Question about Maytag Performa PAV2200
Keeps filling up even when full for over 4 hours (never changed cycles)
I started a wash cycle at 11 pm and set it on 10 minute wash. At 4 am i heard it running. It was fvery ull and still filling AND was still on the 10 minute mark. It was aggitating. We manually changed it to spin and the water spun out. We turned it off manually, so i'm not sure if it would have keep spinning or not. curious about the timer mechanism function or something else?
    Scholar:
  • 196 Answers
The timer sends a signal to the water level control valve. This valve serves two primary purposes. 1. Activate the water valve to fill the machine. 2. Shut the water flow down and allow the machine to operate. Try running the machine again. If the water continues to enter the machine after it begins aggitating then shut the water off at the spigot. Now watch and see if the timer moves or not.
If the timer does not move at all then I would replace the timer. If it DOES move then another problem exists and will need to be addressed.
Posted on Jan 13, 2008
LG Turbodrum DD 8.5kg WT-R852 washing machine, will not completely fill with water to water, to initiate the wash cycle, wash process stops there.
THE WASHER IS OBVIOUSLY HAVING A PROBLEM DETECTING THE WATER LEVEL? IT DETECTS AS FULL WHEN ITS NOT AND THEN GOES INTO DRAIN CYCLE? THE FILLS AGAIN? I would suspect the water pressure switch but if it was detecting a full cycle it would sent it into wash cycle? the water inlet valve only allows the amount of water it is told to send in and does not control the amount or drain cycle. Im not sure here but Im thinking maybe the water level switch may be flawed, the one that has low-medium and high? all these can be checked with a multimeter
Mar 01, 2015 | LG Washing Machines
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 17, 2014 | Washing Machines
WATER IN WASHER WONT SHUT OFF
Hi and welcone to FixYa. I am Kelly. When water wont shut off no matter what you do the problem is inside of the water valve assy. Usually there is a small bit of debris in the diaphram center hole that is holding the water passage open.
Here is what you can try to do to clear if BEFORE replacing the eater Valve.
1. Get a bucket
2. Turn off both water supply hoses momentarily
3. Set the water temp to warm
4. Remove ONE hose from the wall connection and place the hose in a the bucket.
5. Turn on the remaning connected hose/
6. Start machine fill cycle and tap the hose connection at the water valve on the back of the machine with either a screw driver or hammer handle.
Timer OFF
REVERSE HOSE CONNECTIONS ON THE WALL CONNECTION.
7. Place the other hose in the bucket
8. Start Fill cycle.
9. Again tap the hose connection at the water valve
10. Stop timer.
11. Reconnect both hoses and test for water flow with timer off.
12. Start fill cycle
13. Rapidly select hot and cold wash water.
14. STOP fill cycle.
15. Remove each hose individually from the water valve one at a time.
16. Use a knive blade and remove the inlet screen from the water valve. Wash screen under slowly running water rubbing it clean with your fingers. Re install screen. Reconnect water hose.
17. Repeat step 16 for opposite hose and screen.
18. Turn on water supply.
19. Test for proper filling and water stopping by starting and stopping fill cycle.
If it works you got lucky. If you still have the problem you will need to change the water valve. Either one of these water valves will work on your machine:
http://www.repairclinic.com/Appliance-Parts?s=t-PAV2300-%3d%3dc292d509361
Thanks for using FixYa.
Kelly
That is about it
Jun 05, 2010 | Maytag PAV2300 Top Load Washer
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
How to set kenneth cole unlisted digital watch with 4 buttons
OK I'll do my best to describe the procedure...
Part 1:
Press mode button till the seconds window blinks
Press Lap/Reset button once to make minutes blink
Cycle through minutes using Start/Stop Button
Part 2:
Press Lap/Reset button once again to make hours blink
Cycle through hours using Start/Stop Button
(for this part, it's a bit tricky. Hours can be displayed in AM, PM, or 24 hour duration. AM is represented by "A", PM is shown with "P" and 24 hour mode is shown with "H", so keep an eye in the seconds window when setting your hour so you know for sure if you have the right hour)
When your done setting minutes and hours, press mode button again till you get to main screen
A helpful hint is to remember when setting up anything in this watch, mode will cycle through the different screens, lap/reset will change the value of whatever your modifying (AKA minutes/hours) and start/stop scrolls through the different fields.
Hope this helps. Sorry if it's confusing, best I could do.
Sep 28, 2008 | Watches
Relic digital watch
Hold down the reset button until the hour digit starts to flash then to change the hour press the start/stop button then to change the minute press the mode button and keep pressing start/stop button until you get to your desired minute and just continue those steps through the date.
Oct 12, 2007 | Watches
Washing Machines Logo
144 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
