Question about Microsoft Xbox 360 Console
Xbox 360 i had a problem with my disc drive open and closing. I purchased a new toshiba, same model that was in the console originaly. now i get and error saying to put a cd in xbox console. I was told by the place i bought it I must flash the new disc dive to the console. I have no idea what that means or how to do it
    President:
  • 4,402 Answers
· http://www.llamma.com/xbox/Repairs/xbox_dvd_repair.htm
Posted on Jan 14, 2008
Tray won't close
Use the following steps to close the disc tray on an original Xbox 360 console.
Step 1: Remove the disc from the tray Step 2: Make sure the faceplate is on correctly
The faceplate is the plastic piece on the front of your console.
  • Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
  • If you find that the faceplate is the problem, please contact Xbox Support to order a replacement faceplate.
If this does not resolve your issue, please try step 3. Step 3: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray successfully closes, open the tray and insert a disc. Now try opening and closing the tray with a disc in the tray.
Note Make sure that the disc isn't sticky and doesn't have any labels that could prevent the tray from closing.
If your disc drive still will not close, please try step 4. Step 4: Move the disc drive tray
  1. Gently move the tray up and down, and then from side to side.
  2. Press the eject button on your Xbox 360 console.If your disc drive still will not close, you need to have your console repaired.
  3. Step 5: Request a repair If the disc tray still won't close properly, your Xbox 360 console needs to be repaired.
Xbox 360 S consoleUse the following steps to close the disc tray on an Xbox 360 S console. Step 1: Remove disc from the trayIf there is a disc in the disc tray, remove the disc. Step 2: Press the eject buttonTry closing the disc tray by pressing the eject button. If the disc tray closes successfully, open the tray and insert a disc. Now, try opening and closing the tray with a disc in the tray.
If the disc tray still will not close, please try step 3. Step 3: Move the disc drive tray
  2. Press the eject button on your Xbox S 360 console.
If the disc tray still will not close, you need to have your console repaired. Step 4: Request a repairIf the disc tray will not close, you need to have your console repaired.
Dec 16, 2010 | Microsoft Xbox 360 Console
XBOX 360 Elite won't play disc; says "reading" then "open tray".
If the console has never been opened to change the dvd drive then eather your laser lens or one of the 2 motors in the drive needs to be changed. 90% of the time its the laser lens. You cant just use any laser for the xbox 360. There are 3 different drives. Toshiba, BenQ, Samsung, so you have to see what drive model you have before you try to order one yourself. I repair these often with 99% success.
Jan 24, 2010 | Microsoft Xbox 360 Elite Console - Black
Well it won't read any disc and the tray keeps opening and closeing
Does it say it keeps opening and closing or does it literally open and close if so its probably something wrong the motor acting or somthing inside of the disc drive if thats the case then i'm sorry to say but you might have to get a new disc drive. If your 360 is under warranty send it into microsoft if its not under warranty go online and find a disc drive but make sure its the same one you have currently inside of your 360.
Have you ever had to replace that disc drive before or no?
if so then your disc drive is the wrong one for that 360
Jul 01, 2009 | Microsoft Xbox 360 Console
My xbox 360 doesn't play my games
the lens of the disc drive needs a check up...
May 29, 2009 | Microsoft Xbox 360 Console
XBox 360 disc tray open
i have the same problem i called xbox and they said that it needs a new disk drive and it would be 100.00 so if you want it fixed youll nedd to call 18004myxbox and they will give you all the info on were to send it or for 100.00 more you can buy a new one like i did
Apr 28, 2009 | Microsoft Xbox 360 Arcade
New XBox 360 putting scratch in games
the problem is the disc drive.
you have to open it up and put some stick foam " like a sticky strip of foam, insulator : on top of the drive .
the problem is that the disc touches the laser assembly while turning cheating a ring on the disc.
i can fix your games as well as the disc drive if you feel like is to complicated.
Jan 02, 2009 | Microsoft Xbox 360 Console
Xbox 360 console
I had the same problem, thats a faulty drive, I could be that the heatsink under it is so hot that is making the drive faulty, So you'll have to open your xbox a put something between the heatsink and the drive. But if that doesn't work then you'll have to replace it with another drive and transfer the old firmware to the new drive so it can work on your xbox.
Aug 20, 2008 | Microsoft Xbox 360 Console
Error Message
Be sure to wipe clean around inside hole on 360 game disk it has info laser scribed that tells the system what game it is.It might also need a laser adjustment.
Dec 26, 2007 | Microsoft Xbox 360 Console
Wont read the disc
Soryy to hear about it guys. no really at home solution but you can call the experts the number is 1-800-4myxbox they will try to fix your problem and if they cant they will repair it. Hopefully this helps and i hope you get to gaming soon :)
leave feedback please
Dec 25, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
