Question about Brother MFC 420CN All-In-One InkJet Printer
I admit it, I used cheapo refill ink! Now the black section of the print head doesn't work...
I admit it, I used cheapo refill ink! Now the black section of the print head doesn't work. I took the printer apart and flushed the black tube and return line with alcohol, then installed new BROTHER black ink cartridge, but still almost no black gets through: when I do image quality test print it manages to print 2 or 3 of the 24 or so dots that show up on the color squares. Can you tell me how to rescue this print head, or where I can buy a replacement?
  • 1 more comment
  • buddybob Jan 13, 2008
    Thanks for your advice. I see what you mean about hard to replace, but I've already been there: I'm a copier technician, so the mechanical proceedure is within my ability, but could you tell me more about the "you must program in the head id and run a purge" proceedure you mentioned?
    Many thanks,
  • buddybob Jan 20, 2008
    Sending this post again, not sure it went through:
    Thanks for your help. I've taken it apart again and think I've cleared most of the print head blockage, but now I get message:
    "unable to init. 4F". Can you tell me what that refers to? Here's my email...
  • Anonymous Mar 18, 2014
    I already cleaned the black print head 5 times. Quality improved, but not well yet. I have ink in the black cartridge. May be ink is dried. Is it possible?
Hey, that's terrific! Ah, well, thanks for your advice. I guess I'll be buying a new printer very soon. Shopping around, it looks like most brands use the same disposable printer setup. Can you suggest any inkjet MFPs that have replaceable print heads in case I make the same foolish mistake again?
Thanks Again
Posted on Jan 26, 2008
  • Brother Master
  • 1,113 Answers
I'm afraid there is no real sucessful way of cleaning these print heads, tiny micro filters built into the head unit will blocked. I have never unblocked one fully.
Fix is to replace head
These heads are not easy to fit, then once they are you must program in the head id and run a purge with four gen inks, this purge uses like 1/4 of each ink.
Recommennd you replace printer it is cheaper to
LINK to UNRECOMENDED removal of head
I dont have the 420 cn listed but here is link to mfc425cn head info so you can see how much they are not worth buying
below is pic of head
I admit it, I used cheapo refill ink!  Now the bla - 2d7dc76.jpg .
Posted on Jan 13, 2008
  • 2 more comments
  • Soulvisitor
    Soulvisitor Jan 13, 2008
    more info on wasting time fixing a brother printhead
  • Soulvisitor
    It too much info to repeat, post email address I might send you a present.
    Menu * 2 8 6 4 rapidly gets into maintence mode then 76 is purge, then 4 for inital and choose all or something like that
    Head info is put into eprom so electronics knows what to do with head I use specialised software but can be done via control panel but once again why waste time with it
  • Soulvisitor
    Soulvisitor Jan 21, 2008
    Great work but now you have killed the head, here is info from service manual
  • Soulvisitor
    missing bit is replace head, main board or head supply pcb
Why doesn't my black ink work in my Epson WorkForce 600 series after replacing the black ink cartridge?
The Epson printer may only use genuine ink cartridges which contain a chip so that you cannot fill the cartridge with ink or use non genuine ink cartridges.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 01, 2013 | Office Equipment & Supplies
I can't print with the black ink. I performed a print head cleaning, and then I printed the nozzle check pattern. I noticed that the Cyan, Magenta, and Yellow shows up. However, the black checkered...
Simple problem that print head cleaning will typically not fix. The black ink is pigment based so it tends to form more stubborn clogs. Just remove the print head and if you have a steamer hit the black printhead nozzles with some pressured steam. If not available, soak the surface of the printhead in shallow hot water (try not to get the contact wet or be sure to dry them if you do). You can tell if the printhead nozzles are open by folding a section of wet paper towel like 5-10 layers and then soak it, press the printhead surface up and down lightly on the wet paper towel and if the nozzles are open you will see some ink pulse in the black port screen (the colors will also pulse from the pressure of the liquid under the printhead). It's easier than it sounds so give it a try. I've saved 100s of Canon printheads this way.
Note: if you have a really dried out head, you sometimes have to soak from the top inlet ports and the bottom nozzle surface to clear, but unlikely in you case since you had a black cartridge installed with ink in it (this keeps the top port from drying).
Sep 15, 2011 | Canon MP520 All-In-One InkJet Photo...
HP 5150 Deskjet -- black printing abruptly stopped. Prints appear with color but no black. Switching black cartridges doesn't help. Clean print heads operation doesn't help. Switching computers...
There are very few things you can do, other than what you have aleady done.
I would recommend a decision on how much the unit cost and how long you have used the
printer vrs. what HP or a local authorized service center would charge to repair it.
If you have refilled ink cartridges, this is problem that can arise due to ink drying on the
print head as the black cartridge is use the most.
Aug 06, 2011 | HP DeskJet 5150 InkJet Printer
I am printing an invitation on my HP Officejet 7210 All in One. I am gettting striping in areas which have a lot of solid black. How can I fix this?
From the HP Toolbox on your PC you can run a cleaning page. If that doesn't fix it, or if you are using refilled ink cartridges, it may be time for a new black ink cartridge.
May 02, 2011 | HP Officejet 7210 All-In-One InkJet...
Even after refilling the cartridge, printing is not clear
Refilling cartridges on _quality_ printers is not a wise solution. The makers of printers like Hewlett Packard spend thousands of dollars to formulate an ink to match the print head and printer. Then you buy a cheapo version of non-descript ink and refill their cartridge to save money and complain about the result. Buy a new HP cartridge, clean the nozzles, print a test sheet and post the results please.
Nov 17, 2009 | HP LaserJet 6L Printer
Printer not printing in black. Print Color only.
Thanks for using FixYa. First of all please try the refill cartridge on some other printer. If it’s working fine on the other printer then check the settings of the printer which are by default 960 dpi (dots per inch) but due to some reason this size has been reduced. Now you have to change this setting to more than 960, around 1200 dpi and then check out that if your printer works fine.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Jul 28, 2009 | HP PSC 1210 All-In-One InkJet Printer
I just refilled black ink of my new printer Lexmark x5495. Does not recognise the black cartilage and keeps on asking for alignment. When it prints alignment page it does not use the refilled black ink....
“Lexmark does not support the refilling of its ink cartridges. Refilling the ink cartridges can cause them to leak, thus clogging or even damaging the print head. Any damage to your printer caused by refilled ink cartridges may not be covered under warranty”. Please use genuine Lexmark cartridges for best results.
Apr 10, 2009 | Lexmark X5470 All-In-One InkJet Printer
Black ink will not print
The ink on the print head is dry and it is preventing it from printing.
I do my own refill so I buy a refill kit, in it, has 3 bottle of inks and a bottle of cleaning solution. The cleaning solution I use to clean the head.
A place that refill in should carry some kind of a cleaning solution that you can use.
I hope this help you
Mar 16, 2009 | HP Officejet Pro L7680 All-In-One Printer
Brother MFC 420CN All-In-One InkJet Printer Logo
383 people viewed this question
James Cagle
James Cagle
Jim Keysor
