Question about Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher
Bosch SHY56A05UC Drain Pump Replacement
I believe my Bosch dishwasher SHY56A05UC drain pump is failing. If I pull the dishwasher out with the help of gravity it drains, but when you put the dishwasher back in it doesn't drain at all. We've already flushed the line so we know there is no blockage. I have found the replacement parts. How easy is it to replace the drain pump on your own?
Any advice/tips would be appreciated.
  • mlmmom1220 Aug 28, 2012
    I already had the drain hose replaced..not the problem unfortunately.
It's not easy. I just look at my sister-in-laws and I think the tub needs to come off. I plan on working on it this week.
Bruce
Posted on Feb 25, 2008
6ya staff
SOURCE:
Bosch dishwasher does not drain water and does not run
Bosch,. like many others have a "safe: cycle where the machine will always do a short pump out before it starts any cycle. If it fails to do a pump out even if there is no water in the machine, the machine will go into safety mode and will not allow a program to start. You will have to pull the machine out and check if the drain hose is blocked or kinked, and that the drain pump is not blocked or jammed. Toothpicks, bits of food and broken glass fragments are good for blocking / jamming dishwasher pumps.
Mar 09, 2015 | Bosch Integra 300 Series SHX33A05UC
My bosch dishwasher will not drain and makes a humming noise
Humming noise is an indication of your drain motor getting power but not spinning. Either your drain pump is defective and needs to be replaced, or something is stuck in the pump preventing it from draining out the water. Either way you will have to take the dishwasher out and get at the pump from the bottom of the machine.
Jan 31, 2011 | Bosch SHX4AP05UC Dishwasher
How do you check for error codes on a Bosch SHY56A05UC/23 Dishwasher? My dishwasher runs continuously in the drain mode and the "cancel drain" feature does not work.
what is happenig i believe and has happened to me 2 times is that the water level float that is on the left side of dishwasher is stuck.
Either remove side panel and flick lever or pull dishwasher out and tap lower portion of panel and this will cause the level to move and then see hat happens
Jan 29, 2011 | Bosch 24 in. SHY56A05 Stainless Steel...
Water in bottom of bosch dishwasher will not drain. How do I get this water to drain
Hi
Dishwasher not draining issue occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. To access the drain pump, please follow the procedure---
1. Drain pumps are mounted to sumps in the front of dishwashers --they're easily accessible from the front of dishwashers by removing toe kicks.
2. Tools needed: small flat blade screwdriver (for unlocking terminals).
3. Remove toe kick/base cover, pull up terminal cover and disconnect wires (using screwdriver to unlock locking terminals).
4. To remove pump, pull latch (on circular collar) & rotate pump clockwise (cw).
5. To install new pump, insert @ 2:00 position & rotate counterclockwise (ccw).
6. Clean water & debris from base, then check float operation.
7. Connect wires, then install base cover & toe kick.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jan 26, 2011 | Bosch SHU9915UC Dishwasher
THE WATER WILL NOT DRAIN OUT
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 14, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
The water is not draining from the bottom of the dishwasher
Kevin
Dec 12, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Have a Bosch shy56a05uc dishwasher that suddenly stopped working to a point. I believe it is related to the door latch switch, because I don't feel the door securely latch shut when I close it, and I also...
Does your dishwasher electronic control or mechanical timer? if mechanical timer, I encounter a similar problem n change the mechanical timer. that problem solved.
Prince P
Jul 23, 2008 | Dishwashers
Wont drain!!!
Check first the drain lines and the drain pump.
If the drain pump is working, and there is no problem in there, then the problem is usually because the water level switch activated by the floating sensor is stuck.
You probably need to have the water level switch replaced.
You can find parts on websites below:
You can find replacement water level switch , and schematics on websites below:
BSH - Bosch Customer Service
Appliance411: Repair Parts
how to mend it .com - ~~ Wiring diagram for BOSCH Dishwasher.
Jan 06, 2008 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Bosch SHY56A05UC/14
There is a pass through the lower back side of the dishwasher that also has a restraining device to prevent drain hose from being pulled off of drain pump. After passing hose through this opening, connect hose to drain pump. Note: there is another restraining device built into lower plastic housing which has a finger notch to accept hose and keeps the drain hose engaged in to drain pump by not allowing hose to back out of drain pump/ hose interface.
Dec 01, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch Dishwasher wont drain
have you removed the filter? if it gets clogged the dishwasher wont drain. other wise is sounds like a faulty drain pump
Nov 17, 2007 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch 24 in. SHY56A05 Stainless Steel Built-In Dishwasher Logo
597 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
