Question about Sony Ericsson W850i Cellular Phone
White screen syndrome
What are the signs of a failing LCD?
  • Anonymous Mar 10, 2009
    Do you have datasheet of the display for Sony Ericsson w850? I'd like to know the pin assignment of the connector.
  • Anonymous Mar 12, 2009
    white display problem
    Problem Solver:
  • 8 Answers
Like other LCD display screens for computers, the failure can be a hardware failure of the screen itself or a poorly connected or faulty ribbon cable inside the device. Perhaps you've already considered having the telephone professionally repaired by the manufacturer or an after market cell-phone repair shop. If you ruled that out because of the cost, and have looked for and received help to ensure there is not a software setting or screen adjustment or reset-to-factory fix for this, then you could be brave or foolish and go ahead and open up the device on your own. If the device is out of warranty and you want to give it a try, and you are about ready to throw away the device anyway, you are a candidate to attempt you own device repair. Get a size 0 and maybe also a size 1 Phillips screw driver from a hobby store or model railroad store or electronics supply store. Power off the device. View the service manual if possible, perhaps by asking for a schematic or device diagram or "exploded diagram" from the manufacturer or by asking at the library, which subscribes to many services that provide device schematics. Print the pages that show how to open the case. Print the pages that show how the small cable connects from the display screen to the circuit board. Open the access cover for the battery and remove the battery and any sim card or SD memory cards. Check for and pull at any rubber spots or rubber dots to see if a screw is hidden under the rubber spot or rubber dot or pad. Unscrew the small screws around the edges of the device a bit, just loosening them each a little. See if the case is beginning to open. Proceed to open the case while sitting or standing at a clean flat well-lighted work surface that is not near a sink or any drains. Make a drawing of the device and show the spots where you remove the screws. Access and check the small cables and see if you can make the connection more secure by pressing the delicate ribbon cable a bit further into the connection on the circuit board. Amazing it is, that the little thin and delicate connection even works at all. Write down the part numbers you can find and take a few pictures as you proceed, and if you succeed it getting it all put back together and it works, then it was just a problem of a loose connection to the display device. Share the results here or on your own website or other repair forums; many will be delighted to learn of your success. If you want to have a service shop try to fix your device, you might ask any cell-phone sales shop personnel where phone parts are available, such as a replacement antenna for your phone, then perhaps also ask if they do device repairs on site. You'll learn that a repair shop fixes several brands of phones, as the insides, the components of many devices are actually rather similar. I looked up cellphone repair and the telephone area code where I live and I located some repair shops immediately using a web search of the Internet. In Phoenix, Yakety Yak Wireless and Wireless On at 742 E Glendale Ave, Ste 120, Phoenix Arizona 85020 both provide some cell-phone repair.
Finally, check with the manufacturer about putting the telephone back under a post-purchase manufacturer warranty; some companies will let you do this and then provide the repair. Other companies require the repair be completed and paid for and then may have an option to add an extended warranty after the device is fixed. Does not hurt to ask and to get the details.
Here's wishing you well!
Posted on Oct 11, 2008
  • 53 Answers
Hi, clive
The problems you will get with a failed lcd is that the screen will light on/off bit like flashing lights the letters on lcd will sometime have line across the screen or some numbers will be missing also the signal on your phone network bars will drop can not make any calls freeze up that sort of problems you will experience with a faulty lcd screen i hope that helps you to identify your solution
Posted on Jan 15, 2008
Is there a recall on the mitsubishi dlp chip wd-65735 and are they replacing them free
Nope,,,White dots, white snow or sparkling stars on your DLP TV mean only one thing - a worn out DMD chip. The white dot syndrome seems to happen when the DLP TVshave been in use anywhere from two to five years - usually when the warranty has expired
Certain brands seem more vulnerable than others to the white dot syndrome. Samsung and Mitsubishi DLP TVs have been plagued with the problems for several years now. Sony and JVC choose to take the TVs set off the market in response to complaints from disgruntled owners.
If you read the various forums offering solutions, you'll see customers being given quotes of $600 and upwards for solving the white spot syndrome or replacing the DMD DLP chip. Fortunately, there are companies offering the offering the DLP chip for under $230 if you want to fix it.
Dec 31, 2017 | Mitsubishi Televison & Video
Bravia KDL-52WL135 color snow mixed into picture
Can you post a picture that shows what snow issue is that youre experiencing that would help with diagnosis
Aug 07, 2012 | Sony BRAVIA KDL-52XBR6 LCD TV
Bought a used LP2207 (that had been tested by the store) and it worked the first evening, but the next morning the screen flickered white with some colored streaks and then stayed all white. None of the...
That is the sign of failed T-CON board or bad DC feeding it from the logic board.
More likely to need new LCD panel, I hope you can take it back.
See my pictures to see if that is what you are seeing on your screen:
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 12, 2011 | Gateway FPD2275W LCD Monitor
Hi i recently started having problems with my dell inspiron 1545 screen. At first it started to freeze and fade to bright white, eventually after a few days it became stuck white even after booting the...
Hi lewis haywar,
Try to replace the LCD inverter in your laptop. Most common issues on LCD are due to failing LCD inverter. It fails more often than LCD cable or LCD backlight does.
Please let me know if this solution helped to resolve your issue.
May 11, 2011 | Dell Inspiron 1545 Notebook
Screen has gone White, phone is still recognising use of buttons-alcatel Amsterdam orange phone
NOT a good sign - if the screen has gone ALL white then the White LED that send light into the screen is shining through the Liquid Crystals which usually means a layer is broken.
The LCD screen has 3 layers of crystal that are voltage sensitive and shine blue,green, yellow etc.
White light usually means a layer has broken. -- Sorry , hope it's under warrantee.
As a rule of thumb , the cost of replacing the LCD is the same as the Phones 2nd hand value on Ebay -- Ray
Jan 22, 2011 | Cell Phones
Screen is disclored.Shows pink instead of white.
Possible bad connection on the LCD cable. Check and reseat the cable on both end( the cable to the laptop and the cable to the LCD panel). If that doesn't work you will need to replace the cable.
Jan 15, 2010 | HP Pavilion dv2000t 14.1" Notebook Laptop...
Raymarine E120, after 4h on display went dark in
blubaju, probably cold-cathode-fluorescent-lamp backlight failure! if unit dosen't have electro-luminescent style backlighting. All LCD panels require WHITE light to see what is on the screen!!! Is same common problem that computer (pc) lcd monitors suffer from!!! I suspect that if your unit has CCFL's, that the SMPS power supply or CCFlamp INVERTER circuit has a problem common to ALL LCD monitors. I should think that any BIG TIME tv/monitor repair shop could examine the printed circuit boards and effect a repair for you! Just mention that you think it suffers from the BLACK SCREEN of DEATH syndrome!!! Also mention that to RAYMARINE!!! when you call them and **** them out!! 12fixlouie .5hr nrth/wst of Windy City Rate this on fixya if this msg helpful??
Nov 16, 2009 | Raymarine M1500 15 in. Flat Panel LCD...
I have a white strip approx one inch wide down the left hand side of the screen on my Toshiba P100 laptop. What causes this, and is it fixable? Thanks.
Usually this is a sign of a failing LCD or a bad ribbon cable. Try to reseat the cable in the back of the screen. If that doesn't cure it, then I'd recommend looking for a new screen.
Jul 18, 2009 | Toshiba Computers & Internet
My screen is white but the rest is fine
So, my guess is you may have dropped you phone recently?
The sidekick lcd connector comes loose sometimes and causes the white screen.
Follow the guide at the link below and you can try to reseat it yourself.
Fix a White screen on the Sidekick 3
Failing that, you can buy a new screen and install it. They are like 30 dollars.
Here is a guide for that
Sidekick 3 LCD screen replacement guide
and here is a link for the lcd screens
Sidekick 3 LCD Screens
Jul 12, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Screen goes blank after being on for a while
if it goes black but the light is still working the dlp chip is failing this is like a small lcd screen that the light use for the piture to work looks like this http://www.fixyourdlp.com/2012/04/24/the-affordable-solution-to-white-dot-syndrome-on-your-dlp-tv/ hope this help you.
Jan 30, 2018 | Samsung DLP HL-P5663W 56" TV
Sony Ericsson W850i Cellular Phone Logo
207 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
