Replacing Canon PC720 Toner cartridge change
I got a Canon PC720 copier at a garage sale - the toner cartridge in it is almost empty. I have another cartridge, but I can't figure out how to get the old one out - when I tilt open the top, I can see that there is a large piece of plastic holding it in place.
I tried to wiggle all sorts of parts, but no luck - I don't want to use.
I have a photo of the inside of the copier - if you give me eMail address, I can send you a scan - that may facilitate discussion.
Thanks - Ulf
Not sure if you found this out yet.
The cartridge just slides out. When you lift the latch you will see the cartridge has lifted too. All you need to do is pull the cartridge toward you. It slides right out.
Posted on Feb 25, 2008
6ya staff
SOURCE:
I just changed the toner in my Canon Copier PC720 & now all of the copies are dark & there's extra toner on the paper
Hello, Heather -
Your toner and printing problems MAY be due to a dirty printer drum.
The instructions here may be helpful regarding cleaning the printer drum:
http://smallbusiness.chron.com/clean-canon-copier-drum-55783.html
I suggest first you read through the instructions completely so you will know what protection you will need to use and what supplies you will need. Toner can easily get all over everything on which you don't want toner. Note: I suggest you put on an old shirt or smock or apron so that any errant toner doesn't get on your clothing.
This is the link to the Service Manual for the Canon PC720, a PDF document (Adobe Acrobat Reader software needs to be installed on your computer - free) you can download and save to your computer for future reference:
https://www.manualslib.com/manual/457679/Canon-Pc720.html
Pages 144-145 (4-28 throug 4-29) of the manual contains some cautions regarding cleaning the drum.
Best wishes.
Jun 29, 2018 | Canon Office Equipment & Supplies
REPLACED THE TONER CARTRIDGE WITH A REFILLED ON AND GET THE ERROR MESSAGE "SYSTEM ERROR F2-70"
Most Copier Cartridge have chips on them that tell the copier I am new, Replacing the toner/refill, does not change the chip info as long as the chip says I am empty its empty to the copier, replace the cartridge with a new OEM cartridge.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 17, 2015 | Sharp FO-2081 Copier
PC 921 toner light on. Replaced toner cartridge, light still on: won't function.
You see these machines needs to be kept very well.
1. the machine is not sensoring your toner.
a) need for the machine to be serviced it probably has a lot of spill toner inside.
b) toner empty sensor is not positioned properly.
b) the toner empty sensor is not functioning properly and needs to be changed.
Jul 14, 2011 | Canon PC-921 Black and White Copier
Error low toner canon mf5870 nd
> low toner
It means that the toner-cartridge, which holds the dry toner-ink, is nearly empty.
Remove the toner-cartridge, and gently roll it from side-to-side -- DO NOT SHAKE IT.
Replace it, and use it, until it's completely empty. Then, buy a new toner-cartridge.
Jun 06, 2011 | Office Equipment & Supplies
Canon monochrome laser LBP3108b printer cartrige can be refill?
I would not advise on refilling a toner cartridge, the toner power is very fine and you do not want to breath in this toner powder.
You can purchase a new toner cartridge or a recharged toner cartridge these are cheaper than a new cartridge.
You can get a few more print pages out of a empty toner cartridge by shaking the toner cartridge in a horizontal position and inserting back into the printer.
Dec 04, 2010 | Canon LASER SHOT LBP-2900 Printer
Change toner cartridge , how do i
Open front cover, realese the blue toner handle, pull out toner unit, put toner crg. on top toner unit, so that arrow poits to copier. Press it and then will pop out tape wich you pull out, not to the end, when it does not go further it is OK, push back the plastic cover that got out, this will realese toner crg.Remove empty toner crg, push back toner unit and lift handle.
NOTE: when toner is empty machine guides you how to change toner on lcd display, you just need to look and press next.
Jun 30, 2010 | Canon imageRUNNER 2200
My toner was low, so I replaced it...it printed one page and now won't copy or print (cannon multipass mp730)
If you changed the toner cartridge before the previous one was completely empty, it is possible the machine simply did not reset.
Turn the power off and take the new toner cartridge out. Turn the power back on and wait for a message telling you there is no toner.
When you get the no toner message re-insert the new toner cartridge.
If this does not clear the message, you will need to find the button to press to manually reset the toner cartridge from Canon.
Thanks,
Pat
Apr 26, 2010 | Canon MultiPASS MP730 All-In-One InkJet...
How to change canon ir400s change waste toner
the waste toner is inside of the drum cartridge it should have a plastic cap you can pull off and empty it
Apr 07, 2010 | Canon imageRUNNER 400S Copier
Replacing toner unit
i have a lot of quantity cartridge . open your copier front door and out the cartridge.Have your side any hp 1200 printer cartridge part no 15 change drum shatter put your old d320 cartridge then solve your problem
please send me success result
Jun 25, 2009 | Canon imageCLASS D320 All-In-One Laser...
536 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
