Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Aquos Channel Bar/audio bar
I have a sharp aquos tv that runs off regular cable when I watch sertin channels the blue channel box at the top right corner pops up over and over with the audio box changing from mono to sap etc.. is there a way to stop this so i can watch these channels?
There is no factory option to stop the box from poping up every time the signal changes, which is what is happening. It has something to do with signal strength or the fact that your cable box is not set up for HD. Call your cable company to get a tech out to check your signal and set up your cable box because they do not come pre-set with HD defaults.
Posted on Jan 23, 2008
When i turn the bar off it automaticly comes back on right away
Samsung HW-F450 2.1 Channel 280-Watt Soundbar
www.amazon.com/Samsung-HW-F450-Channel...Sou...
Amazon.com, Inc.5) If you use sound share to connect samsung tv to sound bar, it uses bluetooth. I dont know if ... The subwoofer is wireless though it requires power connection.
Amazon.com: Samsung HW-J550 2.1 Channel 320 Watt ...
www.amazon.com/Samsung-HW...Channel...Soundba...
Amazon.com, Inc.
Rating: 4.5 - ‎104 reviews
Sony HT-CT370 2.1 Channel 300W Sound Bar with Wireless Subwoofer, Bluetooth, ...Samsung HW-J650 4.1 Channel 320 Watt Wireless Audio Soundbar (2015 ... 2.1-channel sound system with 320 watts of total power. .... bar away from the TV, there's not gonna be a lag or cutting off of the signal. .... Right To Your Door.
Samsung HW F450 Sound bar Problems with arc connec ...
? 5:25
https://www.youtube.com/watch?v=e46odUZ71tE
Aug 4, 2013 - Uploaded by DUGLESSM
Samsung HW F450 Sound Bar hdmi hook up. ... How to connectSound Bar to TV, Blu-Ray Player, DVD ...
Question about new Samsung HW-F450 setu
Jan 05, 2016 | Samsung HW-F450 2.1-Channel Soundbar...
My sharp tv wont change channels not even on tv buttons
I am going to assume you have auto-programmed the TV. If you haven't, do so and let it finish. Make sure you are in the right mode, e.g. Antenna for over the air and Cable for basic cable.
If you have a set top box or satellite, that box changes the channels, not the TV.
If auto-programmed it and it still won't change channels you have a bad tuner and you will need a new Main board to fix it.
Feb 15, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 32 LCD freezes on air channel
I had the same problem, same channel, same day. It must be a problem with signal strength. With the TV on, I unplugged the coax cable that leads to my antenna (I am not on cable). As soon as I disconnected the antenna, I could change the channel off of 11.1. I plugged the antenna back in and all other channels work. Hope this helps.
Jan 27, 2013 | Sharp Aquos LC-32D42 TV
HOW DO I GET THE BLUE BOX ON MY SHARP AQUOS LCD TV TO STOP POPUP
This happens when you are connecting with a coaxial cable. If possible you will need to connect your set top box to the television with a composite/RCA cable and watch tv on input 2 instead of on input tv.
Mar 19, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
"Failed to receive broadcast"
On your TV remote,press "INPUT".It is hard to find,but it should be there.Select"TV" and press"ENTER" button.I believe it is on the top of the list.On some cable boxes you have to select channel 3 and use the cable box remote to change channels.Also,make sure your TV antenna setting is set to "Cable" from the "Air/Cable"(Antenna setting).You will have to read your manual to find out how to get to this menu.After that do a "Ch Search"[Channel search].This automatically searches for all available channels and stores them. It will take some time.You will see the channel numbers as it does it's search.This is done so when you press channel up and down keys it will only go to next channel available and not to one with no signal.Hope this is of some help.
Feb 19, 2010 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
My Sharp Flat Panel Television LC19SB25U has Picture but No Audio
Sharp has had a few problems with their audio boards, not finding any bulletins on this model, but a few complaining about low audio on amazon reviews section. If using an antenna you will experience some channels with low audio. If using cable you should get good sound on all channels..
the 9.1 and 9.2 are digital channels and sharp does display them for at least a few seconds when you switch to that channel. Check all your setting in the audio to Stereo never SAP. To options for you are get a cable box, first check in the back and see if there is another coax in, if there are two try both rescanning after connecting.
GD lk
Eric
Aug 16, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Sharp Aquos HDTV Failed to receive broadcast
I too have this issue I beleive what is happening is the integrated tuner is not locking on to the channel because of a weak signal and then sending that error message . I am going to replace the cable from the splitter to this tv and see what happens. I have another new tv just installed from that splitter and it has all chanels. Remember to RE- run the locate all channels after anything is done to the cable splitter etc.
Mar 29, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
View mode incorrect after connecting to pc
hi my name is mark, i own an aquos, the side bar are normal. not all programming is broadcast in wide screen. if you watch during primetime you will see the bars come and go depending on if the program was taped in 16:9 or 4:3 format. you will see it on commericals also. thanks for your question.
Mar 17, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp aquos a box with mono and stereo and channel 3
Commercials are broadcast in lower quality than the programs, and it is normal for the signal to change when going to commercials. If you are watching ATSC you will notice also the video changes from HD (widescreen) to SD (normal) as well.
Jan 25, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Can't get all my cable channels
what cable company do you have because you should have a cable box because only a cable box can scramble the frequency so you can get the channel you subscribe for
Dec 17, 2008 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
251 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
