Question about Akira EPM-420A 42 in. Plasma Television
Internal power supply
Akira EPM 4200A Plasma monitor, 42':
I am looking to buy this used monitor, but according to the seller, it need an internal power supply in it. The seller says the monitor was purchased in 2000. I live in Des Moines, IA, and I don't know where it can be fixed... do you?
  • 3 Answers
It may not be as complicated as you may think. use a hair dryer on the top right of the back of the tv.
Posted on Feb 17, 2008
When i turn my tv on it powers off after a few seconds
In the absence of audio and video, the likely culprit is the main power supply which services both. Plasma sets use an output of the main supply to produce the high voltage required by the plasma display which has attributes similar to the older CRT displays in the use of high voltage and internal phosphor to convert electron flow into light. The main supply may be a separate assembly. If you feel adventurous, pull the AC plug overnight and remove the back panel of the set. Look for a smaller board with fewer, but larger, components on it. There may be another separate smaller board that produces the high voltage for the display but it is probably OK but not receiving service voltage from the main supply.
If you can find an assembly number on the main supply, you may be able to buy or exchange it for a repaired unit and do the swap yourself.
Feb 09, 2011 | LG RU-42PX10 42 in. HD-Ready Plasma...
Akira tv ct21cgs5ke no picture or sound but power is on, with a ticking sound
you have a supply for your tv but its look like dead set tv? ryt... in think you should had problem to your secondary power suplply, the regulator or chapper system is not functioning
Dec 14, 2010 | Akira SV-4201 42 in. Plasma Television
Problem with AKIRA TV
i need akira tv service mode code pl help me
Jun 23, 2008 | Akira SV-4201 42 in. Plasma Television
Hitachi 42PD3000 Plasma 42 polegadas ... Problema!!
the internal power supply has failed just needs a new one
Jun 14, 2008 | Hitachi 42PD3000 42 in. Plasma Television
Un lock child Lock.
HAL DIE EPROME YT SIT AN TV VIR EEN SEC EN SIT EPROM TRIG EN SIT TV AN
Jun 13, 2008 | Akira EPM-420A 42 in. Plasma Television
Plasma TV
I would check the internal fuses, should be 4, also check the output of the power supply, could be your y block is gone or your power supply.
Regards
What About Bob
Feb 24, 2008 | Televison & Video
Akira Plasma not working anymore!
Have you gotten it fied yet? You can use a hair dryer to get it to come on.
Jan 30, 2008 | Akira EPM-420A 42 in. Plasma Television
Screen problem
This is a problem we have seen on this particular unit. There are internal adjustment that must be done to correct this problem. This adjust is done on the power supply. There are VS, VE and VA adjust. Look on the interior of the Panel for voltage chart. Adjust these voltage accordingly.
Best regards
Circuitcity
Dec 07, 2007 | LG 42PX5D 42 in. Plasma HDTV
SVA HD4208 PLASMA PANEL TV.
SVA is a manufacturer based out of China. Their headquarters is based in LA California. They specify in affordable plasmas and LCD's which are typically a generation or so behind other LCD manufacturers or plasma manufacturers. I have heard of this issue both in the power cord and internal parts of the TV's. Is it still under warranty? Otherwise, you can purchase another power cord. Contact the manfuacturer for those small parts.
Feb 16, 2007 | SVA-USA HD4208TIIIBU 42 in. HD-Ready...
Akira EPM-420A 42 in. Plasma Television Logo
194 people viewed this question
Top Akira Televison & Video Experts
jasbo
jasbo
ray gallant
Are you an Akira Televison and Video Expert? Answer questions, earn points and help others
