Question about Toshiba RD-XS35 DVD Recorder/HDD Recorder
Hooking a vcr player to toshiba rd-xs35su
How do i hook another vcr player to record to my toshiba rd-xs35su
    Problem Solver:
  • 10 Answers
Hi, connect it via a scart lead and switch to av channel.
Posted on Jan 13, 2008
6ya staff
SOURCE:
How do you find a dvd recorder that does not need and external tuner? Does the new tv's have a tuner that you can use with the current dvd recorders
U have cables or satallites tvs services hook up.U can record VHS tapes and used any DVD/VCR recorder machines hook up.Because the pay services does convert the signal back to analoge tv signal so u can record VHS tapes.
May 12, 2011 | Toshiba DVR620 DVD Recorder/VCR
Front Display is saying DR-2 and will not let me use remote to control anything...only thing I can do is shut power off with front panel..I have unplug from outlet and let set for 30mins and plugged back...
I received an attachement from the Toshiba Repair folks several months ago, when we had the same problem. To resolve it, do the following:
While pressing the Easy Navi button on the remote, press 2. The remote control mode will be set to DR 2, which is what the recorder is telling you it is set to.
We encountered this problem for the first time, for no apparent reason. It happened again today, after the operator dropped the remote. This fix worked both times.
Nov 07, 2010 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Don't know how to set channels w/new cable box.
Use channel 3 or 4 or hook up the RCA jacks. If you use 3 or 4 leave it on that channel and use the cable box to change channel. Use RCA jacks (best) turn the channel on the recorder to line in ether LINE1 or LINE2 with one you plug it up to and leave it on that channel.
Jul 23, 2009 | Toshiba RD-XS32 DVD Recorder
How do I hook up my vcr to my dvd recorder so I
You will need one RCA video cable it will have a yellow, red and white plugs. On the back of your VCR locate where the color inputs are find where it says VIDEO OUT hook it up there. On the back of the DVD Recorder look for the same color input jacks NOW find where it says VIDEO IN hook it up there. You may have to turn on your TV,DVD recorder and VCR to get the right channel. your Recorder may have one or more video inputs if it does turn on all three. Use the channel on your TV you use to watch DVDs make sure you see your DVD screen. Now to record to a DVD. Change the channel on the DVD Recorder. Look for the input channels It may be Video 1 Video 2 etc... depends on the inputs you have. ( A great way to tune your DVD Recorder is to play a prerorded VCR tape. Turn the channel on your DVD Recorder unil you see the prereorded tape playing. )
Jul 21, 2009 | Toshiba Audio Players & Recorders
Can't get vcr's to record
ok heres how to get 1 to record...on the cable box look for the AVI OUTPUT hook up the red white and yellow wires to it..then hook the other end of wires to the input on vcr now change the channel on box to input u will have to use the vcr to control the channelssometimes u have to put a tape in vcr and hit play then stop to get the vcr to its stable mdode
May 31, 2009 | Toshiba DVR610 DVD Recorder/VCR
Need an RCA Adapter for a TOSHIBA D-VR610KU
If the RF Modulator will convert a coaxial signal to an RCA output signal, fine however, you still need a tuner to select the channel on the TV you want to record. This unit is primarily for dubbing or copying DVD to VCR or VCR to DVD. There is no tuner in the unit to get the cable signal. Try hooking up an additional VCR, that probably has a tuner in it and use the RCA out of the 2nd unit to the RCA in of the Toshiba. Hook the coax to the input coax jack of the 2nd then RCA out to RCA in of the Toshiba. Choose what channell you want to record on the 2nd unit. You may have to choose Auxillary mode on the toshiba the press instant record on the Toshiba. Again, this unit is a Player or Dubber. Not designed to record TV shows without an external tuner. I hope this helps. If you use a 2nd VCR just to get the TV Signal, you won't need the modulator.
Jan 21, 2009 | Toshiba DVR610 DVD Recorder/VCR
Recording with comcast hd box and toshiba VCR/DVD
1st, see if you can get another cable box that offers component as well as RCA outputs on the back. Does your cable box have S Video out and does your toshiba have S Video in? If so, hook up the S Video from cable box to Toshiba. Then hook up R&W audio from Cable Box out to Toshiba In. Set the channel on the cable box to what you want to record. Set Toshiba to record channel 3 or 4, whichever your Toshiba is set on. The cable box controls the channel you are recording. You cannot set the recorder to the channel you want to record. It must be either 3 or 4. Try it. If everything else fails, you have to go cable from wall to cable in on cable box, cable out on cable box to cable in on Toshiba then either cable or RCA out on Toshiba to TV.
Jan 17, 2009 | Toshiba DVR610 DVD Recorder/VCR
Toshiba dvr will load some dvds & not others
My machine has also done this since it was new. I was just about to bring it in for repair when I thought I would try one more thing. I turned on the recorder. I put in the movie that would not play and let it load (of course it would not load). I pushed the on/off button on the recorder and held it down until the "wait" message came up on the display. After the message disappeared I turned the recorder back on. To my surprise the movie loaded and played. I tried all the other movies I had trouble with and they also played. I hope this helps. I saved my self over 200 dollars in repair bills. I was quite surprised at the lack of help from toshiba.
Dec 06, 2008 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba dvd recorder #rd-xs35
The full manual can be downloaded from http://www.tacp.toshiba.com/dvr/product.asp?model=RD-XS35
The cable box hook-up is on page 22. There are two ways: 8bc47e0.jpg
Oct 25, 2007 | Toshiba RD-XS35 DVD Recorder/HDD Recorder
Toshiba RD-XS35 DVD Recorder/HDD Recorder Logo
144 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
