Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Blue shadows have appeared on the screen
The right side of the screen hae blue shadows along the objects/people on screen. Any solutions or suggestions?
  • bradmel97 Jan 18, 2008
    We have the same problem, but the shadows are at the top and bottom of the screen. We have went into the MENU section and into:
    Manual Converge
    Multipoint Converge
    Then theres RED and BLUE multipoints..
    When you go the it brings up some + signs that are different colors that look messed up. No matter what we do to adjust them it doesn't make much difference... A repairman says he could fix for $375???? Have you had any work done???
  • conn 1977 Jan 22, 2008
    I have the same problem but lost the remote used cable remote but can not adjust little multie points???? Any suggestons???
    Genius:
  • 1,139 Answers
Hello All,
This is a convergence amplifier problem, it can be fixed for a relatively low price, however I do not suggest that you do this on your own because it may lead to more damage then what you have now.. The price the repairman is quoting you is fair, although I have repaired such problems for the cost of the parts and the labor, total of $180.00, but that was because I am able to work without overhead. I would suggest that you have a qualified TV repair technician fix this problem but if you really want to do it yourself here we go:
Turn the TV off and unplug it
locate the two STK IC modules on the metal heat sink (usually on the deflection board),
Remove the deflection board,
Unscrew the modules from the heat sink,
locate all of the biasing resistors connected to the STK modules and de-solder them along with the modules,
Remove the modules and the resistors,
Replace the modules and resistors with new ones (purchased beforehand),
re-solder all components (making sure that you do not create any shorts)
Check your work with a magnifying glass.
Re-install the deflection board, and power on the TV.
Adjust convergence to manufactures specifications.
I hope this helps,
Thank you,
Shuttle83
Posted on Jan 26, 2008
On our JVC AV-48WP30 48in, red shadows
some how the convergence ckt went bad,common problem to pj televisions.
Mar 19, 2010 | JVC AV-48WP30 48" Rear Projection...
Blue shadowing on our 7 year old Sony Grand Wega KDF-60XBR950
YOU NEED SOME CONVERGENCE IC THIS REPAIR MY COST U ABOUT 200-300 PLUS SERVICE CALL
Aug 24, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Blue shadows appear to be behind white objects
TV shows large red spot in middle of tv when dark show are on, you can see it more.  Now blue spots on upper right side too.  Spend way to much on this tv to have these kinds of problems only after 3 yrs.
Nov 16, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Red and blue shadows
Did you ever get the solution to this? I'm having the same problem on my 65 incher.
Sep 15, 2008 | Televison & Video
Sony kp-65wv600 blue arch line on left side
in the menu does it have a convergence menu? try doing that.
Feb 20, 2008 | Sony KP-57WS500 57" Rear Projection...
Having shutting off problem, along with blue convergence issues!
1) Definitely a bad solder connection..I use a magnifier...
2) Blue convergence IC bad....change both for reliability
Located on large heatsinks on main PCB.......
Check B+ resistors for over-heating...............................T.
Feb 06, 2008 | Televison & Video
Colored shadows on sides of subjects
Convergence problem... most likely caused by convergence ics
Jan 18, 2008 | Hitachi 43UWX10B 43" Rear Projection...
RCA 52" HDTV Rear Projection TV MM52110JX1
Replace FL231 400ma fuse. this will fix your problem.
Oct 26, 2007 | RCA D52W19 52" Rear Projection Television
Blue and red shadows on screen
This sounds like one of the convergence IC's has cracked loose or burned out, and should be replaced and realigned by someone with experience.
Jun 26, 2007 | Hitachi 50UX57B 50" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
54 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
