Question about Toshiba CN36X81 TV
TV turns off by itself after being on for 60 seconds
After turning off red standby light flashes. Have to unplug tv and replug before turning on again.
I think it is a power supply problem, but I am not sure. I had an older 30" toshiba with a similar problem about 8 years ago
  • 2,336 Answers
Led blinking Three times means B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Hope this helps.
Posted on Jan 25, 2008
  • Jaime Hernandez Jan 25, 2008
    Disregard these instructions as they will not be applicable to your TV. I was to answer a sony problem but by mistake I pressed post.
    Sorry.
Tv comes on for 2-5 minutes then goes off
I can help you to solve your Sony KDF-E60A20 tv problem.
Does tv turn back on itself OR standby light start flashing?
If standby light flashing, please count how many times it flashing after three seconds long pause and let me know to diagnose problem.
Thanks.
Dec 04, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
I have a sony bravia 52" KDL52W4500 problem it has brokedown, goes on for a second then switches itself off again, red standby flashes 6 times
6 times red standby light flashing is an error code that shows problem of "Panel Det Error" It is technical term and experienced tech will understand it.
Possible cause of problem is either Power (G5) Board, Inverter (D5) board and/or LCD Panel (screen) itself.
Unplug tv from wall socket for couple of minutes to get it reset, replug back in and turn it On, if problem still not solved then it is not user level repair and you need Sony qualified technician to take care of it.
Thanks.
Sep 27, 2010 | Sony Televison & Video
Sony tv won't turn on... When I hit the power it kicks in for seconds. the green light flashes four time then red flashes three times.
Tries unplug,replug tv back in an hour later,let the tv reset itself back to factory setting.The tv should work now.Not than the power supply board it dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 15, 2010 | Sony Televison & Video
Standby button (red) flashing on tv. tv turns on briefly(no picture) and then turns off with flashing red light re-appearing.
Try tv unplug,replug about an hour later.The tv now,resetting to factory setting.The tv now,should work.Not than,the power supply board is dead.That the board,where the power a/c cord plug into it.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 08, 2010 | Sony BRAVIA KDL-40V3000 Television
Tv keeps turning itself off and then back on. green power light blinks. If i tun it off when it does that the red power light blinks 5x repeatedly.
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jun 22, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My Sony Bravia will play for less than a minute and then reverts to standy. Any suggestions?
Please unplug tv from wall socket for minute or so,, replug back in and turn it On.
If tv still goes to standby itself than its standby light would blink to show an error in somewhere inside tv circuits.
Let me know how many times standby red light blinking? There would be 3 seconds long pause in blinking so count pause to pause to determine problem section.
Thanks.
Jun 13, 2010 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
No power but has red light flashing
Thank God for the internet. I had the same problem and I googled it and found this site with this solution. It worked fine. Thank you. Like you said, unplug, hold the power button for 60 seconds and replug and turn on. Worked like a charm. Thanks a bunch.
Nov 13, 2007 | Panasonic TC-32LX60 32 in. LCD Television
Toshiba CN36X81 TV Logo
206 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
