Question about Sony RM-768 Remote Control
KV-19TS20 does the above tv have a "MENU" feature.  I don't have the original remote, and want to change the input from AIR to CABLE.  Does this set even offer the cable feature.    thanx please e me at jr@excel.net
  • charriston Mar 15, 2008
    I have the same problem with my remote -I cannot find a "menu" button to change to cable tv
  • GWGuruMan Mar 16, 2009
    I have the same Sony KV-19TS20 which works great. I do not have the original remote any longer and can not reprogram the TV channels that it remembered last during programming.
    What is the replacement remote in the year 2009 that can access the SETUP of this TV?
The cable/air setting is done manually on the front of the tv.
There is a panel on the front that opens up and the right most switch is where you set it to air/cable
Posted on Jun 23, 2008
I have a 2008 LG 42LC5DC. The tuner is currently set to receive a cable box feed but I'm using antennae only and want to scan over the air channels. How can I get to the setup menu?
First set the input to TV if your cable box feed didn't come in on the RF cable. Press the Input button on the side of the TV (the second button from the bottom above the Power button). Alternatively press the Input TV button on the top left of the original remote. (You'll have to search through the inputs if you have a universal remote without the feature.) Next press the Menu button on the TV or on the remote, if you have the original remote/universal remote with the matching feature. On the original remote, the Menu button is above the OK button. The Menu button is the third button from the bottom (above the Input and Power buttons). Press the Menu button and then use the Up/Down arrows to navigate to Setup. (If you use the TV buttons, the Ch Up/Down buttons are Up/Down. The volume increase and decrease buttons are Left and Right.) Press the Right arrow key and then Use the Up/Down buttons to select EZ Scan. Press the Right arrow key again. Press the Right arrow key or Enter (on the remote) to launch the scan. You can find the screen shots of the Menu options and the button locations in the manual. The manual is available here: http://www.lg.com/us/commercial/documents/32lg505h-owner-manual.pdf .
I hope this helps.
Feb 06, 2018 | LG Televison & Video
How can I set a tv to antenna mode in order to receive digital channels?
It depends on the TV. First make sure that the active Input is TV. On some TVs, you may need the original remote or an universal remote that has an Input or Source button (and a code that enables that function for your TV). Some TVs have the Input or Source button on the TV as well or a Menu option to change inputs.
Next enter the On-screen Menu and find a Channel or TV setting option. In that sub-menu, you will find a Source option. (It may give the choices of Air or Cable.) After you set that to the Air, you'll need to scan for channels.
Please add a comment with the model of your TV for additional assistance. I hope this generic comment helps.
Mar 10, 2015 | Televison & Video
KV-x2162u lost remote
To access the picture settings menu, you must have a remote control. There is no Menu button on the front of this TV to select inputs.
Dec 26, 2012 | Televison & Video
Hi, A friend gave me this particular tv, I had cable put in my room and i connected it to the unit I'm only getting 4 tv stations my problem is There is no remote Does this tv come with a remote so i...
You will find the name on the set is not the company who made the set---you need an original remote to change the set from the AIR band to the CABLE BAND and to then autoprogram the channels in the menu.
A universal is a WASTE of time and money as it will be minus many key features needed to operate the set.
GOOGLE the model number and search for "original remote"
DO NOT BUY A UNIVERSAL REMOTE.
Aug 13, 2011 | Curtis CMC13101 Combo
Cannot change channel, volume, or select menu. will not accept input from remote anymore. you press menu, on the tv, nothing then you press volume or channel and menu pops up but as soon as any key is...
If the buttons do something, but not what they are supposed to do.....By chance are you using a universal remote (replacement for your original)? If so, the codes for the remote need to be re-set for use with your TV. Hope this helps.
Apr 09, 2010 | Sony FD Trinitron WEGA KV-36HS510 36" TV
I have been struggling to get the tv to move to the correct input when I switch from watching TV with Tivo to watching a DVD. I thought I'd made the correct selections, but end up either having to use the...
There are 5 types of input switching methods that you can come accross for each device. In the Software is says there is certain input switching methods that go with certain manufacturers - This is NOT the case. The following is the list of all the inputs:
1) Toggle (Method 1): You only use one button on your original remote to cycle through a set of inputs.
2) Discrete (Method 2): You have multiple buttons on your original remote where each button goes to a particular input and stays there, no matter how many times you press this button.
3) Menu Toggle (Method 3): A menu pulls up where you can scroll through the set of inputs and select which input you would like.
4) Menu Discrete (Method 4): A menu is pulled up where you use another set of numbers to select which input you would like. (you do not cycle through each input)
5) Multi Method (Method 5): A combination of any of the above. This can also mean that you have multiples of one of the above input switching methods.
Make sure you follow through the prompts for them but the Method 5 - you would have to contact Logitech Directly to get it added!
Jan 18, 2010 | Logitech Harmony 890 Universal Remote
Sony Trinitron KV-19TS20 Screen displays purple static or awful image.
This unit needs a tuner. A new one from Sony will run over $70, so I doubt that it is worth it. It is possible that poor ground connections could cause something like this, but the symptoms seem a bit too severe. I think it is time to invest in a newer set.
Dan
Oct 01, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Won't receive channels above 18, cable not at fault
Your "tuner" in the menu is set on "off air" or "antenna. It should be set on "cable" or "dish". See if you can go into your menu with the buttons on the set and change your tuner setting. Keever
Mar 06, 2008 | Sharp 27L-S100 27" TV
Remote/tv buttons not working & start-up menu flashing
You can get an original replacement remote that will work all functions from Here: http://www.remotes.com/remotes/servlet/rs?o=c&a=Search&m=KV-27FS200&uid=11829594841080 Good Luck
Jun 27, 2007 | Sony FD Trinitron WEGA KV-27FS200 27" TV
No Video
From the manual (search Google for CM27101S): Normally, your TV displays the signal coming through the antenna terminal. However, If you?ve connected another component to your TV(such as a VCR) using the Video/Audio input, you will want to be able to view the signal from the component. To do this, you will need to switch from the ? TV ? input to the ? Line1, Line2 ? Input, as follows: 1 With the TV on, press the MENU button twice, then ? Set-Up ? menu will appear. 2 Use the WCHVbuttons to select ? Input ?. 3 Press the CVOLB buttons to change from ? TV ? to ? Line1, Line 2 ?. 4 Wait 10 seconds, or press the MENU button to return to normal TV viewing.
Aug 07, 2006 | RCA F27676BC TV
Sony RM-768 Remote Control Logo
175 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
