Question about Audiovox PRT9200
Main display somehow turned off main display, now I can't get it to come back on
0 characters
1 Points
My pioneer 2700 BS has too many devices on it and the memory is full I've been told I have to shorted out reset somehow from the back how do I do that
Displaying the “Bluetooth”
1 Press option key.
2 Touch , and then . The “Bluetooth” screen appears.
Clearing the Bluetooth memory
This setting is available only when you stop your vehicle in a
safe place and apply the parking brake.
Never turn this product off while the Bluetooth memory is
being cleared.
1 Display the “Bluetooth” screen. ? Displaying the “Bluetooth” screen on page 12
2 Touch [Bluetooth Memory Clear].
3 Touch [Clear].
The confirmation screen appears.
Sep 09, 2015 | Cell Phones
How do you change language from Spanish to English on this phone? I put it on spanish somehow and i cant get it back to english.
Using Settings
Settings contains many submenus that let you customize your phone.
Display/Info Features The Display/Info menu controls how the keypad and display appear: - changes the wallpaper that • Wallpaper appears on the idle screen. - sets the size of text on the display. • Text Size - changes the look of the display. • Theme - controls whether main menu • Home Icons icons appear on the idle screen. - controls backlight illumination. • Backlight133 Customizing Your Phone - controls whether the time and date • Clock appear on the idle screen; sets time and date format; sets year. - controls whether the items on • Menu View your main menu and Java applications menu appear as large icons or a list. - sets large digits to appear on • Large Dialing the idle screen when you enter a number. - sets the language that your phone • Language displays.
for more information Get the manual from here
Hope this helps if so do rate the solution
Jan 05, 2011 | Motorola Mobility i850 Cellular Phone
Click on the LG Dare display settings button and the phone resets
all you do is go into your security and settings and reset the phone. it will turn the phone on and back off again. but this should fix the problem and restore the ability to get into your display settings, as well as view your date and time.
Jul 29, 2009 | LG Dare VX9700 Cell Phone
Moved Icon
from the main menu press this
menu button
menu button use scroll to select unhide all
find you icon, unhide it , then press menu button again and select hide all
Feb 14, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
I dropped my nokia 6101. then when i checked it after awhile...
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
This is your solution! Please vote!
Jan 31, 2009 | Nokia 6101 Cellular Phone
Sanyo Katana's display is just white and won't display anything.
You may want to try to somehow update the firmware, it could just be a funny error. Otherwise just take it back to your dealer and get a new one.
Jan 04, 2009 | Sanyo Katana® II Cellular Phone
Mini display is backwards
I had this problem once, i just turned the phone off and took the battery out for about 5 min, and when i turned it back on it was back to normal
Nov 02, 2008 | Nokia 6085 Cellular Phone
Back Light
First, check that the something is actually displayed :
Turn off the phone then put it on charge.
Check to see if the NOKIA logo appears even if the display is unlit. (try angling the display towards a sunlit window).
Having charged it, try to turn it on.. Do you detect the vibration the phone makes when starting up?
If nothing is displayed but you get that vibration I suspect that the display is somehow damaged and you'll need to look at replacement.
You local nokia centre should be able to provide you with a quote for the repairwork otherwise if you're confident opening it you might be able to replace the screen with one obtained from here for example:
Aug 26, 2008 | Nokia N95 Cellular Phone
Samsung a950 main screen display is backwards and upside down
My Samsung U700 had the same problem (display went back-to-front and colours all reversed and low-res.) It seems to be a problem with the flex cable (the cable between the main phone body and the sliding screen) wearing down and screwing up the data being carried between the display and the phone. Flex cables are cheap to buy and there's plenty of info online showing how to replace them yourself. Good-luck. Google: samsung u700 replacement flex cable
Jul 05, 2008 | Samsung SCH-a950 Cellular Phone
Audiovox PRT9200 Logo
16 people viewed this question
Top Audiovox Cell Phones Experts
Simon Lasota
Simon Lasota
Davor Krstevski
Davor Krstevski
Are you an Audiovox Cell Phone Expert? Answer questions, earn points and help others
