Question about Daewoo DTQ-13P2FC 13" TV
JVC d series - v-chip
I don't have the code to the vchip How can I reset
Tip
Toshiba 42HP95 VChip Reset
Toshiba 42HP95 Plasma TV VChip Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV Parental V-Chip parental lock?
Have you forgotten your VChip PIN, passcode or password?
If you forget your V-Chip passcode, you can view the locked TV without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The VChip passcode will be reset and you can enter a new passcode if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
Tip
Toshiba 50HP95 VChip Reset
Toshiba 50HP95 Plasma TV VChip Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV Parental V-Chip parental lock?
I hope that helps.
Download Toshiba 50HP95 Plasma TV Manual
Vchip reset? Inputs won't show HDMI input option. Floor model TV model# av-48P786 sn#13090154
Hello
If a power interruption occured to your household power supply, V-Chip has to be resetted. To reset the V-Chip do the following.
Channel guard and V-Chip settings are protected by a four-digit lock code. Your TV comes
preset with a lock code of "0000". You may change the code to any four-digit number you wish.
To change the lock code, follow the steps below.
Press the MENU button
To SET LOCK CODE use UP/DOWN buttons.
To operate (lock icon appeares on pressing =>/ Press ZERO to access the lock code
The first digit will be highlighted
Use =>/<= button to
To select the number
Press Up/Down button to
To move to the next digit
Continue to follow these directions for all four numbers
Press the OK button to finish (your lock code is now set)
Press the Menu button when finished
OK. Thanks for using Fixya.
Apr 07, 2011 | JVC Televison & Video
Need to reset v-chip code JVC t.v. vcr combo 2000
I got a jvc tv-13142 at a pawn shop but some of the channel is blocked and i need a vchip code to unlock it i try all zeros and it show error how do i reset code
Jan 22, 2010 | JVC TV-13142 13 in. TV/VCR Combo
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 42HP95 Television
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
How do i take the parental code off of my Mitsubishi WS-65615 65" TV?
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Jan 07, 2010 | Mitsubishi WS-65615 65" TV
Mitsubishi 1080 rear proj. tv
I can help you unlock your Mitsubishi HDTV V-Chip, but you will need an 'original' Mitsubishi remote control for the fix to work.
I hope that helps.
Feb 18, 2009 | Mitsubishi WS-65515 65" TV
Daewoo DTQ-13P2FC 13" TV Logo
145 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
