Question about Xerox Phaser 8500/DN Printer
Error code I keep getting an error code of: 07,101,43,6702. Can I correct this myself?
    President:
  • 2,072 Answers
That is a print head position fault.
The stainless steel print block that holds the print head shaft may have ink in it not allowing the print head to pivot back and forth.
There may be one of the cables keeping the print head moving freely.
The machine was powered off or lost power and the wiper is stuck between the print head and the drum.
You pretty much need to take the covers off to determine the problem. And it may require removing the print head itself. I would not recommend that.
What you can do to prevent the problem in the future is make sure the printer is level front to back and side to side.
There is a possibility that the print head itself has failed, but that is the least likely problem, albeit possible.
Posted on Jan 14, 2008
Trouble shooting codes
Code Error 53 is "defective outdoor sensor" error.
source: search engine keywords - Code Error 53
I am not familiar with this particular thermostat; however, here's some general t-stat information; I hope this solution will help you troubleshoot.
Multiple Thermostats set in 1 zone will conflict; the one with the lowest setting will be the determining Thermostat for the group. Here's an option you can try yourself; my solution is 'hard reset' the thermostat - afterwards, i'm outta options. invest in external thermometer battery/natural types; & manually turn t-stat ON or OFF; Additionally, keep an eye on how much draw your AC is doing on your meter.
disable auto & enable manual; however do NOT change settings or power-off t-stat. I'd keep it on what you had intended it from day1. However, some may debate to turn everything off beforehand. personally, myself, poweringOFF the switch connected to your t-stat works. Remove battery and reinsert inverted; wait (5sec-1min); remove; wait 1min ('debatable' timeframe 5sec - 1min); reinsert batteries correctly; if you have a programmable thermostat; do the same with the hit 'reset filter' held down & wait 5-sec1min; observe roomTemp reading. May I suggest to keep an extra thermometer around to determine if temperature reading from the thermostat correct? Friendly reminder to turnOFF 'auto' mode during this hard reset. If reset requires reprogramming your t-stat, do whatever required to set your desired setting. cheers. best of luck.
Apr 12, 2014 | Honeywell Programmable Thermostat Heater
Canon ir 2830 coding out to E000007-0000 - what can correct this can I do it myself
CANON IR 2830 ERROR CODE e0007-0000 SIR PLEASE SOLUTION MY ERROR CODE
MOB.9636327398
EMAIL-M.KCOMPUTER31@GMAIL.COM
Mar 14, 2011 | Office Equipment & Supplies
I am getting a Hardware Error Code 0502 when I print and the printer stops. What can I do to correct this?
Hi there
Dell error 0502 is lots of this
On the multi function machine seems to be a coating on the metal rod that the cartridges travel on. Just wipe this rod with a Kleenex and the problem seems to go away.
Somehow it presents a drag on the cartridges and causes an error.
Myself I would put a little bit of oil after on a cloth and wipe along the bar.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Oct 22, 2009 | Dell A960 All-In-One InkJet Printer
Error code F2 keeps beeping! Will not reset. Any
thats the oven sensor , replace the sensor and your good to go
Jun 17, 2009 | GE JKP27 Electric Double Oven
Sears He4 has a code F11
Here is what the code means.
F/11 Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
Good luck and Please Rate FixYa!
Jan 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Errore code E 7
Hi p_brooks
E7:
01:DUPLWX MEMORY PROBLEMS
02:LASER PROBLEMS
03:LASER PROBLEMS
10:CCD BLACK CORRECTION SHADING PROBLEMS
11:CCD WHITE CORRECTION SHADING PROBLEMS
12:CCD WHITE SHADING PROBLEM
16:LASER PROBLEMS
thanks
Hamedo
Nov 22, 2008 | Sharp AL-1451 Laser Printer
Error message DC1560
This code shows that paper feed is jam in left side.just check any paper is jammed in this side.or sensor liver is pressed in paper path.by MIAN JEE
Nov 17, 2008 | Kyocera KM-1505 Copier
Original x box console has red ring
you interrupted a dashboard update or you modified your console and didnt do the dashboard install correctly. error 16 means dashboard failure.
Nov 08, 2008 | Microsoft Xbox Console
Xerox Phaser  8500/DN Printer Logo
75 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
