Question about Sony Playstation 3 (PS3) Console
Video settings I set my PS3 up on my HDTV now Im trying to play it on our regular tv and it won't play.
  • 182 Answers
When you turn it on hold down the power button for 4 seconds. it will run the screen settings menu and put it in the best possible option for the lead fitted. hope this helps
Posted on Jan 13, 2008
Hdmi ports not working
reset your playstation 3 video setting
Reset Video Output
If you are changing cables or cannot see an image on the screen, you may need to reset the video output to default settings. To reset the video output:
  1. While the PS3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the PS3 beeps a second time (approximately 5 seconds), then release it.
  2. The PS3 will power up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 21, 2013 | Sharp AQUOS LC-40LE830U 40" LCD LED HDTV
Tv and ps3 plugged in and on. av channel shows an empty screen
Follow these steps to resolve your problem:
1. Turn off the PS3 so it only shows a red light. You can hold the power button on the front until it goes into standby. To be sure, flick the power switch on the back of the Play Station 3 off and then back on.
2. Make sure your Play Station 3 is connected to your regular TV (not HDTV) with the standard video cables.
3. Press and hold the power button until the screen "flickers" and then immediately release. This should reset the video settings.
4. Wait a few seconds, and the Play Station 3 (PS3) logo should appear.
If this does not resolve the problem, follow these steps:
3. Press and hold the power button on the front until the Play Station 3 beeps and then turns off again. This should reset the video for you and you can turn it back on after this.
Jun 10, 2010 | Sony Playstation 3 (PS3) Console
Ps3 wont display on the tv!!
Jun 10, 2010 | Sony PlayStation 3 40GB System
Ps3 not wworking on regular TV after hdmi cable was used.
sounds like you have the ps3 set up in HD video display settings?
If this is the case hook it up to the regular tv and when you turn the power on continue to hold down the power button til it beeps this restores the video to default settings sometimes it takes a 2nd power down and power up holding it down to work.
If this doesnt solve please give more details
May 02, 2010 | Sony Playstation 3 (PS3) Console
I have both an HDTV and a regular tv. When I set up the ps3, I told it to hook up with the HDMI cable. I want to move the ps3 to the regular tv, and the video and audio won't appear on my regular tv.
First add the basic wires to the old tv too. Then go to the screen options while using the hdmi on your hdtv and set it to the normal non-hd screen mode. Then it should appear on your regular tv
Feb 21, 2010 | Sony Video Game Consoles & Games
Ps3 broken
When you attach your Play Station 3 to an HD TV through an HDMI port, the Play Station 3 will ask you if you wish to switch to HD Mode.
However, if you decide to move it to another TV that is not HD compatible, you will get no picture because the Play Station 3 is “stuck” in HD (HDMI) mode.
That’s it! You can play your Play Station 3 again!
Nov 06, 2009 | Sony Playstation 3 (PS3) Console
Playing on a regular TV.
Ensure you have returned the PS3 video output system setting to 480i vs the 720/1080 setting. Regular TV will give you a black screen at the higher resolutions.
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
Screen flickers when I play a BD movie on my PS3
Does it do this with all Blu-Ray movies?
Have you tried a different HDMI cable?
Jun 18, 2017 | Sony Playstation 3 (PS3) Console
PS3 Won't Play Blu-Ray
If there is no picture on the TV screen: Back to top
  • Check that the input mode of the TV is appropriate for the connector in use on the PLAYSTATION®3 computer entertainment system.
  • There may be a problem with the cable in use. Try using another cable that is compatible with the PLAYSTATION®3.
  • If the video output settings on the PLAYSTATION®3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION®3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
If the DVD or Blu-ray Disc™ (BD) cannot be played, or the picture is distorted: Back to top
  • When outputting DVD content or PLAYSTATION®3 system format software in SD resolution, only discs recorded in the NTSC standard can be played.
  • If the PLAYSTATION®3 is connected to a VCR or a combination TV/VCR unit, copy protection encoding on some DVDs and BDs may cause image distortion, or may cause the image to become lighter or darker. In such cases, connect the system to the TV directly.
  • If the DVD or BD does not match the region code set in the PLAYSTATION®3, it cannot be played.
  • Some DVDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to temporarily increase the viewer age restriction level.
  • Some BDs are preset with parental control restrictions. Enter the password that was set in "Security Settings" to change the parental control level.
  • The BD may be disc-locked. Enter the password that was set when the disc was created.
if non of that works you need to contact Sony at
1-800-345-7669 (SONY)
Mon - Sat 6:00AM - 8:00PM PST
Sun 7:00AM - 6:30PM PST
Good Luck,
-Rel
Apr 16, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
23 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
