Question about Sewing Machines
Threader head automatically threads the needle- i need to buy one and i can't find a place to purchase it from
  • nyachi Apr 28, 2008
    the part where the needle goes up and down just fell down as i was sewing also the little curved metal fell as well (where you put the thread through before you put it through the needle whole, im not sure but i think its missing a screw. where do i go to get it fixed?
  • Ishanlei Jun 24, 2008
    My automatic threader broke off. My daughter broke it off and I was able to glue it back on for a while but it came off and this time I can not glue it back on. I am trying to find out where I can get a new one and put it on so I can sew again. Its hard when you don't have it.
    Penny Smith
    Master:
  • 619 Answers
Try to visit web site : www.acesewvac.com
Posted on Feb 22, 2008
The automatic threader wont pick up and thread needle. Can do manually but thats not easy?
to make manual threading of a needle easy buy a needle threader
it is a instrument that has a very fine piece of wire in a loop that you push through the eye of the needle , put the thread in that loop and pull the loop back out of the eye and the needle is threaded
available from most any shop that sells material , cotton , thread or sewing machine shops
cost --pack of 2 for $1.00 or there abouts
Oct 05, 2016 | Sewing Machines
Top thread is shredding Automatic needle threader stopped working
If the top thread is shredding it is usually because the needle and thread are not compatible. If thread is too large for the eye and the thread groove, the action of sewing will cause the thread to shred as it pieces the fabric.
Try a different needle and thread. Here's an excellent web site:
All About Needles
Sep 27, 2015 | Sewing Machines
I cannot get the CE-250 automatic needle threader to work. Threader and needle do not align up together.
Always make sure you rotate flywheel to raise the needle to its highest position before trying to use the threader. additionally the correct needle has to also be used so the threader wire and needle eye line up properly.
Cheers,
Embroidery Services
San Diego, CA
Sep 17, 2017 | Singer Sewing Machines
Auto Needle Threader Won't Come Down
If it's still in warranty, send it in for repair. If it's not still in warranty, pull out a length of top thread and clip off the end with sharp scissors at an angle. Poke the end of the thread through the needle eye -- it should go through easily. Two second solution.
Jan 09, 2014 | Singer 3116 Simple
Bernina virtuosa 155 solutions
Needle threader heads are actually easily replaced and should be replaced anyway every few years because they do wear-out. Get a magnifying glass and, having returned the needle to the top (use the foot controller, so that the machine stops it in the right place), pull the needle threader down until the head rotates towards the needle. Look with the magnifying glass to see if the small hooked part in the centre of the threader head (the light grey plastic part) goes through the eye of the needle - if not, you might be able to bend it VERY carefully so that it does - that should cure it. If the hook is a long way above or below the needle eye, dont try and bend it, the cam that rotates the threader has probably moved on the needle bar and will need adjustment by a service agent. If the hook is passing through the eye of the needle OK, but still not pulling the thread back through when you release it - i.e. the thread is just slipping-off, the hook has become rounded through normal wear and you'll have to replace the threader head. The threader head simply pulls off - you might need to carefully lever it off the round shaft. Replacing it is a matter of simply putting the new one on the shaft and pressing upwards firmly so that the grooves in the threader head go right up to the horizontal pin on the threader shaft.
Dec 12, 2011 | Bernina Virtuosa 160
AUTO THREADER CAME OUT
When you activated the threader, the needle was down and the threader came off or broke.
If it is not broken, you may be able to push it back into place.
Turn off the power and tip the machine back on some towels so it does not slip and with a flash light check the area where it fits and see if you can get it back into position.
If not, will have to thread the needle the old fashion way.
Check with your Brother dealer to see if they can look at the machine while you wait.
They may be able to get it back together or they will have to replace the threader.
It is possible they will have one in stock, or they may have to order it.
May 01, 2010 | Brother CS-8060 Computerized Sewing...
How do I theard the needle on the 5050C singer machine?
does the machine have a needle threader? first if so, pull it down and put the thread behind the left side of the threader and loop the thread around toward the needle then go behind the finger of the threader hold the thread back against the needle and slightly pull upwards pull the threader forward and gently let go with the right hand of the thread and the needle will pull the thread through, second if the machine doesn't have a threader, the easiest way to thread a needle is to buy a needle threader, it is a device that you put through the eye of the needle and put the thread through its hole then just pull the threader back out and the needle is threaded.
Aug 22, 2009 | Sewing Machines
Broke the hook off the automatic needle threader
You can get a new (grey) threader inexpensively that pushes on the bottom of the threader shaft from a dealership. Easy to do it yourself or they can do it in 5 or 10 minutes. Try taking the old one off and looking at it. It pulls right off.
Nov 22, 2008 | Bernina Virtuosa 150
I can't thread the Shark Euro0pro 384 unng the automatic threader
You need to check to see that there is a small hook going through the eye of the needle when you use the threader. A flashlight or bright light will help. So will a magnifying glass. If it isn't, then no amount of trying will help.
If it goes through the eye, you need to see that your thread hooks into it so that the thread can be pulled through.
sewman7
Jun 08, 2008 | Euro-Pro Shark 60 - 384
Automatic Needle Threader Doesn't Work All The Time
Needle threaders are generally finicky things. Check to make sure the needle eye is at the correct height for the threader to connect. Gently pull down the threader and wiggle the handwheel slightly to get the needle eye where it needs to be. The threader may have been been bent or slightly rotated so it doesn't connect properly. Also, if you are not aware, a needle threader will usually not work on needles smaller than 80/12 because the eyes are too small.
Admittedly, a needle threader is a very nice function to have. If you find it will not work, there are some things you can do to make manual threading easier. One hint I found that works well is to lick your finger. Swipe it across the back of the needle eye. Then begin with the thread end immediately above the needle eye and gently slide it down to the eye. The needle usually has a tiny groove above the eye that helps guide the thread. The thread tends to jump right through.
Feb 13, 2018 | Necchi 3620 Quilter Mechanical Sewing...
Sewing Machines Logo
107 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
