Question about Fisher Paykel EcoSmart GWL15
Power off After the machine is turned on for the next load to be washed, it stops after about 5 min and powers off. I then must unplug the machine and plug it back in for a minute to get it to power up again. I'm cluless
  • adrienne42 Mar 08, 2008
    We were ableto turn it on one time and then havent been able to get power to it at all is there a reset button
  • Ron Coons
    Ron Coons May 11, 2010
    whats the model #?
    Sergeant:
  • 351 Answers
May have something wrong with pump? causing the motor control board to turn off.or it may just be a faulty board.
Posted on Mar 02, 2008
Maytag epic Z He washer ecu reset
Unplug it from the wall for 5 min's to reset.
May 05, 2017 | Washing Machines
LG top loading washing machine will not turn on
Possible 3 Probs 1st has the fuse blown in plug 13amp, 2 probably brushes on motor are worn down and only just making contact that why some times when u turn it its ok again,
the second is there is a unit called capistor ur machine will run erratic as this goes then stops all together the unit is silver round about 30mm X 750 long with 4-5 wires connected on 1 end hope this Alan
Oct 02, 2012 | LG WM-2277HW Front Load Washer
I just replaced the cold water fill valve in my GWL11 and turned on the machine. All worked GREAT except the hot was cold and vice versa. Ooops, I had the hoses connected backwards, so I powered off t
a hose swap will not kill the board. But unplugging the unit with the machine turned on might kill the board... moving the power plug, or circuit breaker with the board 'alive' /turned on.. can cause damage.
Sep 09, 2012 | Fisher and Paykel GWL11 Top Load Washer
WHEN I PUSH THE START, NOTHING HAPPENS,NO NOISE AND THE DOOR DOES NOT LOCK. IF I PUSH THE CLEAR BUTTON TWO -- WILL APPEAR AND STAY FOR ABOUT 30 SECONDS AND THEN A BLANK DISPLAY. UNPLUGGED WASHER FOR 5 MIN....
if you had a power failure latly or a power surge it might have knocked the program on the machine.Push and hold the stop/start button for about 10,seconds it should reset if that fails again hold the stop button and another ie rince hold/power save or whatever buttons you have i just cant remember which one there are so many,but try the first option first it should reset.adrian,,,,,,,,
Aug 15, 2010 | Kenmore 44072 Front Load Washer
Front door won't open on 2003 Kenmore Washer and no release
When I had the same issue I tried the following things. It has been so long I do not recall the exact order I did them in or what finally worked but it did open.
Unplugged it for 5 mins.
Turned off everything else in house.
Plugged it back in.
Pushed Drain/spin - start (I could hear it try to click locked)
Then I pushed to stop it (then I hear the door lock click)
I tried all the different wash options and finally one of them allowed me to cancel the wash and the door unlocked. I know I unplugged it at least twice because of the computer needing to be reset. When a tech was working on it a couple of years ago I had him explain a few things and I don't recall the exact # of min's you are supposed to wait so I use 5 min's.
The water was still in my washer and I had to open the bottom and drain it by opening the cleanout to the pump. Large mess on the floor. Make sure you unplug the machine first. It will get on the wiring.
I also learned recently that your house electrical needs to be correct. These machines are extremely picky about their power.
Sep 17, 2009 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet washer had an off balance load. the load stopped with 45 min. to go and we can't restart
unplug from wall for a min plug back in and push power on select drain/spin then the start button
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Machine not spinning after a power cut
machine can be reset unplug from the wall for 5 mins that will reset com board.
Jan 07, 2009 | Hotpoint Ultima WF860 Front Load Washer
Simpson enviro front loader washing machine
have you tride unpluging it for 5 min. and see if if it will come back on sometimes this works as far as a rest its prob behind near or on moter it should be a red button check and see if fanbelt has not broken or slipped
May 24, 2008 | Whirlpool GEW9250 Electric Dryer
Fisher Paykel EcoSmart GWL15 Logo
35 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
