Question about Roxio DVDit Pro 6 Professional DVD Authoring for PC (230100)
Quick Book Pro 2008 problem
I have tried everything to get my QB to work after downloading. I can download it but when I double click the icon it says that it has to shut down. I have turned off everything running in the background that I can think of but just keep getting the same problem. I have downloaded, and uninstalled several times with no change I have also been on the phone to tech support and they are as baffled as I am. I tried loading it onto another computer with NO other QB on it and it worked fine. Something on this computer that I really want it on is not working. any ideas? I have been on the site and done all that they suggest with no change. I have a week before my other one will not work.... I am desperate to resolve this issue. Thanks for any help
Trudie
I install the disk register it put the icon on the desktop then click to open it and it's like a flash of lightening. I have turned off everything running in the background that I can think of but just keep getting the same problem. I have downloaded, and uninstalled several times with no change I have also been on the phone to tech support and they are as baffled as I am.
Posted on Dec 10, 2008
Recently purchased a new computer with window 7. Ouickbooks 2008 installed ok but within a week I got the message a file within the program should be replaced. I tried to uninstall QB 2008 but it will not...
Welcome to Fixya
To uninstall the QB 2008 program. Click start menu then click control panel. Go to program and features icon and search the quickbooks 2008 program. Highlight it and click uninstall on top. Wait until the program will be uninstalled to your system.
Thank you for using FIxya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Sep 04, 2011 | Intuit QuickBooks Pro 2008: Windows
I am trying to instal quickbooks pro 2008 but error 1603
Error 1603 is related to insufficient rights to install QB. Please follow these steps to resolve this issue. Assuming you have Win XP. 32 Bit OS.
1. Remove QB from Start>control panel>Add/remove programs. {IF YOU FIND ANY QB INSTALLED].
2. Rename all intuit folders to Intuit-old. You wil find these folders here:
  • C:\Program Files\Intuit
  • C:\Program Files\Common Files\Intuit
  • C:\Documents and Settings\All Users\Application Data\Intuit
  • C:\Documents and Settings\All Users\Application Data\Common Files\Intuit
3. Then install QB using QuickBooks.msi . You will find it inside QBooks folder in your QB disc. Right click on the DVD / CD drive and click Open/Explore. Then go to Qbooks folder, find Quickbooks.msi and then run it. Follow the wizard and then install it.
IF STILL ISSUE IS UNRESOLVED, THEN REMOVE AND INSTALL MICROSOFT .NET FRAMEWORK 2.0 SP2. To do it, please follow.
1. Download and install .NET removal tool from:
http://public.blu.livefilestore.com/y1pM-hUF1x_Oqpme4sYbkLY1eFfh7z7FTyANwGAK1PQgJMwhILtFzMj7WXQJtjfH39GalpsBeQRzeQHXRlbO9w1gA/dotnetfx_cleanup_tool.zip?download&psid=1
then save it and unzip it . Then run it. Select Allversions in the box where it will ask to remove .net framework from the computer.
2. Download .NET framework 2.0 SP1 and then install it . you can download it from:
http://www.microsoft.com/downloads/en/details.aspx?familyid=5b2c0358-915b-4eb5-9b1d-10e506da9d0f&displaylang=en
click on DOWNLOAD next to NetFx20SP2_x86.exe. download it and install it.
3. Restart your computer and then again install QB.
IF STILL YOU GET ANY ISSUE, REPLY WITH FOLL :
1. WINDOWS VERSION.
2. are you installing QB using a disc or downloading from the Internet?
3. Any Antivirus on the computer?
Oct 30, 2010 | Intuit QuickBooks Pro 2008: Windows
Error 7149 Quickbooks
Thanks, that worked! I first spent a half-hour on the phone with the non-tech support at Intuit and he walked me through that download. What the download does is update your original QB 2005 RC1 version to the RC9 version ("Release Candidate") where they've fixed some things (such as the Flash 7 install problem). Here's what we did:
1.) Removed Flash ActiveX 9 in Add/Remove Programs
2.) Downloaded webpatch from QB site (start here: http://www.quickbooks.com/Help...
3.) Closed QB (couldn't open it anyway)
4.) Installed patch.
5.) Restarted computer.
6.) QB worked!
Thanks for your postings. I hope this helps.
Thanks.
May 07, 2010 | Intuit QuickBooks: Pro 2005 for PC
Error message Library not registered
I got the message "Line 25: Library not registered" after uninstalling QuickBooks Pro 2009 and trying to run my old version of QB Pro 2006.
(I had installed 2009 version to upgrade my QB2006 Pro version but got into problems with multicurrency support not being supported in the Canadian QB Pro 2009.)
Fix is VERY easy and I think it applies to anyone trying to run an older version of QB Pro after uninstalling a newer version.
Fix is to find the file "reboot.bat" located in the program files associated with the older QB version.
In my case it was found in "C:/Program Files\Intuit\QuickBooks Pro" folder.
Just double click on the file to run it. This file tells the system where parts of the QB program are located including the DLL libraries it needs. After running this file you should be able to run your old QB version OK. No rebooting necessary.
May 08, 2009 | Intuit QuickBooks Pro 2007 Full Version...
Quickbooks 2008 will not load, it says that it is installing and then goes to error 1325
Assuming you have Win XP, please follow these steps:
1. Remove QB from Control Panel>Add/remove programs.
2. First rename all folders of Intuit. rename Intuit to Intuit-old from the following locations.
3. Then disable your Antivirus / Online Security.
4. Then install quickbooks using quickbooks.msi . You will find quickbooks.msi in the foll location:
>right click on ur QB disc and click open/explore.
>Double click on QBooks folder and run quickbooks.msi and follow the wizard.
If you still get any more issues, please reply with following:
1. Which windows version you are using ?
2. Are you installing QB for the 1st time on this computer?
3. Did you install any other software rrecently ?
P.S : this issue may also be because of Microsoft .NET framework on your computer. PLease help me with your reply to help you.
Feb 19, 2009 | Intuit QuickBooks Pro 2008: Windows
I am using quickbooks premiere edition 2008 and when I try to do anything with adobe reader it fails. I really need to get reader working
Try uninstalling the Quickbooks PDF converter.
Open the printers folder:
  1. In Windows XP: Double-click Printers and Faxes.
  2. In Windows Vista: Under Hardware and Sound, click Printer.
  3. Right-click the icon for the QuickBooks PDF Converter and choose Delete.
    1. Open the printers folder:
    2. In Windows XP: Double-click Printers and Faxes.
    • In Windows Vista: Under Hardware and Sound, click Printer.
    1. Right-click the icon for the QuickBooks PDF Converter and choose Delete.
    Jan 29, 2009 | Intuit QuickBooks Pro 2008: Windows
    Quickbook will open but will not bring anything up
    Hold Ctrl key and click on QB icon.
    Also Alt+F4 may work
    Jan 23, 2009 | Intuit QuickBooks: Pro 2005 for PC
    Bank reconciliation locking up, printing locking up.
    In your list of printers, you will have one installed by QB called "QuickBooks PDF Converter". Do your reconcile and when it seems to lock up, open your list of printers from the control panel and open this QB printer. There will be a document waiting to print (not sure why, it might be internal to QB). Select that document and hit the delete key. That should free QB up to continue (works for me). You may need to select it and press Delete two different times to actually remove it from the printer. Finally, because it is not easy to open up Printers every time, make a shortcut on your quick launch or desktop to the Printers applet.
    Dec 11, 2008 | Intuit QuickBooks Pro 2008: Windows
    Roxio DVDit Pro 6 Professional DVD Authoring for PC (230100) Logo
    48 people viewed this question
    Top Roxio Computers & Internet Experts
    Marvin
    Marvin
    Alun Cox
    Are you a Roxio Computer and Internet Expert? Answer questions, earn points and help others
