Question about Motorola Mobility RAZR V3
Getting Bluetooth to work with Motorola Razr
The instructions tell me to go to Settings. I do not have a screen that says settings on my phone. I can go to Settings and Tools, but no where does it ask about Bluetooth. What's up?
Go to connections
Posted on Jan 13, 2008
Problems getting bluetooth connection to stay on.
Your bluetooth is turned off.
Go into
MENU> SETTING> CONNECTIVITY> BLUETOOTH> STATUS (I THINK) ITS THE LAST OPTION> MAKE SURE THE MIDDLE OPTION IS NOT TURNED OFF.
Dec 26, 2008 | Motorola Mobility RAZR V3
Setting up my blue tooth
You need to pair it with the phone, working on phone settings, what is phone model?
Aug 29, 2008 | Motorola Mobility Bluetooth Headset H3 for...
Bluetooth not powering up
Try this ::
1. Create a link between your Motorola RAZR Phone and any Bluetooth Accessory 1.0 and up, you need to turn the Bluetooth connection "on". This is how: Go into your phone "settings". > Then select "Connection" > "Bluetooth Link" > "Set Up" > "Power" > "On". The connection will stay on until you turn it off. We recommend to turn it off when not in use to preserve battery life. 2. To connect your RAZR to another Bluetooth hands free kit or headset, go into "Settings" > "Connection" > "Bluetooth Link" > "Handsfree" > (Look for Device). You phone will scan for available devices located within the range of the RAZR, approx 30 feet away. If your cell phone is already connected to a Blue Tooth headset, you must disconnect from it to find other devices. Once you have identified your bluetooth device, highlight its name and click on the "select" button.
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is sually provided by the Bluetooth device manufacturer, not the RAZR. Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
PLEASE DONT FORGET TO RATE THIS RESOLUTION.
Nov 24, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Blue-Tooth set-up
usually you press and hold the button on the bluetooth headset device for 10 secs, the led will change color, then you pick up your phone get into the bluetooth part of the settings and tell the phone to look for it. Then after that when it finds it, the pin will probably be 00000.
Look it up on google the model of your headset you should be able to find the pin.
Aug 12, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Bluetooth Pairing with Motorola Razr
try to do this.. go to menu, settings, inittial set up, master clear, code (000000) the fone boots w8, then again go to menu, settings, initial set up, master reset, code (000000) fone boots again w8, .. then try to pair it again,.,, goodluck man!
Apr 28, 2008 | Motorola Mobility RAZR V3
I can't get my phone to connect with other peoples
I assume you are trying to connect to another phone via Bluetooth. It would help quite a bit to know what kind of phone you are trying to connect to, but here is what you need to have configured on your phone for Bluetooth file transfers:
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer, not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
4. You can now "Copy" media files to the phones nearby that you have connected to. Copy is an option while browsing through the files.
Dec 14, 2007 | Motorola Mobility RAZR V3
Can't connect with other peoples phone
Pairing a Jabra 250 headset with my new motorazr2
Here is what you need to have configured on your phone for Bluetooth connections:
3. The Bluetooth device will ask permission to connect. Select "yes" and press the "select" button; after that you will be prompted to insert a PIN code to initiate a secure connection. The PIN code is usually provided by the Bluetooth device manufacturer (in the manual), not the RAZR (unless you are connecting to another phone). Once the connection is made, you should see the bluetooth logo displayed on the internal screen, while the external screen Bluetooth indicator will flash.
Bluetooth
in this h.set BT automatically switches off after few seconds if not in use.it protects ur h.set from viruses.
u can increase this period from BT settings in h.set
Oct 09, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Problem with the bluetooth on my motorola v3
HOPE THIS HELPS: http://www.motorola.com/mdirect/manuals/V3_9501A42A.pdf
Mar 24, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
21 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
