but the paper is blank when it comes out of the printer. There's plenty of...
It could be that your cartridge needs cleaning. On your computer, go to Start menu > Programs / All Programs > Lexmark 6100 Series > Lexmark Solution Center. Go to Maintenance tab > select Clean to fix horizontal streaks. Your printer will then print a page forcing ink through the cartridge nozzles and clean them. Try to print your document again and determine if the problem is fixed.
Jun 24, 2011 | Lexmark X6180 Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
Printer goes thru the motions but does not print.have not used in a while. the ink cartridges look clean and the chart shows plenty of ink when i print the allignment page(it's blank twice) the display...
If the printer has been unused for a considerable time the cartridges may have become blocked with dried ink.
Remove the cartridge(s). Take a slightly dampened cotton bud or piece of kitchen paper and carefully wipe the copper coloured surface on the cartridge(s). Then wipe with a dry piece of kitchen paper.
Re-insert the cartridge(s) and perform the print head cleaning function in your printer control panel.
Now try printing.
Mar 26, 2010 | Office Equipment & Supplies
Doesn't want to print
Try unplugging from the wall for 5 minutes / plug in and retry, cancels / resets printer memory.
Feb 17, 2010 | Canon BJC 3000 InkJet Printer
Prints only a plain piece of paper
There is something wrong with your printer head. Call brother for a replacement.
Dec 30, 2009 | Brother MFC-5840CN All-In-One InkJet...
I have to hit print twice for printer to print document
Try to install new cartridges, possible ends inks.
Since level of the ink is specified for orientation aproximately
Mar 07, 2009 | HP Officejet 6310 All-In-One InkJet...
Lexmark 1270
Could be your INK cartrage'is empty.or just cloged clean .it
hope that help you
Oct 28, 2008 | Office Equipment & Supplies
Printer not printing
Try this. Push the copy and cancel buttons together for about 3 seconds. Then release. The printer should push a blank piece of paper through. Try to print.
Jul 17, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Dell 720 printer won't print
Our Dell AIO A940 stopped printing black ink. Tried so many things, and finally (a year later) got it to print by selecting:
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
It's worth a try! Good luck!
Oct 23, 2007 | Dell Inkjet 720 Printer
Lexmark JetPrinter Z22 Color InkJet Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
