Samsung lsa800 flat panel monitor power supply unit
I have the monitor...but dont have the powers supply unit..lost!!!..
it is a 14 v 4 amp....part number psu 370-4166.
i live in canberra australia....and believe if i cant get the supply unit..there may be a generic..16 volt 6 amp..which will power the monitor...thoughts??? ideas!??
Hieee can u send me intel845gl
Posted on Feb 25, 2008
    Genius:
  • 1,601 Answers
Do you have Schematic for my monitor
Hi
Dont think they are available any more. It's becoming a throw away world.
I used to fix them.... without a schematic. Your local TV technician can often assist with repairing an older style monitor. e.g. CRT tube type.
Modern monitors are LCD & digital electronics. Although they still blow fuses & have switch mode power supplies with leaky electrolytic capacitors that stop the power supply from working.
If your knowledgable in this field then I would start with a visual of the power supply. Be careful of the shock hazards.
Good Luck
Trevor
Sep 06, 2014 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Where can I buy a power cord for my Proview PL456s 14 in. Flat Panel LCD Monitor?
Can you supply a picture of the connection on the back of the monitor? Try to make it high quality and put a scale, ruler or dime near the connector to give proper scale/size and I will research it for you.
Dec 01, 2010 | Proview PL456s 14" Flat Panel LCD Monitor
Samsung monitor MN:2333HD, monitor will shut off after about five or ten minutes
The power supply on the unit needs repair. In some cases you can find a damaged one with good power and install the board. A good technician should be able to fix the unit for 80.00 or so. If you want to send the unit in to us we can usually have the repair completed in less than a week. Thanks
May 04, 2010 | Samsung SyncMaster 2333HD 23 in. LCD TV
I have a samsung 15 inch LCD TV. When I turn the
kcs36dd, Lcd TV's also have, just like LCD monitors, an AC to DC voltage power supply. It is called a "switch-mode-power-supply" and generates the DC voltages required for all the other important electronic circuits inside the unit. 98% of all 14" to 22' lcd panels have backlighting provided by "cold-cathode-fluorescent-lamps" (CCFL) that produce WHITE LIGHT so you can see all the pretty colors that the glass LCD PANEL produces on the screen. The INVERTER circuit requires 12vdc to 20vdc from the SMPS to convert into 500 to 1000v ac to light-up the CCFL's. IF the SMPS detects a FAULT CONDITION with itself or the INVERTER it will go into what is known as FULL or PARTIAL SHUTDOWN MODE to try and save itself from a catastrophic, nonrecoverable failure. e.g. sparks, smoke, fire. lmistyrel on aim.com I could give you more assistance if you had provided following informatiom.
1. How old is the unit? 2, Approximate total "ON" hours unit has? 3.Has unit failed within the WARRANTY period? 4. Will SAMSUNG do a cash+old unit swapout because of PREMATURE FAILURE? 4. Do you know enough to do a unit TEARDOWN and inspection to possibly determine ROOT CAUSE of SMPS/INVERTER failure? 5. Can you handle a soldering iron and solder to make DIY repairs to unit. 6. Since your unit is just a little more complex than a LCD MONITOR, have toy viewed on YOUTUBE short video clips of "LCD monitor disassembly" or "LCD monitor repair" for the most common cause of BLACK screen complaints? If further assistance is required do additional post to original. 12fixlouie aka louie12fix on fixya
Dec 05, 2009 | Samsung 153b-sliver (Silver) 15 in. Flat...
Need to get a new power supply for my samsung monitor
you first look the watt on the power supply and if same watt power supply is available then connect because power supply has overload protection it will not work also look the connecter is matching if not then purchase only original power supply dont chase the duplicate it will consume more money
Nov 20, 2008 | Computers & Internet
Power Supply for Cornea CT1700 LCD Monitor?
cornea lcd monitor, Monitors Projectors, Computers Networking items on ... Power Supply Adapter Cornea CT1700 LCD Monitor (12V 5A) $18.99: 12vAdapters Dot Com ... Items that are listed in a currency other than U.S.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Cornea CT 1700 17" Flat Panel LCD Monitor
Monitor is blank
You either have a bad inverter board in the unit or a lamp problem, also there are known issues with these units having bad capicitors in them. It is more fesable to replace it then repair it sorry :-(
Sep 15, 2007 | Polyview V17E 17" LCD Flat Panel Monitor
Televison & Video Logo
1,063 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
